I have a Swintec 4600DP calculator. The paper will not feed in correctly. It constantly feeds to one side and then jams.
SOURCE: Non stop paper jams
I had this same problem. I finally noticied that the problem occurred consistently on the right side of the paper feed. I discovered that a little part along the right side of my drum unit (just inside the paper feed area) had disconnected and was loose inside the drum unit itself. Once this little part was placed back into it's rightful place, VOILA! Problem solved! Hope this helps!
Posted on Mar 11, 2008
shmorhay
SOURCE: PAPER FEED
Feeding paper into the Canon P1-DHV requires the nonobvious trick of inserting the paper into the roller area vertically rather than horizontally. Keep the removable cover off while doing this, and start by feeding the paper through the back slot. But rather than continuing to feed the paper horizontally (straight through) make it loop upwards and then downwards into the roller area, forming a sine curve in cross-section. Use the Feed button to advance it. Canon, please use the battery compartment cover as a paper-feed-path diagram in future versions of your product. -- bo@shmorhay.com 30-Mar-2008 17:30 San Diego
Posted on Mar 31, 2008
SOURCE: casio DR-T220
Turns out the incorrect type of paper was being used. The paper needed is the paper that is sensitive to pressure and this paper was not.
Posted on Jul 22, 2008
checkitright
  • 1362 Answers
SOURCE: canon pixma ip3000 paper feed jam
try cleaning the rollers with alcohol, the tires are probably dirty and one side is not gripping the paper.
Posted on Jul 23, 2008
SOURCE: Printer will not feed paper correctly
I had the exact same problem and it was a foreign object (*** end lol). I fiddled about abit then turned the printer upside down, gae it a few taps and it was fine.
Posted on Aug 21, 2008
Clear paper jam
1. Turn ON calculator and set the slide switch P/NP/IP switch to P position.
2. Remove the paper roll from printer.
3. Use a business card and insert into the printer slot
4. press the feed key to feed the business card to clear the paper jam
Jan 19, 2015 | Victor 1260-3 Calculator
Paper will not feed through printer part
cut the paper evenly with scissors before attempting to feed it into the paper entry port. If you just rip it, it will jam or fail to feed.
Nov 06, 2013 | Casio Office Equipment & Supplies
Swintec 8016 / the ribbons jam up
When you load a ribbon there is a black rubber feed roll on the L. side that feeds the ribbon they be come loose on the plastic spindle. It should be replaced but a little pliabond or similal cement mat reattach it. (JUST A LITTLE)
May 13, 2009 | Swintec Office Equipment & Supplies
Remove platen on Swintec 8011 typewriter
I can't remember which models have which features, but some Swintecs have pop out plantens, and some don't. If it is pop out, you will find a plastic V clip in the frame of the typewriter through which the platen shaft passes on both sides of the typewriter and platen. Pay close attention to which side the gear of the platen is situated before removing to make sure you put it back on the same side of the typewriter. Squeeze the V clips and pull the platen up and out. When re-installing, make sure the metal paper table is in correctly by aligning the fingers on each side into their mounting guides, or you will have paper jams, paper feed trouble, and other issues. You can clean the labels out with something that will not leave an oily residue on the paper table, paper feed rollers, or the platen. Re-install the platen by aligning the V clips to the frame on each side, and press them down until they snap into place.
Mar 23, 2009 | Office Equipment & Supplies
Only 8 1/2 by 14 paper jamming at the DADF
Does it feed sometimes, and just jams frequently, or every single page?
Are you sure the paper size in the tray is set correctly? Otherwise for frequent or constant jams when the paper simply stays in the tray, then the feed rollers are likely worn out.
Mar 16, 2009 | Office Equipment & Supplies
The paper will not feed correctly. The Right side is getting jam
First jam a paper on purpose then you will know where the jam is . and you will also know where to find the paper which is under the white cylinder.
Feb 02, 2009 | Canon PIXMA MX310 All-In-One Printer
there were may situation that can help with this trouble,
1- try to see if the trays are seated correctly no bend or twisted
2- try to check the quality of your paper no concave nor convex ( like U or N)
3- clean the feed roller from either side by moistened cloth, ( only on one direction evenly
4- ensure no hindrance on the paper path inside the machine
5- reset the unit once more
let me know if you need some more
Jul 25, 2008 | Office Equipment & Supplies
Swintec SW20 Portable Cash Register Paper feeding
please confirm that paper path is clear from any foregin object droped inside(pins-stapler-small pieces of torn paper).
regarding manual you can buy it on line(it is not free of charge).
Jun 29, 2008 | Office Equipment & Supplies
Register tape
Assuming that you know where the paper gets feed in, I usually use this trick to start a new roll of paper.
First, tear off the end of the new roll so that there isn't any glue stuck on the paper.
Then, fold the tip of the paper like an arrow. (Fold one side to the middle and the other side to the middle so both sides meet in the middle. Looks like >
Then, place the paper into the slot where the paper feeds into in the back. (Paper will get fed under the printer assembly) and then hit the PAPER FEED/ADVANCE button at the same time. If the paper is in the correct slot, the paper should start feeding the paper all the way through.
Hope this helps.
Have a good day.
M =)
Feb 13, 2008 | Sharp EL-2192Rll Calculator
k24674
