Question about Microwave Ovens
HI, The water from my Aqua Guard Gold Nova does not come out but the light and the sound switches on. So someone told me that the filter might have to be cleaned or changed. Please tell me how to take out the filter from the Gold Nova and clean it and also kindly tell me where do I get the water filter for my Aqua Guard Gold Nova in Bangalore. Also let me know how much it will cost and how to fix it once I get it. Kindly help me solve this problem. Thanks and Regards, Anand
I have Aquaguard Nova from Eureka Forbes. Presently, on switching-on the water there is only beep sound for some time and then it stops. This is no music. What can be the problem? Is the water still filtered properly?
Posted on Oct 03, 2010
Yes, you need to change the filter.
Posted on May 19, 2013
My whirlpool gold GT4185SKQ-2 microwave won't heat
It's not door switch. It's the microwaves are not being produced. Do to safety issues DO NOT take apart. Replace
Jul 24, 2014 | Whirlpool Microwave Ovens
GE Microwave PVM1790DR1BB light works but no fan and the turntable does not turn
I have this exact model with the same issue. I am a technician by trade on office equipment. I took the cover off where the door latches go in and there are 3 relay switches behind there. I adjusted the switches so the door latch would make better contact with them.
May 05, 2013 | Microwave Ovens
Emerson microwave oven with grill mwg9115sl
You need to remove the top cover and the light could be seen mounted on the side of the cabin. You can access this by removing the guard and the bulb can be replaced with the same type rating. If the bulb has not fused then check on the door switch and power from the board.
Jan 31, 2013 | Microwave Ovens
I think the problem is the water isnt going in to machine. Although the moter sound like it might be going
If there is no water flows then the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Sep 05, 2011 | Microwave Ovens
Repair Manual of Aqua Guard Inova water purifier
hi,the water from my aquagaurd inova comes for two minutes and stop and green light goes off
Aug 27, 2011 | Microwave Ovens
Pasquini Livia 90 Auto Espresso Machine I suspect the control unit is failing. For some time, when cold, the machine would try to fill, or run water through the brew head when switched on. A few tries and...
It does sound that you have a problem with the control of the system and could also be the sensor.
I read about a thread for pasquini products and It seems that their technical support and parts or accessories are available through this website:
http://www.1st-line.com/machines/home_mod/pasquini/livia.htm
If you would need parts or someone to go to your place and check the unit, visit the website above.
Hope this helps!
Jun 07, 2011 | Microwave Ovens
Hi, I bought a Salton One Cup Coffee maker but it was discounted because it did not have the coffee filter and I figured I could use a paper filter which so I bought Melite filters but it did not work....
Boy I know that I like coffee as well. Can you modify the filters to work? Cut on them or what ever,all you need is the paper layer there. let me know on how it works out on here . Not real cool to give out email address on here or address,Way too many creeps out there
Feb 18, 2011 | Microwave Ovens
Can you run a microwave with nothing in it? Someone told me that just putting a sponge in it will ruin the microwave.
hi, running it with nothing in it will cause it no harm, the only object that will cause it any harm is if you place anything metalic inside it whilst it is switched on.
to clean a microwave most people place a bowl of clean water inside and put the microwave on high for 5 to 10 min doing this breaks up any grime stuck inside the microwave making it easier to wipe off, you can also put a wet cloth in a bowl and switch it on doing this does the same as a bowl of water.
so the only thing that can cause damage is anything with metal in it this will cause it to short out.
hope that has been some help to you
Aug 18, 2010 | Sharp R-1480 Microwave Oven
Goldstar MV 1501BQ microwave
It's probably a bad door switch or door switch mount.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 22, 2008 | Goldstar MV-1501 Microwave Oven
Microwave Ovens Logo
681 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
