Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
You can turn the washing machine on and it starts shooting out water for just a couple of mins and then it quits. The machine will not do anything.
  • 530 Answers
Does it spin? if no check you lid switch
if it fills for 5 seconds or so and never reaches full and just humming sound heard. check you inlet valve
i would turn each hose off and take them off the back of the washer. get a bucket and put hose in it and turn one on at a time.
do you have good flow comeing out of your house if yes check the screens in the inlet valve. are they clogged with sand? if yes clean them. try these things and let me know how it goes
Posted on Aug 24, 2010
I have aa frigidaire front load washer model LTF2940FE1. We put a pretty big load of towels in this morning. halfway through the cycle the machune made a couple of loud noises, like it was shaking, and...
Never put a large load of anything in, they're quite frankly not designed to work like that for a number of reasons. If the drum is full then water can't circulate properly and your clothes won't get washed as well as they could do.
The machine shut down to prevent damage to itself, try turning it off at the mains for 30 mins, turning it back on and then putting half the load in. This should reset it and stop the shaking.
Jun 24, 2012 | Frigidaire ATF6000ES Front Load Washer
Duet front load washer door locked & will not cont wash cycle
you can use a wet dry shop vac and attach it to the end of the drain hose and remove all the water in the unit this should unlock your door then you can check the drain pump for anything that may be restricting or blocking the drain pump
Jun 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer quit the spin cycle
If the machine will not wash or spin, but will still pump the water out, you probably have a broken coupling which connects the motor to the gearbox. This is a simple job for an experienced tech, and should not be expensive...good luck....Nomess
May 23, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Hi there. my machine suddenly stopped 2 mins
there may be something small that has stopped the pump from draining.use a shop vac and attach it to the end of the drain hose and remove the water.once this is done unplug the unit for a couple of minutes then plug it back in this should open the door.then you need to remove the drain hoses from the pump and see if there is anything stopping the impellar wheel from turning.
Sep 21, 2009 | Washing Machines
Machine fills with water, sits for a couple of minutes, agitates for 15-30 seconds, stops for 3-5 min. agitates for 15-30 secs etc... When rinsing, empties water starts to spin, kicks into high gear for a...
Your motor/clutch combo is on the way out. The motor is overheating and turning off. Cools down and restarts.
You need a new motor/clutch combo or a new washer. I do not recommend another GE.
Jul 07, 2009 | GE Washing Machines
Kenmore washer won't agitate,drain or spin.
What you have here is a broken drive coupling
the part looks like this:
To fix it CLICK HERE
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
Old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Sep 29, 2008 | Washing Machines
Fisher & Paykel Smart Drive 601 - won't turn on
Hi I Have this washing machine (FISHER & PAYKEL Smart drive 601) hasn't been turn on for 4 yrs. now I'm going to use it coz my other machine broke.when I turn it on ,at starting it only distribute a little amount of water then it span the drum slowly.after about 5 mins. The lights of cold and hot keeps blinking and beeping.sounds like an error beeps .The power and all the light button still on except the cold and hot lights keeps blinking then just stop workin. can u help me what the problem could be.
Thanks
Jaf
Jan 17, 2008 | Washing Machines
BOSCH washing Machine WFE 2021
perhaps it is waiting for user to add fabric softener? how it got in this mode?
May 28, 2007 | Bosch WFE 2021 Front Load All-in-One...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
16 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
