Question about HP Photosmart 2710 All-In-One InkJet Printer
I would like to know how I can send a fax from my photosmart 2710 printer?
  • HP Master
  • 2,517 Answers
Yes you can send fax from this I would like to know - 22656513.jpg HP Photosmart 2710
Posted on Aug 24, 2010
    Scholar:
  • 122 Answers
Hello mandyd_60, Here is how to send a fax using your printer:
  1. Make sure the printer is plugged into an active phone line in your home.
  2. Place the original documents to fax directly onto the glass face down.
  3. Enter the fax number using the keypad.
  4. Press "Start Fax Black" or "Start Fax Color".
  5. Press 1 to "Fax Original From the Scanner Glass"
Please post a reply with any problems you have faxing. Thank you for using FixYa!
Edward
2 Suggested Answers
  • 6 Answers
SOURCE: The printer will not scann to the computer
Are you able to print? I suspect so. If not your probably looking at a bad cable or corrupt windows drivers.
The director software uses it's own system to talk to the printer via scan / fax though printing is controlled by windows itself. Since scan and fax are the same function to the printer, essentially i would start by re-installing the director software.
1. Remove it via add/remove programs, don't reinstall over. It may work but you'll likely just waste time, you want all it's files gone and replaced with new ones.
2. If that has no effect remove the printer from Control Panel > Printers. Also remove the scanner device from Control Panel > System > Hardware > Device Manager >
3. Reboot, windows doesn't really remove things till you shut it off.
4. Install the director software again, hook up the printer when asked.
Again:
If you can print at all communciation with the device is perfectly fine from a hardware perspective.
If you can fax without the computer then your scanner and such is fine from a hardwware perspective.
So your problem is simple software, either windows devices install or hp director. Both simple to remove and re-input.
It's very
Posted on Nov 09, 2007
HP Photosmart 2710 Scaning software
The software for the HP Photosmart 2710 All-In-One InkJet Printer can be found at
http://www.hp.com/#Product
After arriving at the site, click on the subheading "Support & Drivers", then follow the 2 steps
listed to obtain the needed software.
Jan 22, 2011 | HP Photosmart 2710 All-In-One InkJet...
Hi, When I try to copy a document I keep seeing the send fax box only, Thanks
Hi
push copy button first
to make your printer work as a copier
Pls vote me to keep us alive
Nov 20, 2010 | HP Photosmart 2710 All-In-One InkJet...
How do I send a fax on the hp 2710?
  1. Click Start , point to All Programs , point to Accessories , and then click Paint .
  2. Click File , and then click From Scanner or Camera .
  3. Make any desired setting changes.
  4. Click Scan .
Apr 06, 2010 | HP Photosmart 2710 All-In-One InkJet...
Help connecting HP 2710 wireless to my PowerBook G4
No, there is no fee. I will help you figure it out. However looking thru the HP manuals is the HP 2710 your printer model number or your notebook? I found manuals on notebook.
Don't forget to rate this solution before you log out.
Jan 26, 2009 | HP Photosmart 2710 All-In-One InkJet...
Paper mismatch when recieving a fax
I understand that while receving faxes, you are experiencing with paper mismatch error message.
Please select the paper type as plain paper fromt the front panel of the All-in-One and try to recevie faxes.
Mar 27, 2008 | HP Photosmart 2710 All-In-One InkJet...
HP 2710 All in One Printer/Scanner/FAX and Vista
There are two models of printers starting with the number indicated. Both have Vista drivers and both have documented vista installation issues. Using the following link
HP Photosmart 2710
Select the correct model
Under software and downloads you will find the software necessary.
Below that you will see a link for Trouble Shooting software ...
Click it then Windows Vista and you will see two potential installation issues you may encounter.
Dec 17, 2007 | HP Photosmart 2710 All-In-One InkJet...
Again:
It's very
Nov 09, 2007 | HP Photosmart 2710 All-In-One InkJet...
HP Photosmart 2710 All-In-One InkJet Printer Logo
62 people viewed this question
Ben Johnson
