Projector projects image upside down - Office Equipment & Supplies
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 269 Answers
Go into the projector's menu, then into the picture settings and deselect ceiling.
Posted on Aug 24, 2010
Why does the image project upside down
Hello, Try pushing the CTRL ALT and UP buttons at the same time.
Aug 25, 2014 | Panasonic PT-AE1000U LCD Projector
MY EPSOM PROJECTOR IMAGE IS UPSIDE DOWN. WHAT DO I DO?
Hi, Your projector is probably set for ceiling mount which will project an upside down image because the projector is normally mounted upside down when installed on the ceiling. Go into the menu and select extended then select projection then select front. That should return the image to right side up.
Aug 22, 2011 | Epson EX30 LCD Projector
I have a Panasonic PT-LM2U; when it is turned on, everything powers up fine but the image projected is upside down. I've looked through the menu but didn't see an option for flipping or rotating...
Every modern projector that I have seen has a setting that will allow you to flip the image for this.If you purchased it used it was probably configured as a ceiling mount in an upside down orientation or rear projection onto a translucent screen. (The projection method can be set from the "OPTION2" menu. in a Model LM1 so it should be similar. http://service.us.panasonic.com/OPERMANPDF/PTLM1U.PDF
If yours doesn't have this option, then you'll have to use mounts that require the projector to be upside down.
Jul 18, 2011 | Panasonic PT-LM2U Multimedia Projector
My projectors image is upside down. how do i fix
Go to Menu> Extended> Projection> select Front ( to project from the front of the screen ).Front/Ceiling ( If the projector is mounted upside-down from the ceiling ). Rear ( to project from behind onto a transparent screen ).Rear/Ceiling ( to project from behind when the projector is mounted upside-down from the ceiling ).
Apr 11, 2010 | Epson EX30 LCD Projector
Upside down images
the projector will project 4 image configurations: front, rear, ceiling front, and ceiling rear. go into the menu, under settings, and change it from ceiling to front.
Jan 07, 2010 | InFocus In2102 Projector
Mounting the Projector from the Ceiling
Projectors, in general want to project the bottom of the image 1 foot above the lens at a typical range. When mounted upside down, they project the top of the image 1 foot below the center of the lens. If you don't want to turn the projector over, you'll have to change the angle and probably go to the extreme on the keystone correction.
Aug 05, 2009 | Dell 1200MP DLP Projector
Upside down image
These projectors are designed to be mounted upside down. Think of a projector that is ceiling mounted in a classroom. Change this setting in Menu - Advanced Menu - Setup - Mirror.
Jun 09, 2009 | Hitachi CP-X445 LCD Projector
Lcd projector projects images upside down???
if you go through the projectors setup menu you will find the option to invert / flip and rotate image adjust as required
REgards Al "alastech"
May 29, 2009 | Epson PowerLite 62c Multimedia Projector
Reverse Image
find the menu for saving the settings, for sure there is a menu saving all your desired settings. good luck!
Feb 11, 2007 | Mitsubishi X490U Multimedia Projector
757 people viewed this question
k24674
jasbo
jasbo
