Question about KitchenAid KSRS25IL Side by Side Refrigerator
Frezer temp @ -5 ,referagerator @ 47 degrees. how can I get it colder /
    President:
  • 3,773 Answers
Determine if freezer fan is running. If not thats the problem.
Remove the back panel in freezer to access the fan.
Check for frost buildup on back bottom of freezer panel
Sometimes this is a auto defrost problem or ice buildup on
freezer coils.
If ice on the freezer coils is restricting air to the ref.
To confirm ice you will need to turn off ref. for 24 hrs and let the ice melt OR remove back panel in the freezer and visually look for ice in the evaporator coils. if it works fine when you turn it on take your mod number to a local Appliance parts store and they will sell and instruct how to fix the Defrost system
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 24, 2010
CWC-1600 cools constantly
More than likely, the thermostat on the unit is going bad. If the coils haven't been cleaned recently, then I suggest that you unplug the unit, clean it well and then cycle it back on. If it continues, then the thermostat that's located within the unit is going bad. Please refer to the owners manual for proper service and maintenance for your unit. https://www.appliancefactoryparts.com/content/pdfs/140265-1.pdf
Feb 04, 2017 | Heating & Cooling
After power interruption we find the temp is sitting at 48 degrees fridge side and 19 degrees on the freezer side.
After about 24 hours your temps should be close to zero in freezer and about 37 in refrigerator. If not check position of thermostat control and turn clockwise for colder temps if necessary.
Mar 16, 2016 | GE PSC23SGRSS Side by Side Refrigerator
Hi my botton frezer no working the compressor its hot
Compressors are normally 100-120 degrees when being cooled by a condenser fan motor. If there is no fan motor near the compressor then it can run up to 180 degrees, so the compressor temp by itself doesnt mean much. You can take an ampmeter and clamp it around one of the wires to the compressor to see if it is running, drawing anywhere from 1-2.5 amps or trying to start, in which case it may draw up to 20 amps every 3-5 minutes.
Oct 05, 2010 | Amana ARB8057CSL Bottom Freezer...
Temp Control
Hi!!
The higher the number, the colder the setting.
Rate this post, Good Day!!
Apr 26, 2010 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Looking for ideal freezer temp
For most freezer sections of a refrigerator, zero degrees F is ideal. -2 to +5 range is acceptable, but the warmer temps will reduce icemaker productivity, while colder temps might make that ice cream as hard as bedrock.
Apr 02, 2010 | GE GSS25SGMBS Side by Side Refrigerator
Frezer temp is 20 deg. fridge temp is 47 deg.
Remove the freezer shelves and bins. Remove the freezer back panel to access the fan motor.
May 26, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Icemaker is not making ice
is there water in your icemaker.if so then its up to icemaker to do its part.frezer temps must be near 0 degrees.if no water in icemaker is the line in the back of the frezer frozen [top back where water passes thru frezer wall into frezer section.if its not frozen,am i then getting voltage to the water valve when the ice maker cycles.if not then icemaker is bad.if your ice bucket is on the door[whirlpool,kenmore]there are boards in the frezer section that can fail.i know that dosen't tell you what the problem is .but it does give you somthing to go on with.God bless ,tom
Jan 11, 2009 | Refrigerators
Wine cooler temperature control
toatlly normal operation, realize that the machine needs to shut off/ on to regualte temp, new electronic thermistors are sensitive enought to detect miute temp flux, i wouldnt be concerned about this
Feb 23, 2008 | Refrigerators
Sub-Zero 650/F
get into diagnostic mode by pressing and holding either colder key, then pressing on/off. You can use the colder key to scroll through 5 reading labeled fe, re, f, and r  look at the re temp. is it higher than 38? if it is you probably have a freon leak in the evaporater refridgerator (call sub zero...they will completely pay for this issue, even past the 5 year warranty)  If the temp reads really low (like 10 on re or something) you probably have a bad fan or fan switch in the fridge portion. this unit has seperate compressors and freon for the fridge and freezer..hence the lack of problems in the freezer. hope this helps!
Oct 24, 2007 | Sub-Zero 650 / O Bottom Freezer...
KitchenAid KSRS25IL Side by Side Refrigerator Logo
118 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
