Question about Grundig GU22DVDPX 22 in. LCD TV
My Grundig can work here in Philippines? - Grundig GU22DVDPX 22 in. LCD TV
Grundig t55-549 forgot pin code
Try 0345 563 582 515 098 584 219 104 233 223 065 471
Grundig
FT70-700 822DOOFA MW82- 500IRDT ST63725 ST63755 TF55-302 GT210S. MW822699 CVC2030ST ST70-875
563
Grundig
T70-1021, T70-1022
065
Grundig
MW82701 ST55/730 MW70/2700
582
Grundig
GT1401
515
Grundig
T55-1120 T55-1020 WF703020
471
Grundig
32WF100 W82-2030
584
Apr 21, 2014 | Televison & Video
Sky remote control code for grundig tvr 5540 ft/gb
Try 0345
Grundig
563
Grundig
T70-1021, T70-1022
065
Grundig
582
Grundig
GT1401
515
Grundig
471
Grundig
32WF100 W82-2030
584
Apr 16, 2012 | Televison & Video
Grundig Televition (P37 830 Text) shows only one channel with an
hello, I had thesame problem. I tried everything, after 14 days, where was TV off a tried itagain...an the same problem: text " ATS... OK " So a tried hold 3seconds on Grundig driver button "OK" and then the started automatictunnig. After it - averything is function! :)
May 03, 2010 | Grundig GF70-600 TV
Dropped my portable grundig s350. Stopped working
Anything could happen in a fall, no telling what needs attention, could be a bad battery connection a cracked circuit board. If it is under warranty send it in if not a good technician is needed.
Jan 24, 2010 | Grundig S350 AM/FM/SW Radio
Grundig yacht boy 400 radio does not work with mains operations
I had the same problem. Examined the wire from the transformer,and found a break. Repair of the wire solved the problem. WLD
Mar 01, 2009 | Grundig YB 400PE AM/FM/SW Radio
Who fixes a Grundig YB400 antenna disconnection?
I can fix it that your grundig receivers.But the problem is that im here in the philippines.That is very easy you open it carefully and find the wire for the antenna and connect it and better you solder it, grundig product is customer friendly its not hard to repair .message me whatever the result
Jun 17, 2008 | Audio Players & Recorders
How to break tv code
I have a TV bought from Egypt Grundig ST-28-5441/5 . But when you put it on there is a display of 4 codes to input. What codes can i use to reset it.
Mar 30, 2008 | Televison & Video
Grundig GU22DVDPX 22 in. LCD TV Logo
61 people viewed this question
Top Grundig Televison & Video Experts
Henry  Thomas
Henry Thomas
Raj Patel
Are you a Grundig Televison and Video Expert? Answer questions, earn points and help others
