Question about Norcent Technologies DP313 DVD Player
Is there a way to scene select without remote?
DVD player won't play new movies
Try this
1.While the previews are playing, press the Menu Button on your DVD player remote to access the DVD's Main Menu.
2.Go to Scene Selection and press your Enter or Ok button on your DVD player remote.
3.Highlight Scene 2 and press the Enter or Ok button. This will start the DVD in Scene 2.
4.Use your rewind or reverse button on your DVD player remote to rewind back to the beginning of Scene 1.
Walt Disney Home Entertainment Technical Support
1-800-723-4763, Monday's 9:30-7:30 and Tuesday through Friday 9:30-6:30 CST
Excerpt from email tech support Walt Disney
Dec 07, 2007 | RCA B27TF680 27 in. TV/VCR/DVD Combo
Purchased the DP300 at the Goodwill. The DVD has the remote control;however, I do not know how to use the remote control. I used the red, yellow, and white connector to my the DVD player and to the TV but...
with regard to using the remote control :
Make sure the batteries in the remote are working (they go in the back of the remote at the bottom).
Turn on the DVD player with the power button on the DP300 itself (lower left). Open the dvd tray either with the remote (press open/close button, upper right) or with the button on the DP300. Put a DVD in the tray and close it with the remote or the button on the DP300. The DVD should load.
Use the arrow buttons in the centre of the remote to select choices from the onscreen menu of the DVD. Press Play (centre of the 4 arrow buttons) to activate the choice you want. For example, if you want to play a movie, use the arrow buttons to go up or down until "play movie" is selected, then hit PLAY, and movie will play. If you want to choose a scene/chapter of the movie, use arrow buttons to go up or down until Scene Selection or Chapter is selected (highlighted), and press PLAY. This should bring up a list of the scenes or chapters. Use the arrow buttons to select the one you want, then hit PLAY, and that scene should play.
If the DVD tray is taking less than 20 seconds to operate, there is likely no problem. If it is taking more, there may be. I think the mechanism that opens and closes the tray is often the first thing to stop working on DVD and CD players.
Jul 20, 2011 | Norcent Technologies DP300 DVD Player
Cannot advance thru the menu selections on exercise DVD with universal remote
To navigate in Menu to select desired part of file is needed original remote because universal remote does not have these special command. universal remotes have few common control buttons for routine control of any gadget.
Replacement remote for Samsung DVD-V2000 is available HERE and HERE as it will help you to select required scene in exercise dvd disc.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Nov 03, 2010 | Samsung DVD-V2000 DVD Player/VCR
Not receiving signal from remote control
I have a new remote from a C1300NTVD Lightning McQueen car TV for sale. It's probably the same remote for a C1320PTVD.
Chris
email me: chris_goulet [at] yahoo [dot] ca
Apr 28, 2009 | Disney CARS 14 TV/DVD Combo
Brightness difficulty
I had the same problem and so went into the menu and selected brightness and increased the number, and my dark pictures were much better.
Jan 26, 2009 | Protron PLTV-4250 42 in. LCD Television
Lost the remote
If it is Sony DVD Player DVP-NS425P then you need original remote to use above options.
Remote part number is as follows...
clear_spacer.gif " 147772411 " RMT-D153A REMOTE CONTROLand price is approx $18 and available at Sony Accessories. Please write model number of your dvd player DVP-NS425P in search box and see result.
Oct 04, 2008 | Sony DVP-NS425P DVD Player
MVC-CD300 for Dummies?
for average still shots, do I need to constantly monitor & adjust scene selection (twilight, landscape, portrait)? No, just leave it on the little teal colored camera. If you want to use the scene selections then it must be on SCN. I unfortunately spent a lot of time when I first got this camera switching between scenes without putting it on SCN - so it didn't really change scenes! Also, when switching modes, must I turn camera off before rotating mode dial? No
Sep 12, 2005 | Sony Mavica MVC-CD300 Digital Camera
Norcent Technologies DP313 DVD Player Logo
174 people viewed this question
Top Norcent Technologies Televison & Video Experts
Jaime Hernandez
Mat Taylor
Level 1 Expert
Are you a Norcent Technologies Televison and Video Expert? Answer questions, earn points and help others
