Question about Dometic Rooftop RV Air Conditioner
I need a part for the heating coil, i think it is called a limit sw., a small disk between the coil
    President:
  • 3,773 Answers
Try www.marcone.com
Be sure and have your model number.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 24, 2010
Pilot light will not stay on
Try to clean the thermopile, it should be free of dirt/ soot so heat from pilot flame could be sensed better. Thermopiles generate small amount of voltage when heated properly, the voltage it creates is used in energizing gas valve solenoid coils.
Check also if the hi limit is good, small amount of voltage thermopile generates pass through hi limit terminals.
Jun 04, 2011 | Pitco Frialator SG14 Deep Fryer
Furnace keeps tripping off on limit switch. replaced limit switch still trips, blower motor seems to work fine.
It's always possible that the limit "dial" switch is sticking leading you to believe that it's only at 150º.
How old is the furnace and when was it last cleaned.
Dec 12, 2007 | Heating & Cooling
Jan 12, 2010 - My air handler fan (american Standard #TWE065E13FBO) works during a/c operation but not during heating operation. Checked continunity through the the thermo sw and throught the heating coils...
You need to check if the air handler fan running.Suppose if you donot see it then, check to see if the fan on the outside unit is running. If the fan on the outside unit is not running either, check to make sure that the breakers for the furnace/air handler and the air conditioner are on. Also if the breaker is not tripped, then the problem may be your thermostat, the furnace/air handler control board, or the wires between the furnace/air handler and the thermostat.
Let us know if you need further assistance.
Thanks for contacting Fixya.com
Jan 12, 2010 | Heating & Cooling
Dryer is not heating. I replaced the heating element but it's still not heating
The heating element is controled by Thermal disks. Basically these are preset thermastats that tell the heating element when to turn on and off. they can be checked with contuinity tester. Replacment is simple normally 2 screws hold them in place. They will have 2 wires running to them. This page gives a discription and photo of them.
http://www.alibaba.com/product-gs/200327543/Disc_Bimetal_Thermostat.html
I hope this helps
Please leave feed back
Nov 30, 2009 | Cars & Trucks
Mdg5500aww no heat / flame.
Yes, that open switch is the high limit thermostat. this will shutdown the unit and prevent it from heating. you must replace the open switch(thermostat) asap and, replace the thermal fuse as well.
Jul 24, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Why does the fan go on but the furnace/air conditioner does not?
What are you calling it to do at the time? If you are asking for cooling, go outside and check that the outside unit is receiving the call to come on. (is the contactor being pulled in) If not, check for loose wiring to the unit and check voltage from the t stat. If you are calling for heat, then a limit switch has tripped and needs to be reset. Limits are small disks the size of dimes with 2 wires and a small button in the middle. Depress the button firmly to reset it. Hopefully this helps.
Apr 15, 2009 | Dometic Rooftop RV Air Conditioner
Want heat up, but comes on.
Sounds as though the limit switch is tripped. Find a small disk about the size of a penny or dime with two wires going to it. There should be a small button in the middle of the wires. Press it firmly and then try again. You can usually find the limit switch on the burner Assembly.
Apr 10, 2009 | Kenmore 72062 Gas Dryer
Heat does not work when thermostat calls for heat...
This is a safty limit switch. Find two wires that are going to the inducer or combustion blower that terminates to a small disk about the size of a penny. In the middle of those two wires should be a small button. Push firmly down thus reseting the switch. This should do it. It could also be the pressure switch but I have never heard it called that before. If the first doesn't fix the issue. Remove the small tube that runs from the inducer to a black or silver disk, blow out and draw in air until you hear clicking noises. Sometimes they can become stuck. If that doesn't work, remove the other end of the tube from the pressure switch and blow through it. Sometimes debris can clog the entrance to the pressure switch as well. Hopefully this will solve your problem. You can have a bad limit or a bad pressure switch. In this case you will probably have to call someone out.
Apr 08, 2009 | Goodman Heating & Cooling
My (Rheem)electrical heater is not heating the
Check all your manual reset limits. There are two wires that go to a small disk about the size of a penny. In between those wires is a small button. Press the button firmly. You will have between 2 to 5 of these. There is also a limit switch located on the back wall of the unit that enters in the heat exchanger but it is not resetable that could be bad. You will need to check all of these. They can be jumped temporarily by removing the wires and adding a small wire.
Apr 06, 2009 | Heating & Cooling
No heat
OK there is morer limit switches inside and in rear of duct. On that you may need to have a good look at is called the high limit. It prevents the dryer from reaching extreme temperatures but it also can become weaker over time and remain open not allowinh electrical power to the elements. Here is a small photo
4d2f0c6.gif go to my web-page and enter LE9200xww1 in to the model search feature. You get a breakdown of your dryer and parts listings. Click link below...
http://servicepartstec.blogspot.com/
Let me know if you need more help from there,
Thanks, Sea Breeze
Mar 21, 2009 | Whirlpool Dryers
Dometic Rooftop RV Air Conditioner Logo
24 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
