Question about Whirlpool 18.2 cu. ft. Top Freezer Refrigerator ET18PKXG
Model et 18 pk will not get cold or freeze anything
What numbers on a dial mean the coldest my freezer keeps icing up what number should I have the dial on
Not sure what you mean with icing up, but in every freezer, vapour will freeze to the side.
If you want to go for sure, just buy a little thermometer for the freezer (must be going at least to - 30 Celsius) and hang it in the freezer. 3 or 4 star freezers should be at -18 Celsius.
Lower does not add anything to the quality of the food, or can extend the time you can preserve it in the freezer, but will cost more energy to keep it that cold. Lower than - 18 will shorten the time you can keep food in the freezer. -18 C is about -0,4 F.
so 0 or above is bad. -0,4 or below is good.
Sep 22, 2014 | Refrigerators
Freezer wont go below -9 degrees
This information does not mean anything to us if you didn't specify the model. In what temperature range a freezer works we knew thanks to the stars.
One star (-6 degrees centigrade) is perfect for making ice cubes and is sufficiently cold to keep food for three or four days.
** Two stars (-12 degrees centigrade) stores food for fifteen to twenty days.
*** Three stars (-18 degrees centigrade) will keep food safe for up to three months.
**** Four stars (below 18 degrees centigrade) means that the compartment provides the ideal conditions for freezing down fresh and pre-cooked foods.
Dado
Oct 27, 2013 | AEG Freezers
It is not wanting to freeze. but it does keep things frozen. and some times water does come out at the botton
Hello
Check that it set cold because its not below -2 or -5 thats why dose not freeze anything it needs to be at least by -10 to -18
Jun 04, 2011 | Frigidaire 14.1 cu. ft. Upright Freezer...
My refrigerator worked great until I had to unplug it for a little over a month. Now the freeze is not freezing.. its getting cold but not freezing and my refrigerator is cool but not cold.. any...
Normally the refrigerator should be run continuously as taking only 0.5 to 1.2 amphs maximum.
Once it's switched off for more than 2 days, there are chances to get chocked. Replace the gas after flush out the system.
Dec 08, 2010 | Maytag Refrigerators
Whirlpool 6 sense model WSC5513- A+ X side by side, without ice or water dispenser. Refrigerator part not cooling properly. Temperature setting is -18 degrees Celsius for the freezer and 2 degrees...
The temp for the fridge is about right and -18 for the freezer is ok so check to see if the water filter is plugged, at 8 degrees Celsius is about 18 degrees fht. Which is freezing so the numbers don't add up. 26 degrees below zero on the freezer side is what you want if it that cold it could have frozen the water line.
Aug 20, 2009 | Refrigerators
This had never happened before maybe it is to do with the freezing weather but my bosch freezer will not go back to the temperature of 18 when I try to put it back to 18 it stays at 18 for a second and...
IN REPLY TO YOUR EMAIL THE FREEZER TEMPERATURE SLOWLY WENT BACK TO 18 DEGREE'S AND HAS STAYED THAT WAY AS IT SHOULD BE I CAN ONLY THINK IT HAD TO WITH THE FREEZING WEATHER AS OUR FRIDGES AND FREEZERS ARE IN A UTILITY ROOM AND CAN GET VERY COLD.
Regards
Patricia
Feb 02, 2009 | Bosch KGU34641 Bottom Freezer Refrigerator
Problem installation Webcam Makntech
i lost my cd,i want my web cam software
Aug 29, 2008 | A4tech Xmaster PK-835 Webcam
Refrigerators Logo
55 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
