Question about Bosch Washing Machines
Washer leaking on emtying it is a bosch2473 from the drum
    Brigadier General:
  • 3,513 Answers
Hi
Please check this links bellow …
http://www.technicianbrian.com/2009/05/bosch-washer-leaking-water.html
http://www.boschrepair.co.uk/tag/washing-machine/
Let us know if you have something more to ask else please accept the solution.
Thanks for contacting fixya.com
Posted on Aug 24, 2010
Washer leaks on floor from drum top while centrifugating
Good Morning Andres,
I see that you are having trouble with your Frigidaire laundry center, model# FEX831F, and the washer leaking water from the drum top onto the floor. It could possibly be that your washer door is either not closed all the way or is not sealing properly. I suggest checking to make sure that the door is closed all the way. If it is, I would check the seal, and see if there anything that might be damaged and allowing water to leak from the drum top. If you are unable to find anything that might be allowing the water to leak out, I suggest contacting your local authorized technician. They will be able to diagnose your appliance and see why you are having water leak from the drum top. Hope this is helpful.
-Best Regards-
WP
Apr 22, 2014 | Frigidaire FEX831F Top Load Stacked Washer...
My washer makes alound grindin noise wen trying to empty
1) most Noises coming from washing machines coming during the cycles of SPIN .Clothes load can be un-balance. Stop the machine and balance the clothes.Start again, and repeat the step if necessary.
God bless you
Jun 28, 2012 | Washing Machines
My Samsung is leaking water under the washer.Its leaking from under where the drum is.It fault gasket leak from the drum.The washer is one year and 4 month old.Is there a guarantee on it.Samsung say...
I never heard of a washer gasket of drum....Just try to look closer new as your machine is usually something that cld be easily sorted, check if pipes aren' loose or broken.
Jan 09, 2018 | Samsung WF337AA Front Load Washer
Internal leak on a kenmore top load washer
Yes, very likely is a bad water inlet valve allowing water to leak past it into the drum. Really not a difficult repair with a little help.
Go here for:
Kenmore Washing Machine Parts
RepairClinic.com
appliance parts, help & more
Sep 13, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machiene drum won't turn
it sounds like you've got an item of clothing jammed between the inner and outer drum
Jun 22, 2009 | Indesit W 123 Front Load Washer
Water leaking underneath when drying,whats the problem
Hello!
If leaks only on drying, then it might be the condensing system, maybe the fittings of the condenser on the drum got loosed. Remove the back panel and inspect after leaks on the left side where the condenser is.
Feb 27, 2018 | Washing Machines
Maytag Washer leaking from front
If I remember correctly, you need to remove the drum to get at the bolt that you are talking about. There is a rubber washer that provides the seal. The locking collar on the hub is Left hand thread. If you work at it you can get it loose.
Jul 12, 2008 | Maytag MAV2755A Top Load Washer
Washing Machines Logo
21 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
