Question about HP 1240 Plain Paper Inkjet Fax
The fax does not know the copy is loaded when sending. Can receive but can't send. It doesn't know the paper being sent is loaded. It keeps asking to load original document. We can a confirmation stating it was sent but the paper never advanced.
    Brigadier General:
  • 3,513 Answers
Hi
Please check this link bellow to diagnose your problem…
http://bizsupport1.austin.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=115&prodSeriesId=374920&prodTypeId=15179&objectID=c00297388
http://bizsupport1.austin.hp.com/bizsupport/TechSupport/Document.jsp?objectID=buu02549
Let us know if you have something more to ask else please accept the solution.
Thanks for contacting fixya.com
Posted on Aug 24, 2010
Can send faxes but not receiving, comes thru blank piece of paper
What about copies or internal prints?
If even a copy doesn't work then it sounds like your LASER unit has gone out, in which case I'd just replace the machine.
If the internal pages or copies come out but not faxes, and you know the sender is sending correctly, then it could be an issue with the main board.
I'd get a second opinion from a service tech locally but I can at least give you the part numbers for both so you have an idea of the cost of parts.
LASER UNIT
LM4578001
MAIN BOARD
LG6141001
Jun 13, 2011 | Brother IntelliFax-2820 Laser Fax
SHARP UX-A1000 - sends all BLACK page (to all
Noisy line? is all that strikes true when you ensure me it makes great photocopys, but then you receive OK, very strange, All the mechanisms for doing a local copy is the same as sending a fax the difference is the conversion to phone noise so it has to be electronic, I;d guess lightning/power surge, cant think of much else....sorry
Nov 04, 2009 | Sharp UX 510 Plain Paper Thermal transfer...
Cannot sent fax because document too long
If you can copy the document, then you can send it BUT the receiving fax will probably have restricted length fax pages to prevent jammed documents at the sending end causing the receiver to use all the paper. If you have access to a service manual you can restrict the length of faxes sent and received on your machine. But it may be the receiver with the restriction.
Jul 01, 2009 | Canon FAX-L900 Plain Paper Laser
Panasonic UF-490 Fax machine is sending more than one fax
You might have a job stuck in memory. Message window should say 00%. Try this press Function key press 7 key press monitor key slowly 4 times press * key press 6 key scroll down to ALL JOB CLEAR press SET wait for reboot Good Luck
Jun 05, 2009 | Panasonic Panafax UF-490 Plain Paper Laser...
Distorted copy quality in the sent faxes
Make sure the rollers that pull the paper through are clean and that the glass is also clean. Clean the rollers with a cloth dampened with alcohol.
Apr 20, 2009 | HP LaserJet 3050 All-In-One Printer
I have brother all in one 420cn. Can send fax but cant recive fax
There are no digital fax machines. You need an analog phone line for your machine to work reliably.
Feb 25, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Can't send or receive fax
Your product must be accidently set to copy mode instead of fax mode and when it is, it actually expects a document to be loaded in the tray to "scan/copy" so change to fax mode again and try to sent the document. This should fix your problem.
If you do want to make a copy, make sure a doc. is loaded and press start copy to do so.
Jan 06, 2009 | Canon FAX L-120 Plain Paper Laser
I have the stupidest question. i have a brother fax 560 plain paper fax. Do i load paper face up or down to send a fax? THank you!
just check there wilkl bi mention face up or down .if not mention no problem just make a copy by putting face up and one copy by putting it face down.one time u will receive white copy and one time u will receive print on paper .when u will receive print check this is face up or down .after confirm just send fax
Dec 16, 2008 | Brother IntelliFAX 560 Plain Paper Fax
All Fax pages not received or sent.
have you watched the paper going through the doc feeder are thay goning one by one or is it pulling more then one. try making a copie withe 4 sheets does that work. if not open cover of doc feeder clean rollers. serperation pad. ( pad would be twrods the top of the cover )
C.W.H.
Jul 21, 2008 | Canon LaserClass 2050 Plain Paper Fax
TX problem
If I understand you right, what you send, people are receiving blank sheets?
When you try to run a copy are those blank also?
If so your problem is with the scanner. The drum should have nothing to do with sent faxes.
Unless your putting the paper in the scanner upside down. And if you ran it enough to need a drum I can't imagine that .
May 15, 2008 | Xerox FaxCentre F116 Plain Paper Laser
HP 1240 Plain Paper Inkjet Fax Logo
Seeker5211
Seeker5211
