Question about Garden
I AM IN THE MARKET FOR AN AIR TO AIR EXCHANGE UNIT. I HAVE AN AIR CONDITIONER (CENTRAL) AND THE OLD UNIT THAT BROKE IS ATTACHED TO THIS UNIT IN THE BASEMENT, WHAT MODEL OR MAKE SHOULD I BUY?
  • 11,800 Answers
Find exactly the model of your air conditioner then measure the space available. Once you know that you should go to a specialized shop and ask for a compatible model. Make sure it's not manufactured in China and don't buy the cheapest. From what i've heard the best ones are manufactured by Venmar.
Posted on Aug 24, 2010
Tip
How to fix problem of Air conditioner doesn't cool
How to troubleshoot and repair the most common problems with your central air conditioner Although some central air conditioner repairs must be handled by a qualified air-conditioning repairperson, you can handle simple repairs and maintenance yourself. Following, you'll find guidance based on the symptoms.
Air conditioner doesn't cool A central air conditioner that runs but doesn't cool may just need to be cleaned. Plan to do this on a relatively warm day. The following are basic guidelines, but always refer to your owner's manual.
1) Before you begin, turn off the power to the unit. There is normally a shut-off or disconnect panel on the house wall next to the outdoor compressor. Also shut off the air conditioner's 240-volt circuit at the main electrical panel.
2) Rake leaves and debris away from the outdoor condenser. Trim any bushes that might block airflow.
3) Unscrew and remove protective grilles and the top cover or grille from the compressor. If the fan is attached to the grille, be careful not to pull any wires loose.
4) Use a soft brush to clean dirt and debris from the fins, and then vacuum the fins with a brush attachment (taking care not to damage the fins).
5) From inside the unit, use a hose and nozzle with a trigger-grip to spray debris from the fins (protect the wiring and motor with plastic sheeting or a large plastic garbage bag). If your owner's manual calls for lubricating the motor, do that now--but don't overlubricate.
6) Reassemble the unit.
7) To test it, turn the thermostat to "Off," reset the power at the disconnect by the compressor and the main panel, and then set the thermostat to turn the unit on. Important note: To avoid straining an air conditioner's compressor, wait at least five minutes between turning it off at the thermostat and turning it back on. Let it run for a few minutes, and then feel the two pipes that connect to the condenser unit on the air handler (slide any insulation back). One should feel warm, the other cool.
on Sep 02, 2010 | Heating & Cooling
Central air conditioning system is blowing warm air.
many, many. Is the outside unit running? If it is, is the compressor running? Feel the refrigerant lines leaving the unit. Little one should be warm. Big one should be cold, probably sweating.
Jul 08, 2010 | Ruud UAPA042 Air Conditioner
I have a GE central air conditioner model
If you are talking about the indoor fan it is probably a bad capacitor. Replace the fan motor capacitor. And YES, if the fan motor needs replacing too, you can DO-IT-YOURSELF.
Jul 05, 2009 | General Electric Heating & Cooling
My Trane air conditioner is not blowing cold air
there could be a few things low on freon will cause the coil to ice up and no air can get through,breaker or switch to the blower unit in the house is off belt broke or the moter let go
Jul 05, 2009 | Ruud Central System Air Conditioner
How to take apart case and back flush heat exchange fins
You do not have to remove the coils. Just carefully lift the top with the motor and set it aside (power off). Spray the outside with a foaming cleaner (Dow bathroom) and flush from inside out.
May 24, 2009 | Weather King 12AJA4801AH Air Conditioner
Central air conditioner
check the filter also sounds like a low freon charge.
Jul 29, 2008 | Ruud UBHC Air Conditioner
20 year old central a/c heater not working
Check your thermostat and mode selector setting, thermostat setting should be set at warmer and mode selector setting should be at low heat or hight this is applicable for manual unit.
If it is a remote control just set the remote to heat mode.
sample only
Jan 02, 2008 | GE Quiet-Aire Ductless Split System Air...
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
