Question about Panasonic AG-HVX200 Mini DV Digital Camcorder
My HVX 200 will not switch on. Totally dead- tried charged batteries that I know are working as they power other cameras. No reaction. It will not switch on or eject. Is this a fuse problem? On the circuit diagram I cannot see any fuses. Maybe a link has burned out. Any info woule be grateful. Also whether it is a common defect.
  • 3 Answers
There is a fuse on the power board that could have gone faulty, or the power board itself.
Posted on Jan 31, 2011
CAMERA WILL NOT POWER UP EVEN WITH FULLY CHARGED BATTRIES
Try non-rechargeable batteries, and try testing your rechargeable batteries because they do wear out.
Sep 19, 2014 | Cameras
Nikon cool pics totally dead
The battery is most probably defect. and then,
The manual says:
Battery is exhausted.
When connecting to an electrical outlet using a Charging AC Adapter, the camera cannot be turned on.
  • Confirm all connections.
  • Off is selected for Charge by computer in the setup menu.
  • When charging by connecting the camera to a computer, battery charging stops when the camera is turned off.
  • When charging by connecting the camera to a computer, battery charging stops if the computer is suspended (sleeping), and the camera may turn off.
  • Depending upon computer specifications, settings, and status, it may be impossible to charge the battery inserted into the camera via computer connection.
So even when you think the battery is charged, it still can be empty. When a rechargeable battery is old, or not often used, it can lose its capacity, not being able to power the equipment it was meant for correctly.
To make sure your battery is good, you could try to check the voltage with a multi meter. The voltage should be slightly higher than the 3,6 Volt that is printed on the battery. like 3,8 Volt, when measured. if it is just a fraction lower than the 3,6 is is not fully charged and it will be much lower when put in a camera, after switching on the camera. When you measure 2,4 Volt, 1,2 Volt or even nothing you can be sure the battery is dead.
Best option then, would be to order a new battery. But if you know someone with a camera that has the same battery that works, ask if you can check your camera still works with a battery that is ok. because when in a rear situation it is you camera that is defective, you can save the mont for a new battery and look out for a new camera, because the batteries are not cheap.
Nov 12, 2013 | Nikon Coolpix S3300
The phone has been dead for more than a year
You cannot usually charge a totally flat battery from the USB port. These are only used to "Top UP" the battery... You need to replace it with a fully charged one,and then us the USB to keep it fully charged.
Jan 29, 2010 | Sony Cyber-shot DSC-T20 Digital Camera
Wont turn on
Well to be3 a 100% about the battery I would replace it with one that you know or is guaranteed to work. Camera batteries can look OK from outside and be completely collapsed inside.
No Charge lights can indicate NO battery and if there is one inside then it is dead and registers as a no battery ( no charge light)
The red light blinks in very low state, but totally discharged it will not blink and wont blink again until loeft on chareger for about 3-4 hrs to overcome the low state.
Jul 25, 2009 | Kodak Easyshare M753 Slim Digital Camera
MY Hvx 200 Is totally Black when I turn it on. the display and playback of my old footage works fine but the picture is totally black. any Ideas When I switch the camera on, the view finder is totally...
You should go into the menu, camera settings and set the evf to on. EVF stands for electronic view finder. This can be set to be on when the lcd is open or closed. CAreful, if the evf is set to on and you point the viewfinder towards the sun, it will burn white marks into the viewfinder and ruin it.
May 09, 2009 | Panasonic AG-HVX200 Mini DV Digital...
Dont know how to use the harddrive with camera
Make sure you turn your other settings in the menu while in camera mode to ext, both or chain. Ext. mode, means pushing record on the camera makes the hard drive record, but not to tape, Both means that both tape and hard drive will record, Chain means when you run out of recording onto tape, the hard drive will automatically start recording as the tape runs out.
Mar 25, 2009 | Panasonic AG-HVX200 Mini DV Digital...
THIS MEANS THAT CAMERA PART HAS A PROBLEM BUT NOT THE PLAYBACK PART.MUST BE A CAMERA BOARD PROBLEM THEN.OR EVEN POWER SUPPLY PROBLEM/ VOLTAGE FEEDING THE CAMERA BOARD FOR EXAMPLE.
Mar 08, 2009 | Panasonic AG-HVX200 Mini DV Digital...
On off button
are the batteries fully charged?
Jan 12, 2008 | HP Photosmart M407 Digital Camera
Panasonic AG-HVX200 Mini DV Digital Camcorder Logo
158 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
