Question about General Electric Refrigerators
My G E refrigerator is not cooling. I is 60 degrees inside. The freezer part is working fine as far as freezing but the motor is running all the time and there is no cool air running into the refrigerator part.
    President:
  • 3,773 Answers
Sounds like a defrost problem. remove back freezer panel and look for ice on coils which restricts air to the Ref.
Take your mod number to an appliance parts store and they will sell the parts to fix the defrost system. Most all parts are in behind freezer Panel at the coils.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 24, 2010
Hi, I have a Zanussi ZBB28440SA integrated fridge freezer, the fridge section is no longer cooling yet the freezer seems fine? Any help would be great!
unsure as to what problem might be , but refrigerators at 16 degrees would be freezing things solid here in the US if you are suggesting the temp is in centigrade them perhaps the damper motor controller has failed on it and you need to seek professional help to replace it
Dec 31, 2017 | Zanussi Refrigerators
Amana ASD2620HRB Side-by-Side freezer running, but not freezing. What could cause this?
What is running? The important motor is the compressor - the one that works with the refrigerant to supply cooling. If it is not running you can check the start relay/capacitor. If they are good, make sure that electricity is reaching the motor windings. If the thermostat stays open, the compressor will not be activated.
If compressor is running and if there is ice buildup on the evaporator behind the back panel, then the self defrost mechanism is not working - could be you have an open heater coil. If you completely defrost the refrig for a day and then plug back in, if it works fine, then it is definitely ice buildup which serves as an insulator and prevents cold air from reaching the refrigerator portion.
Aug 03, 2017 | Amana Refrigerators
Whirlpool Model # ETClCHMXK009... Freezer is freezing but refrigerator is not cooling well...
Hi
If refrigerator is not cooling properly it can be due to a defrost timer, which is causing the fridge to go into defrost cycle. Usually it takes 45-60 minutes for refrigerator to come out of defrost cycle. If the timer is bad then it will not come out of defrost cycle and can result in this kind of issues. It can also occur due to defrost thermostat, it allows current to pass through it at temperatures of 20 to 30 degrees Fahrenheit and prevents current from passing through it at 40 to 60 degrees. This is difficult to test, though, because it takes a prolonged, very-cold temperature to turn it on. The defrost thermostat is snapped onto the top portion of the evaporator. The thermostat sends temperature information to the processor. The defrost heater must be replaced when replacing the thermostat.
1. Remove the lower fan duct work from the evaporator cover.
2. Remove the 1/4-in. evaporator cover screws and remove the evaporator cover.
3. Disconnect the defrost thermostat wiring connector.
4. Remove the defrost thermostat from the evaporator.
Hope this helps...please post back for further assistance.
Daniel
Jul 17, 2011 | Whirlpool Refrigerators
Freezer works but fridge doesn't stay cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 16, 2010 | Maytag MSD2756G Side by Side Refrigerator
The refrigerator compartment not cooling, freezer is ok so far
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
469d
Jun 03, 2010 | Gladiator 19 cu. ft. Chillerator Garage...
Refrigerator not cooling properly
evap. coil could possible be frosting up due to a defrost problem, this would keep the evap. fan from blowing air into ref. section. it also could be a bad evap. fan motor or it could be that the ref. inside light bulb could be staying on due to a bad light switch ,you would be surprisedhow much heat a 40 watt bulb produces
May 07, 2009 | Kenmore 64802 Top Freezer Refrigerator
Kenmore Side by Side Refrigerator too cold
On a fridge freezer only the fridge temperature is monitored. In a cold location the fridge might not even need cooling and the freezer would get too warm but the thing won't care.
If the fridge sensor sees it as too warm then it will keep the motor running and the first thing to get really cold is the freezer.
Remember the freezing part is not temperature controlled ion a fridgefreezer.
Apr 28, 2017 | Refrigerators
Frezzer is fine but fridge is warm
See if cold air is coming out of the air diffuser top-back freezer side of fridge. A common problem is a bad air diffuser assembly. Sometimes it may freeze closed and break when it tries to cycle. The freezer usually works fine.
Aug 05, 2007 | Kenmore 53602 / 53604 / 53609 Side by Side...
Refrigerators Logo
54 people viewed this question
Top General Electric Refrigerators Experts
Van Allen II
Van Allen II
Darrell
Day Coker
Are you a General Electric Refrigerator Expert? Answer questions, earn points and help others
