Question about Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range
Still waiting re: Jenn-air model JDR8895AAS Serial# 1AL13321967GL. Broiler mode as well as toaster not functional, element does not appear burnt out,no in line fuses visible or listed as replacement parts in the manual.Back panel as well as top off. NO shorted wiring visible ,no sign of main board damage/burn out .All contacts appear nominal.Tech info. guide for self diagnostic will not operate. When both upper cancel and broil pushed simultaneously one beep sounds and three sec. later two beeps sound with no display of "QUICK TEST" on screen.
  • crobak Aug 24, 2010
    asked question yesterday,BAD answer given. No fuses inline or other wise listed in wiring diagram indicated.Repeated assistance requested and additional info. as to state of stove given. Please assist asap.Thank You
  • 15 Answers
SOURCE: Oven won't lock and self clean.
Shut off the oven for at least a minute and turn it on, set the clock, and it worked. I had tried a short power cycle before and it didn't fix it. The extended power cycle did the trick.
Posted on May 02, 2008
SOURCE: clock assembly
my automatic cleaning setting in my oven will not heat up. I set "clean" on both dials and put the lock on, the fan comes on but no heat. Is there a certain system to turning it all on and the timer so it will work?
Posted on Jun 02, 2008
SOURCE: Jenn-Air electric range
my jen-Air has a problem with it continuing to beep. Ive tried to get it to stop by pushing all the buttons. When I pust the off/cancel button it just keeps beeping. Tried the stop timer button and same thing. When I turn on either the bake or convection bake button it automatically just shuts off by itself. It is approx 10-13 years old. HELP, or please tell me to get a new one.
Posted on Oct 23, 2008
  • 2651 Answers
SOURCE: Jenn Air F7 error msg with incessant beeping
F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button
Posted on Dec 08, 2008
SOURCE: Jenn air gas/elctric slide in range self cleaning does not work
Posted on Apr 03, 2009
Jenn-air elecrtic oven JDS9860AAP is slow to heat up and will not come up to temp.
Either you have an open element a burnt terminal lead or a bad control try setting on broil only the element should glow in bake the bottom element should glow while the top cycles on/off based on your description of a humming noise I would suspect the relay on the control board
Feb 16, 2015 | Jenn-Air Kitchen Ranges
What is the complete model number of your unit?
Dec 04, 2012 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
It's a Model JJW8530CAB. The baking element
Are you having any issues at all with the display at all? Did this start out of the blue or did you have a power outage or anything else?
Jan 20, 2012 | Jenn-Air 27 in. Electric Single Wall Oven...
How can I disable Sabbath Mode on my Jenn Air JDR8895AAS
Sabbath Mode on this model can be disabled by pressing the "CLOCK" button and holding it for 3 seconds. "SAb" will then flash for 5 seconds, then return to normal display. Sabbath Mode will also automatically turn off after 72 hours.
These instructions are listed on page 16 of your owner's manual. If you no longer have a manual, you can obtain a replacement copy at Just enter your model number under their "Manuals" link and you will find the owner's and installation manuals available in .pdf format. You can download or print a copy for FREE.
For your convenience, here's a direct link:
If you require additional assistance, please post back and let me know. I hope you find this information helpful.
Oct 25, 2010 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Top oven toast function not operating/element not burnt out but will not heat
The fuse on the oven may be burnt, this will not allow the oven to be hot, while other parts will be functioning. Check your owner's manual to see if your oven ignition system has a fuse. some are located under the cooktop, though locations vary. Replace it with the same size fuse if the fuse element is burnt.
Take care.
Aug 23, 2010 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Several Gas Burner Igniters spark every 5 seconds even when all burners are turned off. Jenn-Air Dual Fuel Range JDR8895AAS Help, and Thanks! -- Larry
hi could be a short on the ignition switch of the spark box is stuck in the repeat mode disconnet power and see if this helps
Jan 23, 2010 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Cuisinart Toaster Oven Broiler Not working properly
This is not a defect - it is just how the unit operates. You can set it to Broil, and the top element should not come on. Make sure the wire rack is turned upside down so that it curves inward and try one more time.
-Tha Mp3 Doctor
Jan 04, 2009 | Cuisinart TOB30BW Toaster Oven with...
Are you sure the breaker didn't trip on one side? If one leg of the 220 is out, the lights and controls will appear to work, but the elements will not heat up. Make sure you have 220 to the appliance. It's also possible that you pulled a wire off somehow when changing the broil element.
Dec 12, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range Logo
50 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
