Question about Kenmore Washing Machines
Hi, I have a series 80 washing machine and the spin cycle will not work. We smelt a burning smell and then the the spin cycle stopped working. I hear the motor turning but no connection to the spin. Is it the clutch? Thanks for your help. Neil
  • 1 more comment
  • sellors5 Aug 25, 2010
    Hi, I took the motor off and the coupler is good. I'm thinking clutch. How do I remove the trani. I removed the 3 bolts but it is reluctant to come off...
    Hi I took the motor offr and the coupler is good. How do I access the clutch? Thanks Neil
    I changed the clutch and it's all good. I laid the washer on the floor (before I read your comment) but it seems okay. What was the issue with it lying flat? Thanks for your help. Neil
  • 5,911 Answers
If this is a Whirlpool manufactured TOP LOADER (such as Estate, Roper and Kenmore), a no spin problem can have several causes. Most commonly, this is caused by either a lid switch malfunction or a broken motor coupling. The following link explains how you can diagnose the problem yourself and repair:
http://www.fixya.com/support/r3965207-whirlpool_top_loader_no_spin_problem
From the symptoms you describe, it sounds like you may have a broken motor coupling.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you may need. If you do not wish to order parts on line, use the part numbers from the Sears website and go to your nearest appliance parts retailer. Most of these parts are commonly sold as part of their in-store inventory.
Read through the information provided. If you have any questions, please post back with your complete MODEL NUMBER and let me know. I hope this is helpful to you.
Posted on Aug 24, 2010
  • 530 Answers
More than likley you have a broken drive coupler
tilt unit back and lean against the wall you will see the pump attatched the motor and attached to one side of the motor is the coupler and the other side is the transmission where the other side of the coupler sits. turn the power off first and take the pump off
then the motor
there are a total of 4 clips you will have to remove and possible 2 screws 5/16
always check the coupler first
could be your clutch but start here first and let me know what you find
part number for the coupler 285753a
  • 2 more comments
  • erica graber Aug 25, 2010
    you have to remove the agetator first trany is screwed into it.
    The clutch sits on top of trany
    sometimes oil gets on it and makes it slip
    you can take the inside out of the clutch and clean and dry and maybe get a peice of light weight sand paper and scruff up the pads
    try that and see what happens
    it is possible that your transmission is stuck in a nuetral drain
    when you get the transmission down
    turn the coupler clockwise about 6 times around
    then turn counterclockwise about six times
    in one direction i am not sure but it should spin the clutch
    if the clutch does not spin by turning the transmission shaft
    you have a bad transmission
    first you have to take the cap off the agetator to remove the bolt.
    make sure you put the 3 bolts back in that hold the transmission because once you remove the agetator it will fall to the ground.
    the transmission shaft is really long probably 2 feet or so.
    I never tip the washer all the way on the floor because if you do it can cause another issue. lean against the wall and have someone help you hold the cabinet if you have too.
    let me lnow what you find
    there is a plate that is triangular that just sits in there and sometimes by lying it flat will make that plate go out of alignment. which will cause the unit to go out of balance when you put it into spin. but if everything is good. congrats on the fix
Kenmore 80 series makes buzzing noise but won't drain or spin, smells like burning if left on spin cycle.
That sound a lot to me like yall have something inside the pump. Over the years I have found all kind of things from ladies undergarments to shoes strings. themobilian_1938.jpg
Video pump replacement:
Service manual
Mar 16, 2011 | Washing Machines
My washer was working fine and then it just stopped and smelt like it was burning.....if I try to spin the basin manually it squeeks and sounds like metal on metal. its a kenmore 80 series
If it was me I would remove the outer case and observe the washer while doing a load to determine where that noise was coming from.
I have some repair photos HERE
Apr 08, 2010 | Kenmore 24032\24036 Top Load Washer
Spin cycle not working. smells like motor may
Open the back door and check the motor body for the heat. If so check whether the drum is freely rotating.
Then check the motor.
Apr 07, 2010 | Maytag Legacy Series Top Load Washer
Washer won't spin
Try a different spin cycle on another setting if it still doest work try removeing the clothes and changing it to a normal wash cycle. If no try unplugging it for a minute or 2 and then back in hopefully it resets and if still no movement on the unit at all you may have overloaded it causing the motor to wear prematuraly and burn up. This is very common with overloading.
Aug 06, 2009 | Whirlpool LTE5243D Top Load Stacked...
Washing machine spins slowly and smells of burning rubber
The belt could be worn and will be slipping on the pullys, as it spins up the rubber , rubs against the pullys and that is what creats the burning rubber smell, the belt needs replacing.
regards jonno
Apr 21, 2009 | GE WBSR3140DW Top Load Washer
Kenmore washer 80 series misses spin during wash.
You may need to replace the motor coupling between the pump and motor...
Apr 07, 2009 | Kenmore Washing Machines
Kenmore 80 series
sounds like your control switch needs replacing.
Apr 15, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machine Stopped Working
Hi Beth, sounds like you broke a belt. You can verify this by pulling the washer away from the wall and tipping it back to look underneith. Should have two belts, pump and drive. The part numbers are 211124 pump and 211125 drive. Catriver, post back.
Aug 02, 2006 | Maytag Dependable Care LAT9706
Washing Machines Logo
Sal DeAngelo
fordexpert
Ed Mac
