Question about Toshiba 27A33 27" TV
Audio trouble with my tv
I own a toshiba color tv, model # 27A33. On some channels there is no sound when tv procrams are on but not while commercials are on. i went to the tv menu under audio but it dosent give me the option of turning off sap. what is the problem and how can i fix it?
  • Anonymous Mar 22, 2009
    Three channnels display Stereo SAP.Two are okay but one(#21) is silent.Reset has no effect....fine tuning??? How?
    Champion:
  • 252 Answers
Use your remote . manually fine tune your tv.
Posted on Oct 02, 2008
Press the "reset" button on your toshiba remote. it worked for me!
Posted on Nov 11, 2008
How do I scan for channels for antenna on a Toshiba 27a33 without an original remote? I only get ch. 3,4, inputs 1,2, and color stream.
Without its original remote control, you can't. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
Feb 20, 2015 | Toshiba 27A33 27" TV
Toshiba 27A33. I can't find the manual channel button. Only the on/off button and volume buttons...
assumming your remote has a keypad with a bunch of numbers 1,2,3, etc those are the channels you press the combination of the channel number you want and press enter...sscrolling up and down thru the channels is probablymore what you want, and that should be located by a set of signs wghich has horizontal or vertical arrows right nex to each other...
Sep 09, 2014 | Toshiba 27A33 27" TV
Prices for components of color television
They can go from a few cents to over $50  - all depends on the component and the model of the tv.
Jun 28, 2010 | Toshiba 27A33 27" TV
I have a toshiba standard tv 27A33. it has one
This television uses a feature called a V-Chip which allows parental control and consequently blocks channels of your choice. This set is approximately 7 years old and the owners manual is no longer available on line. You can over ride any blocked channel by entering the menu, select parental controls and enter the "secret" code. How one channel got blocked is a mystery. I suspect someone was exploring it's features when they accidentally blocked a channel. Normally the system control works flawlessly and if you have no other symptoms you need to reset that channel. That info is in the owners manual that came with your set.
Mar 30, 2010 | Toshiba 27A33 27" TV
I have a sony trintitron model kv20fs12 that i just bought used.A few of the channels have audio only during commercials. When the show comes on it has no sound. One channel has background noise such as...
Check your TV's audio settings and make sure it's not set for SAP (second audio program). You'll probably find it's turned on. On many channels or programs you won't notice anything since the broadcast doesn't include a SAP signal. But if the signal's there, the set switches to that sound channel and you have the trouble you describe.
The problem you might run into is that you often need the original remote to control the audio settings. I don't remember for sure if your Sony model has front-panel menu control. I believe that series does, though. (The remotes included with most TV sets usually have a single button to control SAP, which is often how the settings get changed in the first place. Someone hits the button and doesn't know it.)
Hope this takes of your mystery sound! Thanks for using Fixya.
Feb 14, 2010 | Sony FD Trinitron WEGA KV-20FS120 20" TV
We have cable, but only get 13 channels on this toshiba
Check in the menu options and switch one of the settings from TV to Cable. Sorry I can't remember exactly what it's called but if you find something with TV / Cable and switch it to Cable - you should be able to go over channel 13.
May 26, 2009 | Toshiba 27A33 27" TV
I bought the gemini universal remote control G401S but it didn't work when i tried the the brand search it changes only 2 channels can yo plzzzzzzz help me?
Hello
I have found Gemini's list of codes for a different model remote. I could not find your model but the models I found are identical to each other with their codes, so trying these should be worth a shot. Here are toshiba's codes:
TOSHIBA 140,200,210,220,440
Good Luck
Hope this helps and please don't forget to rate
-Chris
May 04, 2009 | Toshiba 27A33 27" TV
When I connect a DVD player, there is no audio or video.
Select "Video 1",or whichever input you have connected the player to. It is not available on "channel...accordianman
Nov 12, 2008 | Toshiba 27A33 27" TV
1992 TOSHIBA TV. MODEL NO. CF2772B
could be the audio chip going bad or cold solder inside the tv
Aug 06, 2008 | Toshiba 27A33 27" TV
Toshiba 27A33 27" TV Logo
321 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
