Question about Hoover Soft Light Supreme U4262-930 Bagged Upright Vacuum
How do you change the belt on a Hoover Convertible Soft & Light model U4535-930?
reddevil6
  • 1673 Answers
SOURCE: hoover belt replacement
Turn vac. over, remove the buttom plate over the brush roll, then at the bottom edge of the top cover, using a flat blade screwdriver, insert into the slots and pry up to unlock the tabs, then the top cover will come off. Put the belt on the brush roll and feed the belt thru the opening and put stretch it over the motor shaft. Put the top cover back on and push to lock the tabs.
Posted on Jan 29, 2008
wayneard
  • 1901 Answers
SOURCE: hoover upright model u5095-930 belt change
I couldn't find your specific model but this may be similiar to another that you have to position the new belt around the agitator (beater bar) on the bottom of the vacuum, replace the cover, and then turn the vac over and remove the TOP cover to lift the new belt up and place it on the motor shaft/pulley. The new belt may require some effort to pull it over the pulley.
Hope this helps.
Posted on Oct 29, 2008
dragonsthatk
  • 547 Answers
SOURCE: hoover sweeper model U4263-930 belt change
undo screws on bottom of vac take out brush and belt put belt in then manewver brush in
thank you for useing fixya please rate me
Posted on Feb 12, 2009
landsend
  • 1066 Answers
SOURCE: Change belt on a hoover elite, model no. u4671-930
Every Hoover I've had has two screws on the bottom that you remove.  Then you lift off the cover and you pry out the brush roller. The new belt goes with one end on the motor shaft and the other end on the humped roller part on the brush roller.  Good luck it's a bit of a struggle but you can do it.
When you receive advice from this website you have to understand that without the item in front of us, we are only able to provide "a best guess" as to what the problem might be based on you description of the defect.  If you haven't described a clear and precise description of the defect you decrease the chances of an accurate reply.  Thank you.
Posted on Apr 29, 2009
galati2k
  • 281 Answers
SOURCE: hoover elite, model no. u4671-930
in the front on the bottom you will see 2 slots put a small screwdriver in and push up on the clips in the slots and the bottom cover will come off .be careful not to break the clips.just push up on the clip and pull out on the cover at the same time.before you replace the belt clean the old rubber off the motor shaft first ,if you don't the new belt won't last very long
What is the belt part no. for a hoover elite rewind?? model no. UH71009RM
If you look up the Hoover page for the UH71009 (the non-remanufactured Elite Rewind), there are 3 different belt model numbers listed. One part number is simply for a 2 pack of the belts. See http://hoover.com/products/details/uh71009/elite-rewind-bagless-upright/ . Click on the Parts & Accessories tab.
I believe the belt part number is 38528058 , http://hoover.com/parts/details/38528058/sra-r-b-562932001-belt/ .
I hope this helps.
Oct 04, 2015 | Hoover Vacuums
How do I change the belt on the Soft and Light Hoover Model #U4266930 Hoover send the manual through email, but apparent it is gone now...missing on my favorites list . Attempted to request second...
I have same problem, somehow take top all apart, looks like allen screws holding bag container on, remove that, get to screws right underneath top shell, then get to motor pulley from above . be careful not to pull off motor pulley when wrapping other end of belt around brush underneath, or else you'd have to take top all apart again. Good luck.
Jun 13, 2011 | Hoover Soft Light Supreme U4262-930 Bagged...
I need instructions on how to change bag in a Hoover Soft & Light Supreme upright vacuum cleaner. Thank you.
Here is a link that will show you how to change bag (and more).
The model number of manual is not the same as yours but it will work for your machine.
http://www.hoover.com/pdfs/manuals/C1404.pdf
I hope this helps.
Feb 02, 2010 | Hoover Soft Light Supreme U4262-930 Bagged...
Replace belt - how do I get off the interior housing
Rather than try to explain this procedure by typing it, I'll give you a link to an online guide with pictures that show the procedure. You'll see two links on the page regarding belts , look at both and use the one that is closest to your model. Hope this helps.
http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
Aug 21, 2009 | Hoover Soft and Light Supreme U4266-930...
Can't get to motor to connect belt after removing brush cover
I followed the instructions that were supplied @ the FixYa site, to remove the hood. Removing the hood was the problem. Just follow the online users manual pages 22 thru 26. you must spread the hood by the rear wheels to remove. Thank You Very Much. Delano
Jun 29, 2009 | Hoover Soft Light Supreme U4262-930 Bagged...
No suction for u4264-930
This link at the Hoover site is a general manual for the older uprights. It shows how to replace belt etc. Mine is a "Soft & Light" and it worked for me:
Dec 23, 2008 | Hoover Soft Light Supreme U4262-930 Bagged...
How to change belt on hoover soft and light supreme
Turn the machine over so you can see the bottom. If you look carefully at the plate that covers the roller, at the back behind the brush opening on either side, there is a clip that is recessed and you can push it with a flat blade screwdriver as you lift the plate up. This will allow you to take the plate off and remove the roller. Put a new belt around the roller pulley and insert the other end of the belt through the opening in the roller housing of the machine and re-install the roller. once it is installed, rotate the roller by hand to make sure that the belt is not pinched. Replace the bottom plate and rotate the roller again. The belt is running between two guards and it is possible to pinch it and damage it. This is why you rotate the roller by hand, to ensure that it is not pinched.
Now, if you look at the back wheels, on the side of the machine where the hood meets the bottom, there is a clip on either side that you can pry on gently and this will release the back portion of the hood. To release the front portion of the hood, there are similar clips located at the back corners of the bottom plate. Basically, you are prying the hood away from the base of the machine and releasing it. Now, turn the machine over, (back on it's wheels) and lift the hood off the machine. The handle of the machine should be down for this. You will see the belt where it comes through the roller housing and you will have to grab it and pull HARD and stretch it around the motor shaft. Once it is attached, rotate the belt and roller by hand to make sure that everything turns easily. Replace the hood and press the sides gently. You should hear and feel the latch/clips snap into place. If your machine has a height adjustment, there will be an adjustment knob that will have come off when the hood was removed. Replace the knob and you are done.
Feb 02, 2008 | Hoover Soft Light Supreme U4262-930 Bagged...
Hoover Soft Light Supreme U4262-930 Bagged Upright Vacuum Logo
239 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
