Question about Pentair IntelliFlo VS-3050 & VS+SVRS Variable Speed Pump -
Doing new pool install, I have the IntelliFlo VS-3050. My salt chlorine system is the pool pilot digital Nano 220 v . My question is can the salt system be controlled by the timer on the pump if so how. Or does it need to be hooked up to a separate timer.
  • 366 Answers
I don't believe an intelliflo can control a salt cell. You'll probably have to use a timer or control system to control them separately.
Posted on Aug 25, 2010
Why does my intelliflo pool pump on/off switch shows yellow led instead of green
make sure wiring correct for 120 volt vs 220 volt if ok check intake union see if leak
May 20, 2014 | Pentair IntelliFlo VS-3050 & VS+SVRS...
I have a 38 month old VS-3050 and it cuts out every 10-15 minutes and comes back on in 30 seconds. no flow blockage and the filter is clean, I even reset the panel.
I don't have a solution, but I have experienced the same thing on the Pentair Whisperflo. It was installed when my customer's pool was built in August of 2009. (Your pump is basically a smart Whisperflo.)
The motors are not alike.The whisperflows have been out for over 15 years
Does your pump run on an Intelletouch power center?. I have had had some trouble with the system from the get go, and the Intellechlor chlorine generator had to be disabled out right because it never ran correctly.
If you have the IT system I would suspect that it may be a bug, as my pump is doing the exact same thing, on a system right about the same age as yours (if you have one). Multiple resets and reprograms have had no effect.
If you do not have the IT system I guess it may be possible that the timing programming in the Intelleflo is the same as in the Intelletouch power center, having the same bug. Wish I could be of more help.
Jan 15, 2013 | Pentair IntelliFlo VS-3050 & VS+SVRS...
Pentair IntelliFlo VS-3050 & VS+SVRS Variable Speed Pump -leaks from housing
Which part of the housing?
The back against the motor or against the strainer basket housing?
Parts break down for the Pentair IntelliFlo VS-3050 here.
If leak is on the back of the housing - shaft seal. Or if the leak is on the front the replace O-Rings #10 or #23 in diagram.
Sep 13, 2012 | Pentair IntelliFlo VS-3050 & VS+SVRS...
Can I install a vs 3050 pump to my system that has a ozanator installed on it?
Yes, but make sure that the ozone generator is installed/plumbed DOWNSTREAM from the pump.
The reason is that pure ozone will make the plastic housing very britle if it passes through the pump, as well as weakening the seals and o-rings.
Mar 21, 2011 | Pentair IntelliFlo VS-3050 & VS+SVRS...
Jandy Aqualink with IntelliFlo VS-3050
Jandy has an e pump.It would be cheaper to go that route.the Inteliflo is not compatible with the jandy system .If money is not a concern the pentair product is the way to go.
Sep 29, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Pentair IntelliFlo VS-3050 & VS+SVRS Variable Speed Pump -  Logo
140 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
