Question about Konica Minolta Office Equipment & Supplies
We have a C250 copier and when you are printing the the work is being printed double on paper. we brought brand new toners. what can we do to fix this problem?
  • Konica Minolta Master
  • 6,161 Answers
Replace the fuser unit.
Posted on Dec 26, 2015
  • 26 Answers
SOURCE: double print or a shadow print
You have probably been using non genuine toner, some kinds of this toner is not the same quality as Brother toner and just chews you drum out before its due to be changed. Change the drum and use genuine toner.
Posted on May 20, 2007
jaylex
  • 417 Answers
SOURCE: Toner life end
There is no reset code the likely thing is that you have a faulty toner cartridge. Put another new one in and check the machine then.
Before you try the above shake the toner cartridge and tap it some more as it may also be the toner inside have become solid and needs breaking up.
Hope one of the above works for you
Thanks J
Posted on Jan 08, 2008
Logjam
  • 159 Answers
SOURCE: CKECK PAPER & RECEIVED IN MEMORY
The problem is the paper size doesn't match the size of paper set by the machine. Usually this is corrected by changing the paper in the tray to legal size. However, you may have changed the size of paper in the data, so check that in the user settings.
Posted on Jan 20, 2008
  • 106 Answers
SOURCE: PAPER JAM MESSAGE, BUT CAN'T FIND ANY JAMMED PAPER
look at the paper tray,some of your sensor are jammed,try tyo find out where is the sensor on paper try
Posted on Feb 29, 2008
SOURCE: put in brand new toner machines says toner is low.
plull the drum out...and clean the roller....you will be able to see the ink on the roller where your lines are appearing.
Posted on Jan 13, 2009
Very bed image on a paper
Print a couple of pages. As the printer is printing open the toner cover. Pull the toner cartridge out and look down at the paper. If the printing looks good the fuser probably needs replacing. Before doing that, have you checked the toner cartridge.
Mar 09, 2014 | HP LaserJet 3015 All-In-One Printer
Ink flaking off printed labels
your problem is not good fusing. try with a different fuser.
Apr 10, 2013 | Oki Brand Oki 62433501 C711n Laser...
I recently bought a second hand konika bizhub c250. The problem i am facing is that every time i try to print A3 size on full colour (and i say full colour cause, plain A3 with little colour or text work...
First, I should ask where you buy your toner and what quality is it. If it's not a genuine Konica Minolta toner you will run into more problems.
Your first check, print using about 5 copies of card, if the prints on the cards shows shadowy image or you find shadow repetition of the prints, that's a confirmation of a bad toner quality.
Apr 06, 2017 | Konica Minolta bizhub C250 All-In-One...
Double printing on page
This is caused either by the fuser or the tonercartridge.
The most common cause is the tonercartridge.
You can test this by forcing a paperjam to stop the paper just after the toner but before the fuser.
To force a paper jam print you can print a page from the manual feed tray and as the last third of the page enters the printer opening the door causes it to halt.
If the double printing occurs before the toner is bonded to the paper by the fuser you should replace the tonercartridge..
Dec 29, 2010 | HP LaserJet 2420 Printer
My printer worked very well until I changed the toner. I see dust around the back toner. I brought the generic toner. The store manager said that was the problem. Then I brought new HP toner. It is the...
Smeared output can result when you refeed a printed page into the printer to make a double-sided page. This happens because the rubber rollers that grip the paper to pull it into the printer can pick up toner from the first side’s printing and smear it. So before replacing parts, this is an easy thing to check. Printing multiple pages consecutively will make the pages print progressively cleaner or you can clean the rollers with rubbing alcohol.
Smeared toner also happens because the nonstick coating on the fusing roller is scratched or has baked-on debris. This can happen if the printer is in a dirty environment especially. If you are comfortable removing the fuser, you can try to clean it with a soft cloth and alcohol, but make sure you let it cool down first!
Finally, if this does not resolve your issue then make sure the fuser is heating; toner that is not heated properly will fall from the page and smear. If the thermostat is bad or the fuser not working properly, you will most likely need to replace the entire fuser assembly. This will be pretty expensive to repair so hopefully it's one of those other issues.
Apr 08, 2010 | HP Hewlett Packard LaserJet 2605dn Printer
Won't print or pick up a sheet of paper
toner cartridges of the 2400 laser comes with a counter chip. if it reaches its limit or the number of pages it should print. the toner cartridges are unusable anymore. try buying new cartridges or if you could find a supplier of the counter chip it would do just fine.
Mar 27, 2009 | Minolta magicolor 2400W Laser Printer
Printing everything double sided
go in youre ip address, log in as admin, chooce print tab and there is a print tab, there is a default options, and choose double printing off
Oct 29, 2008 | Konica Minolta bizhub C250 All-In-One...
Streaks on color copie
You must pull 2 sided glossy from the stack bypass and set on color paper.
Apr 11, 2008 | Canon CLC 1120 Color Copier
Phaser 7300n Printing on Double Sided Glossy Paper
At first I didn't think the paper was the problem, but I looked up the specs on it and is seems to be a paper designed for an offset press.
I suspect after reading the information on the paper that the coating is not designed for the high temperatures of a laser printiers fuser heat of over 350 degrees.
I do suspect the paper is the issue.
sounds like you are melting the coating.
Dec 30, 2007 | Xerox Phaser 7300DN Laser Printer
69 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
