Question about Karcher 2500 PSI Pressure Washer
Karcher 520M Pressure washer won't operate at high pressure
I have water supply of about 33 gal/min (15 litres/min) (i.e. sufficient to operate 520M). When I turn the Karcher on it runs, but only at low pressure. Doesn't matter whether the wand control is Max or Min.
I dismantled the pump mechanism and cleaned everything. When I opened it I suspected a the "spill valve" was jammed, but its now AOK.
Anyone with any experience please? I can't quite work out what switches on the high pressure side of the thing.
Exploded spare parts list at:
http://www.m-and-d.com/karcher_parts.html
ANY pointers very gratefully received.
Dave
I had the same problem - good water inlet pressure, no output pressure, even though the lance and handle seemed to be clear and working find.
I found that the electrical switch wasn't being operated correctly by the spill valve and wasn't turning the motor on/off correctly.
Inside the plastic electrical box there is a small white device that presses against the micro switch assembly. Carefully adjust the allen screw perhaps 1/4 turn out or 1/4 turn in to obtain correct operation of the microswitch - you will hear the micro switch clicking in and out when re-assembled. I'm sure they must have a rig to check correct positioning of this screw in the factory!
Hope it helps - mine is working find now and saved me buying another!
Posted on Mar 09, 2009
2 Suggested Answers
  • 92 Answers
SOURCE: Karcher 520M wont operate at high pressure
The solution is very simple. All you have to do is change the spill valve.
This because the spill valve is not worth servicing. The actual problem is that the spill valve is leaking from its bottom-part seating. When you close the gun, the spill valve goes down, opens from the underside, and switches the electricity off. When you press the gun, the spill valve returns to normal, and if the underside does not close, you have low presure, because the water keeps circulating.
Regards,
MG. (Karcher service engineer).
Posted on Nov 04, 2008
My Karcher 530M runs ok until I release the trigger, then it will not start again unless I switch and allow the water to run through for about 15 secs before switching on again
Hi Cliff:
My experience is that the pump pressures prevent the engine from starting, so we hold the trigger while starting.
My brother has cut a wedge of wood that he uses to jam the trigger open to bypass the problem. It can get a bit wild if the wand is not secured when the unit is started..
Aug 10, 2016 | Karcher Garden
I have a gas powered 2200 PSI Cambell Hausfeld pressure washer when i try use it the pressure pulses up an down the complete time you hold the trigger down an ideal what i should look for Thinks
Quite often this can be caused by low water supply. Check the filter that the supply hose plugs in to and make sure your water supply has plenty of pressure and volume. There will be a water volume rating in litres per min (lt/min) or (gal/hr) depending on what part of the world you live in. You need to have at least that amount plus half again feeding the machine under a reasonable pressure 6ft/lb Gravity fed from a tank won't cut it. If it is vibrating and hardly working there is grit stuck under one of the valves which isn't a biggie but if you don't know how to disassemble the pump valves take it to someone who does as there are small parts like springs etc that are easily lost. It won't break the bank to get someone to repair it. Cheers. Hope this helps.
Jun 27, 2014 | Campbell Hausfeld Garden
Karcher 2500ph pressure washer spill valve has been replaced pull wand trigger pressure good for 3 or 4 seconds drops off for a second or 2 goes back to good pressure for 3 or 4 seconds drops off again for...
If you have a Karcher then you should always post your machines barcode.
full article on nozzles :
http://repairshed.blogspot.com/2013/09/pressure-washer-lance-nozzles-what-you.html
The spill valve operates at approx 20% higher than specified pressure washer operating pressure. If you have any lance issues then the pressure could be running higher than specified (machine running at same pressure as spill valve operation pressure)
your machine produces a fixed flowrate of water (maybe 8 litres per minute) and your nozzle is a fixed size. the diameter of the nozzle determines the back pressure. A piece of debris could further close your nozzle orifice and increase the back pressure. Using a new lance that has the wrong nozzle fitted can also cause this issue.
The karcher barcode is on a silver sticker and is usually 15 digits long. Example 156987400000123 is actually model 1.569-874.0 and serial number 00123....
Aug 15, 2013 | Garden
Karcher 2.59 Motor Whine - Not pumping water.
Check the following:
Check the water supply is at full pressure and there are no kinks in the supply hose.
Remove the water filter and ensure it is clean
If this is the first time you have used the machine ensure the supply hose is of sufficient bore.
Nov 21, 2012 | Garden
I have Karcher 520m and when you press the trigger you can hear what sounds like a relay engaging but there is no water pressure, then it will fire up and work, but next time you press the trigger the...
The issue you are having is with the unloader valve in the pump. Now with the 520m it is a little bit harder to repair than with more gasoline powered pressure washers but it can still be done. It would be easier if I could just send you a email of the breakdown on the machine. Send me a email to justin@wmpcs.com with the discription of the problem you are having.
Oct 10, 2010 | Karcher 1750 Psi Elec Pressure Washer
Does not give a continous high pressure flow cuts in and out
that is sure signal of insufficient water supply!
try easy solution first:
make sure that your mains is fully open, that tap on whihc hose is hook up is fully open and hose is of "decent" diameter to allow sufficient flow.
if above solution do not work then you need to make another, more difficult arrangement:
prepare 20litres pressure tank with inlet connected to mains and outlet by short hose to power washer, fill it with water from mains, keep it under mains pressure and use karcher power washer normaly. this will solve water supply problem. twenty litres will last about 2min, because it is re-filled, under standard pressure therefore it will last about 3min...
third possibility is to stop washing...
if you find my advice helpfull, please do not hesitate to left the comment and vote for me, thanx!
Jul 31, 2010 | Karcher K2.26 Electric Power Washer
My karcher pressure washer seems to oscilate on and off,the pressure is low ?
The most typical reason for this is that your supply pressure or volume is not sufficient. Try using a larger diameter hose.
Oct 30, 2009 | Karcher K2.26 Electric Power Washer
Karcher Power Washer that surges up and down with water pressure.
Before you start it up:
1. Disconnect the high pressure hose 2. Connect the water supply and turn on 3. Make sure water is flowing through the pump
Start the motor, run for about 10 seconds and then turn off.
Turn off the water supply, connect the high pressure hose, turn water back on, start the motor and away you go.
May 29, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 520m oil leak
small engine shop should be able to obtain the proper gasket for you.....oil 20 weight fill untill you can see it at the bottom of the threads at the whole you pour it into!
May 24, 2009 | Karcher 2500 PSI Pressure Washer
Regards,
May 05, 2008 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
3,460 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Phil Rivera
Are you a Karcher Garden Expert? Answer questions, earn points and help others
