Posted on Aug 24, 2010
Diagrams the power supply de board 51-2350-00 de printer's datamax.
My datamax thermal is not heating up
These printers do not "heat up" as such. Possible causes are:
1. Incorrect ribbon type for fitted ribbon spools. Look at back plate and see which way arrows are pointing. If arrows point Anti-clockwise, then you require inside wound ribbon (i.e. standard datamax) If pointing clockwise then you require outside wound (i.e. Zebra type ribbon). Check ribbons by touching sticky side of label to ribbon (it will transfer ink to label on print side).
2. Could also be faulty printhead, Logic board or Power supply. These will require an engineer to check properly.
El display se ve de cabeza
pointer 6920: Debes de cargarle el ultimo firmware disponible, este firmware trae resuelto el problema del display. Posiblemente tengas que cargar tambien el Boot Loader para que la impresora acepte el firmware. Puedes descargar ambos archivos desde ftp://ftp.datamax-oneil.com/Printer%20Firmware/ , para cargar el boot loader debes de poner la impresora en modo descarga presionando las teclas PAUSA y TEST mientras enciendes la impresora.
Roberto Martinez
[email protected]
I have a datamax I series and I would like to know how to troubleshoot the stepper motor
What type of problem do you have?
Will the printer not feed?
There has been some troubles on early model of the Datamax I class printers that are detailed in a service bullitin on the driver/power supply.
If the printer feeds intermittently, or runs back wards(hunts) it is probably a board failure. I usually replace the board and the motor on exchange with DAtamax if under warranty.
Datamax I-4208 ribbon loading
Follow the arrow symbols stamped on the ribbon spool assy
Vb6 code to print barcode using datamax e4203
Puedes utilizar comandos DPL e instalar una impresora generica, o generar un archivo PDF y utilizar un controlador de windows para DATAMAX. DPL commands you can use and install a generic printer or generate a PDF file and use a Windows driver for Datamax. buscar
1helpful
HOW TO PRINT LABELS IN DATAMAX PRODIGY PLUS PRINTER USING VB.NET
Tu necesitas utilizar comandos DPL. Pero si vas a utilizar graficos o windows true type fonts, tu necesitas un cartucho de memoria ram o flash. You need to use DPL commands. But if you use graphics or windows true type fonts, you need a RAM or flash cartridge.
Datamax WS6308 print error in .net
El controlador de Seagull es muy bueno y con muchos parametros, intenta modificar los parametros del spooler. Seagull driver is very good and with many parameters, try to modify the parameters of the spooler. buscar
k24674
ADMIN Andrew
ADMIN Andrew
