Question about Saeco Odea Go
My saeco "odea go" has its red exclamation light blinking fast. The manual says that it needs to be primed. However, the light still blinks, and there is no water coming out of the hot water dispenser. What to do? Any help is greatly appreciated
Have got exactly the same problem any suggestions?
Posted on Sep 18, 2010
My saeco odea giro coffee machine has a red light flashing quickly. The light looks like an exclamation mark. No matter what we have done to try and correct it still doesn't stop.
First try to prime the machine.
Turn on hot water and prime about 100 ml hot water. If the red light remain you have to change the flowmeter.
Nov 01, 2017 | Saeco Coffee Makers & Espresso Machines
Saeco coffee machine with a red blinking exclamation point light won't make coffee, how do I fix it?
When the red exclamation point is flashing slow, something is not where it is supposed to be, bean hopper lid, door, brew mech, water tank empty, dregs box or water tray on dregs container is full. If the red exclamation point is flashing quickly, open the steam valve for pump priming. If pump turns on, and water passes correctly, the light should go off and return to heating stage. If not, we have a blockage or a pump that is not working correctly.
Nov 16, 2015 | Saeco Odea Giro Plus Coffee Maker
Saeco Odea Go machine, red light blinking,
when the red light blinking it means machine must be primed. BUT if you prime it and still red light -you have to change the FLOWMETER.
Dec 24, 2017 | Saeco Odea Go
Saeco Eclipse stopped functioning
Have you solve your problem with Odea. Mine is new out of the box and not working at all. Red light blinking, manually prime it and so far only tree cups of coffee. After priming it the green light was solid and could make 3 cups then stopped. Any advise greatly appreciated.
Dec 12, 2011 | Saeco Odea Go
What does it mean when the red exclamation mark light is flashing?
Either you need to prime the pump, or the brew unit is not in correctly, the steam knob is not in the right position, the tray is missing.
Sep 20, 2009 | Saeco Odea Go
New Saeco Odeo Go has solid red exclamation mark, doesn't budge
You have to 'manually' prime the pump: When the red exclamation mark shows, press the water switch on the right side (the picture of the water drip), then open up the steam nozzle and let the machine pump hot water into a cup until the red light goes out.
Jun 11, 2009 | Saeco Odea Go
Saeco odeo giro and the red squiggly light
This is the descaling indicator.
If it flashing your machine needs descaling.
Feb 22, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeca odea giro
Sorry for the delay, i´m on sick-list and have limited access to computer.
To prime the machine you have to put a container under the steam pipe, open the steamknob on the top of the machine. Let the pump go to there is a steady flow of water then you can close the steam knob again.
I´m not sure if you done this already.
Let me know if i can help you more.
Best regards
/Mirran
Oct 09, 2008 | Saeco Odea Go
Saeco Odea Giro descaling problem
Ok first check if the machine is in greenlight state when you press and hold the water button, as it will not work when the red exclamation mark blinking.
also check if the button work at all flipping back and forth to hot water and steam.
I have never had this problem that it dident work.
But remember this, you dont have to do the descaling again as that has nothing to do with the reset.
You can even reset the descaling alarm with out having done the descaling.
If that for some reason wouldent work I would think its the CPU card is not working.
Jul 14, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Odea Go Logo
1,312 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
