Question about Apple 24" iMac Desktop
White screen when I turned it on ten minutes ago, still hasn't started. Tried the option-command-p-r. Worked before for a blue screen. Is it working and will start up when it gets done?
    Problem Solver:
  • 8 Answers
Try holding the power button down and keep holding till you hear an extended beep, then allow to start up normally this is like a heavy duty PR zap..... if that dosent work try booting up from your OS10 or techtool dvd holding down the C key during start up if boots from the DVD go to utilities then disk utilities and run it
Posted on Oct 06, 2010
White screen on startup
Thank for contacting Fixya, I will be glad to assist you.
When experiencing an issue with booting up to a white screen, you can perform several steps to attempt to resolve this issue.
Option 1:
• First, hold in your power button for approximately 10 seconds to do a hard shutdown, if your Mac is not already turned off.
• Once your Mac is shutdown, you will need to perform what is called a PRAM reset (Parameter RAM)
• Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously .
• Turn on the computer.
• Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
• Now, hold the keys down until the computer restarts and you hear the start up sound for a 2nd time.
• Release the keys and allow the Mac to start up.
If this procedure does not resolve your white screen issue, try this next option below.
Option 2:
-PMU RESET-
The Power Manager is an integrated circuit (computer chip) that is usually on the logic board of your Mac computer.
It is responsible for power management of the computer. It controls backlighting, hard disk spin down, sleep and wake, some charging aspects, trackpad control, and some input/output as it relates to the computer sleeping.
• If the computer is on, turn it off.
• Disconnect all the connections going into the Mac except for the Power cord.
• Once all connections have been disconnected, remove the power cord from the Mac.
• Wait 20 seconds.
• Reconnect the keyboard, mouse and power cord back into the computer.
• Press the Power button to restart the Mac computer.
Let me know if either of these processes help resolve this white screen issue.
Thank you.
Regards,
-The MacTechTrainer
Jul 13, 2012 | Apple iMac G4 Desktop
I cant get laptop to start up!
LOL, when will consumers ever learn to stop being so quick to go out and buy the latest and supposedly greatest operating systems? Windows 7 is so much like Vista with the problems of Startup Repair not working and losing devices, etc.
You reinstalled windows and it still does not work?
Ok, after Startup Repair tells you it cannot repair the problem. Click the option that takes you to the Recovery Menu to see other options. Down at the bottom select the Command Prompt.
When the command prompt window opens (black screen with white writing) they the command:
sfc /scannow then press Enter
When Sfc (System File Checker) finishes run the Check Disk Utility ( I ran one this week on someones computer that was doing the same thing and Check Disk ran for 3 hours, but it fixed the problem).
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Apr 20, 2012 | Dell Latitude D600 Notebook
White screen of death on Macbook 13". when turning
You may need to reset the PRAM.
Start your computer and hold down the option, command (apple), P and R keys simultaneously until you hear the second chime. Then release.
This will reset the perimeter RAM (PRAM) and may allow your system to start, which it will do immediately if it capable.
If this is not the case and you have already tried removing the RAM and the HD, you may need to have the motherboard tested.
Oct 31, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
HELP!! (dell precision 340) im getting 4 screens when i turn on m
Reboot into Safe Mode by repeatingly tapping on F8 while in process of rebooting and then select "last known good configuration". If that fails reboot again to safe mode and select safe mode with command prompt and in the command prompt type "chkdsk /f /r " <enter>
If that doesnt work do place your Windows CD into the Cd-Rom, reboot and select option "Repair"
Jan 02, 2009 | Dell Precision 360n PC Desktop
Blue screen...sometimes a white screen?
This error is caused by a bad sector or error on the HD. The best course of action to start with would be to either boot up from a windows XP CD or you can try going into safe mode with command prompt. Once you get to a command prompt you will want to type the command chkdsk /r. This will run a scan of the hard drive and repair any issues it is having. If you are booting from an XP CD you will want to choose the options for repair and go to the repair console. For further information please read http://support.microsoft.com/kb/297185
Dec 19, 2008 | Gateway FPD2275W LCD Monitor
Blue-screen crashes
i suspect the cpu and or fan is defective
Jan 09, 2008 | HP Pavilion dv1000 Notebook
Motorola Razr front screen blue, inside screen white/blank
this i did find a guide to opening the moto up .
http://themotoguide.com/razrdisassembly.php
hope this helps you out.
riz.
Nov 12, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Apple 24" iMac Desktop Logo
136 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
