Question about Nokia 7610
My lock code wont work.
I turned my lock code on, i know my lock code, but my phone isn't accepting my numbers and i cant unlock it. please help me asap thanks....
  • pkp031 May 17, 2008
    i have entered invalide lock code more than 10 times.
  • umairansar Oct 13, 2008
    i donot know the lock number
Here's my imei number for my 2100 backup phone . please unlock it . i forgot my security code . imei#351344306612315 thanks
Posted on Oct 13, 2008
  • 4,102 Answers
Hi, the problem is if you have entered the code wrong more than 5 times then the phone is hardlocked and will need unlocking software and lead ok.
Also is the code asked as soon as you switch the phone on if it is then i might be able to help you as every phone has a master code but this code wont work if its been entered wrong 5 times.
If you have not tried to enter any code more that 5 times then the master code should unlock your phone for you ok.
What i need is your imei number its on back of the phone under the battery and looks like 12345/12/123456/12 its 15 numbers long ok.
I need this as every single phone has a unique master code based on the imei number.
So as long as you have not tried entering more than 5 wrong guesses then the master code will work ok
Posted on May 06, 2008
Unlock code for samsung propel pro SGH-I627
TEMPORARY UNLOCK: Put a non-accepted SIM Card and turn it on. Type *#9998*3323#. Press Exit. You will get a new menu. Select Malloc Fail.
In newer phones: #*7337#
If you want to unlock your phone put a sim from another company then type *#9998*3323# it will reset your phone. Push exit and then push 7, it will reset again. Put your other sim in and it will say sim lock, type in 00000000 then it should be unlocked. Type in *0141# then the green call batton and it's unlocked to all networks. This code may not work on the older phones and some of the newer phones. If it doesn't work you will have to reset your phone without a sim in it by typing *#2767*2878# or *#9998*3855# (not tested)
Type *#9998*627837793# Go to the 'my parameters' and there you will find new menu where you can unlock phone.(not tested-for samsung C100) To unlock a Samsung turn the phone off take the sim card and type the following code *#pw+15853649247w# .
Nov 05, 2009 | Samsung Propel Pro SGH-i627 Cell Phone
try this code 12345 if its not working u shud service that phone tell them plz reset my phone code its very cheap!!
plz do rate this post as good as u can so we can help others
Oct 18, 2008 | Nokia 7610
Nokia 6500 slide help i need restriction code
PLEASE READ FULL INSTRUCTIONS BEFORE DOING ANYTHING
TRY WITH NO SIM CARD IN THE PHONE
Doing this is at your own risk!
Every code unlocks a certain lock. Code number 7 usually unlocks them all but some phones are 'buggy' and will not accept code 7 at first then use code 1.
Usually you only have to use code 1 or code 7.
#pw+xxxxxxxxxxxxxxx+1#
1. Press ( # ) on your phone
2. To get ( p ) press ( * ) 3 times within 1sec
3. To get ( w ) press ( * ) 4 times within 1sec
4. To get ( + ) press ( * ) 2 times within1sec
5. Enter the 15 digit code
6. To get ( + ) press ( * ) 2 times within 1sec
7. Enter code number
8. Press ( # ) on your phone
Now your phone is unlocked!
If your phone isn?t unlocked after code 1 or code 7 then you have either entered the wrong IMEI or Network. Sometimes there could also be a problem with newer software versions. Then you can try another 'Boxserial' Remember! You have only five tries to enter the right code. After that you will need a cable to unlock your phone. So please, be aware
Phone type: DCT4
IMEI: 352027025104628
Model: 6500
#pw+319926630701132+1#
#pw+702310427045122+2#
#pw+754840072200550+3#
#pw+093433717136641+4#
#pw+199064315752575+5#
#pw+286305406405613+6#
#pw+307016424512121+7#
There is 4 locks on a Nokia DCT4 phone.
Lock 1: MCC+MNC (Network och landsspecific)
Lock 2: GID1 lås (SIM-card typ)
Lock 3: GID2 lås (SIM-card typ)
Lock 4: MSIN lås (SIM-card specific lock)
The generated codes open up one or several locks.
Code 1 open lock 1
Code 2 open lock 2
Code 3 open lock 3
Code 4 open lock 4
Code 5 open lock 1 and lock 2
Code 6 open lock 1 lock 2 and lock 3
Code 7 open lock 1 lock 2, lock 3 and lock 4
Let me know if you have any problem follow these instructions and you should be ok.
I think it needs to be done with no sim card in the phone remember you only get 5 goes after this if its still not unlocked then the only other option is with a lead and unlocking software.
This should solve your problem let me know how you get on ok
This is done at your own risk!
Aug 02, 2008 | Nokia 6500 Slide Cellular Phone
I would like unlock code so my samsung SGH-X530 accepts any sim please
1. remove your simcard
2. type *2767*3855# ALL DATA WILL BE LOST.
If the phone is locked with firmware then the code wont work.
let me know if it works.
Mar 28, 2008 | Samsung SGH-E370 Cellular Phone
Phone and sim locked
you can unlock your phone (ie allow it to accept SIM cards from any network) using the ''full reset'' code - *2767*3855#.
Hope this helps
Mar 03, 2008 | Samsung SGH-D900 Cellular Phone
Forgot my lock code for N73
you need to have a master reset code to reset all the settings. I do have an unlocker for this. if you want just give me the IMEI code and I could process it for you FREE.
Feb 26, 2008 | Nokia N73 Cellular Phone
I need the password reset for my motorola q
Hi i can help you but the problem you have is if you have entered the code wrong 5 times then no code will unlock your phone the code i can give you is for your phone only and wont work in other nokia phones this code will reset the security code to what it was new usuall 12345 or 1234 or 0000 depending on the network of phone new.
This code will turn the security code off giving you acess to the phone if you need to put a security code on the phone after removing it then you can do this.
also if you forget the code again keep the code i give you as this is the code for your phone.
For me to get you the code i need your imei number its located on back of phone under the battery it looks like 123456/12/1234567 it should be 15 numbers long once i have this i can use a nokia calculater and work out your master code this can only be done using the imei number as each phone has a different imei number so this code only works on your phone and imei number.
A soon as you give me this code i can get your master code for you ok
Let me know speak soon
Feb 20, 2008 | Nokia 6133 Cellular Phone
Phone locked
okay, well you cant have an "unlock code" because the unlocker will need to know your imei etc, i cant unlock, but look for a backstreet unlocker, they are crawling everywhere!! they know exactly what to do. some can be done over the internet, you meet them in a specific place etc. they usually wont cost more the £10 or $20
hope this helps
Dec 05, 2007 | Nokia N95 Cellular Phone
Forget the phone lock code
hey dont spend any money......i will just solve it.....
just give me your mobile no IMEI no ,just check your mobile bill ,you will definitely find your IMEI no on it..just provide me your IMEI no and i will give you unlock code...........
low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not
dilipbagdi
Dec 02, 2007 | Nokia N73 Cellular Phone
Forgot SIM lock
i forget my sim lock number mobile no 3207647710
Oct 12, 2007 | Samsung SGH-D500 Cellular Phone
Nokia 7610 Logo
133 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
