Question about Nelson Sprinkler: Traveling Tractor
Our Tractor runs a while then slows and stops and just shoots water out.
  • 43,501 Answers
Your water pressure is dropping...you need to have 40-60 PSI to keep it going...
Here is a tip about how to get parts for your traveling lawn sprinkler and also a great article about how traveling lawn sprinklers work.
Traveling Lawn Sprinklers
heatman101
Posted on May 19, 2011
I have a Craftsman lawn tractor, model # 917.276180. After mowing for about an hour, the transmission starts to slow down and eventually stops. The tractor s/n is 03006D006025 and was purchased new from...
Hi, remove the battery and battery carrier and clean all grass and debris from the hydrostatic drive, cooling fins and fan. I'm not sure what transmission it runs but the solution applies to all. Hope this helps, regards Phil.
Aug 25, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
After cycle water is still 1 inch deep in bottom of dish washer
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Jan 06, 2011 | GE PDW7900N Built-in Dishwasher
Ford tractor injector pump what slow down
Not sure what you mean by this but often times the screen in the petcock (fuel shut off valve in the tank) will plug and cause the tractor to shut down, run rough, or have no power. Hope this helps.
Oct 11, 2009 | RTO Ford Tractor 2000 3000 4000 5000 Water...
Model # 917256563 19.5 hp Craftsman. Ran fine until the front tire fell in a small hole. I heard a poping noise from rear of tractor I lifted the wheel out the hole and now the tractor will only run if I...
If the tractor stopped abrubtly, you may have bent something pertaining to the frame or the clutch pedal assembly if you caught your weight on the clutch when it stopped. Sears parts.com has en exploded view if you enter your model number
Aug 21, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Bagger problems
I would say is to run the mower at high rpm's and slow the tractor speed down and not take full cuts.
Aug 11, 2009 | Garden
My riding mower workes fine fore about 45 mintes then it slowes down wants to move real slow and wont pull my yard sweper anymore. The blades engage just fine, the motor starts/runs fine It just moves slow...
Im assuming the tractor is a hydrostatic, in this case when the transmission starts to go...thats it, call the company and find a replacment or get another tractor. unfortunately rebuilding them isnt all that worth it
Jun 13, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Jd tractor 750 will start and idle, not run with throttle up
possible water in gas ,
if the tractor was running good and this suddenly happened,look at gas in tank if there is water you will see it looks like a bubble in tank floating around !
Apr 26, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Humidifier leaks water when turned on
Humidifier water pad comes w/ a mark in one end, that mark should be on top. Also check your feed tube they tend to crack some times. if if still leaks water change the water pad
Nov 14, 2008 | Aprilaire 550 Humidifier
Nelson Sprinkler:  Traveling Tractor Logo
197 people viewed this question
Top Nelson Garden Experts
Dennis
Mike Squire
Phil Walker
Phil Walker
Are you a Nelson Garden Expert? Answer questions, earn points and help others
