Question about Toto Carrollton Toilet
Delay in refilling toilet after flushing - Toto Carrollton Toilet
  • 14 Answers
SOURCE: Toto Toilet - no water flow to refill tank after flush
Remove the tank lid and look at the fill valve. Is it a yellow valve?
This fill valve is common on the Toto Toilets and can easliy plug with debrie.
They can be disassmbled and cleaned. however, I usually just replace the valve with Fluid Master Fill valve.
You will also want to check the water coming into the toilet by turning off the water that supplies the toilet and disconnecting the water supply line. After removing the water supply line turn on the water at the valve to make sure that the water is flowing properly. Check the supply line also to make sure it is not plugged.
Be sure and place a small container to catch the water that will come from the valve. A towell will also help from making too much of a mess.
If the Supply line and the valve are clear the problem is in the fill valve.
The G-Max system denotes the Flushiing system which is a 3" flapper that allows the water from the tank to flow into the bowl quicker.
Good Toilets!
sanray
Posted on Jan 10, 2009
SOURCE: toilet tank will not refill with water after flushing
I fixed the problem. There was a clog in the pipes so i just flushe dthe pipes out.
thanks,
for your help
Posted on Jan 18, 2009
  • 659 Answers
SOURCE: Toilet will not flush
You need to replace the fill valve with a oem replacment valve. You need to use toto parts.
Posted on Mar 21, 2009
SOURCE: toto toilet with gmax flushing system blue top
I have the same problem and can not find a solution. The toilet flushes fine but then a delay in filling up the tank occurs. Is there a part I can replace? Does something need to be cleaned or cleared?
Posted on Jan 15, 2010
  • 17 Answers
SOURCE: toilet bowl gurgles after flushing cycle
Sounds like your toilet is not vented properly. Possilbly something caught in the trap is causing it to syphon
Posted on Jan 23, 2010
Delay on tank refill after flush for American standard toilet
The washer is sticky inside the valve. Depending on the type, you either replace the washer or diaphragm, or completely replace the inlet valve.
Easy job, just Google or YouTube.
American standard toilet Google Search
Dec 05, 2016 | Cameras
Toto toilet won't flush
Replace the assembly. This is common in areas with high mineral content in water. You will be glad you did. Delay too long, you may find your toilet running while you are at work .
Jan 25, 2013 | Toto Drake ADA Compliant Toilet with...
I bought 2 toto toilets about 7 years ago. One toilet has started to experience about a 2 to 3 second delay from the toilet discharge to the refill. I replaced the flapper ball but no change in the flush....
jasether-
The fill valve is most likely corroded with mineral deposits. You can either try to clean it or replace it (these cost just a few dollars). Remove the old one and take it to a plumbing supply or hardware store to properly match the replacement.
Hope this helps.
Regards,
DIYpro
May 04, 2011 | Home
After the toilet is flushed, the water coming out of the rubber tube to refill just barely trickles out. It takes about 10 minutes to refill. Thanks Don Cook
Most likely the toilet flush valve is plugged with sediment &/or needs to be replaced. Try turning off shutoff valve on bottom of toilet. Then turn valve back on. It may flush out the sediment. If not you will need to change the valve.
Jan 17, 2011 | Toto Home
Toto toilet
check the pipe connection from water tank
Mar 17, 2010 | Toto Washlet S400 for Power Gravity...
When you flush, the bowl refills and then suddenly empties 90% of the refilled water. Why? This is a toto toilet and this happens almost all the time now.
it sounds like it is not flushing completely at first and then releases and the suction is pulling water out of the bowl. Could be a venting issue or a clog issue that is hindering the proper flushing of the toilet.
Nov 23, 2009 | Toto Home
Toto toilet with gmax flushing system blue top
Jun 20, 2009 | Toto Drake ADA Compliant Toilet with...
Mar 07, 2009 | Toto Aquia II Dual Flush Toilet
Toilet tank will not refill with water after flushing
thanks,
for your help
Jan 17, 2009 | Toto Carlyle 1-piece Elongated Bowl Toilet
Toto Carrollton Toilet Logo
157 people viewed this question
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
