I have a Phillips 46 in. model 46kp30 we can hear it but not see the picture
  • jboyandcutip Aug 26, 2010
    I do have electronic knowledge, and i am looking at the schematics on the tv and i do not see a high tension module for the crts. I see red/green/blue/svm panel, focus combo,and interface panel. Can you explain where I might locate these things to test?
  • 11,800 Answers
The tv has a fault in it - either in the high tension module for the CRT's or in the final video circuits. To find precisely which you must open the tv and test it. Beware, the very high tension inside is dangerous, if you don't have at least basic electronics knowledge then it's time for a repairman.
Posted on Aug 24, 2010
  • Azrael SRL Aug 26, 2010
    SVM - Scan Velocity Modulation - it's the board that allows different scanning frequencies, for different resolutions. You can check there if the module is powered and if the scanning frequencies are generated.
    The focus board is the one that controls the sharpness of the image by modifying the voltage on the acceleration grille from the CRT's . No connection to your problem.
    The interface panel is the board with the buttons on the case - no connection with your problem.
    This tv generates the image using 3 Cathode Ray Tubes. For them to work they need a very high tension - over 24 000 volts. Look at the tv board; on it you will see a black rectangular transformer placed vertically; from it 3 red wires go to the tubes - this is the high tension transformer, easy to locate on the schematic. Find the transistor that is powering it and check it for integrity and if it receives power from the source.
Phillips 46 TV I have no picture but I have sound Flat Panel...
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, it can't be replaced. In this case; a panel replacement is the only repair.
Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
Feb 09, 2015 | Philips 46PFL3706/F7 46" 1080p 1920 x 1080...
Green light flashing and no picture on our tv
2004-Model H 347 - 10839 Phillips big screen HDTV. The picture went 3-D.
Dec 25, 2009 | Akai PT46DL10 46" HDTV-Ready Television
Phillips hdtv model 30pw9110d/37 won't turn on
Common short the cover cap over the video & sound boards short out if you remove it the cap only (shield metal) it usually will fix this
Apr 28, 2009 | Mitsubishi WT-46805 46" Rear Projection...
TV turns itself off after a few seconds, no picture at all
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Mar 28, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Adjusting colors on a magnavox 46" projection TV
Replace the CRT fluid. It grows algea in the blue and green only. 9.99 from MCM electronics.
Oct 19, 2007 | Philips 46PP9302 46" Rear Projection...
Sumsung HLP 4663W
Might be a bad ballast, has the picture been dark?
Jun 21, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
