Question about Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower
I took my filter off it had a black case around it and misplaced it. I want to purchase these part.
  • 183 Answers
Option 1: Find a local small engine repair shop. They will probably have one in stock. Either take your filter, or the whole mower with you so they can get you the correct cover.
Option 2: Determine the make and model of your engine. Plug this info into google.com and you will find many online sellers willing to sell to you.
Posted on Aug 24, 2010
Our fridge is beeping every time we open it
Check the owner's manual or Google for one. Check to see the interval in which you should be replacing the water filter. Water Filters can usually be purchased where you purchased your fridge or a big box hardware store for around $30-$40. In most cases, you should be able to reset the water filter alarm to clear the beep w/o replacing the filter.
Sep 23, 2016 | Refrigerators
What causes brown gooey ring around Dream Maker Eclipse spa and how do i prevent it
try non chlorine shock to shock it sounds like you used a chlorine product with it which will cause a gooey mess if it doesnt go away try to drain clean up everything including the filters or by new then try to use bromine that is more stabile in a spa
Aug 29, 2014 | Pool & Spa
Cabin air filter installation 2006 volvo s-80
remove the passengers side lower kick panel, it's under the glove box. it has two T25 torx screws.
Disconnect the light and move it out of the way.
You'll see a large black cover underneath the whit a/c case. The black cover will have four T25 torx screws. Remove all four screws and the cover will come off.
remove the cabin filter by pulling it through the bottom.
pay attention to the orientation of the filter. it will only go in one way.
Reassemble the same way you took it apart.
Mar 15, 2014 | 2006 Volvo S80
Will unit brew if there is no filter?
This things are very temperamental. They use air pressure to move water around. There are no filters in it.
Mar 03, 2014 | Keurig B70 Platinum 10 Cups Coffee Maker -...
My frigidare 241968503 is leaking water around where you plug the filter in?
Took out filter, placed forefinger firmly over one outlet and sucked, with my mouth on the other. heard seeping noise and found clear casing cracked very slightly where it is melded with the white front plate. This is a much simpler check before you start getting out your tools! Solution, replace filter and cross your fingers that this stuff made in Singapore will hold up for a few more months.
Mar 06, 2012 | Frigidaire Refrigerators
I have a Whirlpool AD70U dehumidifier with type 3 controls. I have the fan set to auto and the humidity to normal. The unit drains into a floor drain. It seems dry in my basement yet the fan seems to run...
If it's set for Continuous Mode the fan will run all the time. It does so, in an effort to keep recycling the air. Once it senses a rise in humidity, the compressor turns ON. Check the settings, to be sure it's where you think. Also, check and clean the air filter, if necessary. Before removing the filter, be sure to turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet. If you wash the filter, it most be completely dry, before reinstalling it. Do Not operate the unit without the air intake filter installed.
Make sure you are maintaining at least 12" - 18" clear air space around the entire unit.
To further assist you, in case you have misplaced your Owner's Manual. I have included a link to it, that you can download and print for future reference.
https://www.whirlpool.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%201188826.pdf
I hope this helped you to further troubleshoot and solve the problem.
Jun 21, 2011 | Whirlpool AD70U Humidifier
Fuel filter on picaso 2.0 litre diesal engine
Black smoke from a diesel engine does not mean you have to change the fuel filter.It is caused by the air filter being dirty.That you need to change.Anyway if you want to change the fuel filter it is located at the front middle of the engine in a black plastic round case with notches around the top.Good luck hope that was helpfull.
Jul 29, 2009 | 1987 Peugeot Liberte
How do you remove the fuel filter on a peugeot 307 hdi?
open the bonnet. Look where the Clutch & Brake Oil Pan is. Right under this on Engine there is a black plastic round shaped with fuel pipes for inlet and outlet. Remove the car battery from tray (you need rachet with long beck to open bolt). From this side have a look and you'll find a bolt (need star key screw driver) open this bolt remove inlet and outlet pipes by pressing the button like lockheads on these pipe ends and pulling outside and the power adapter plug below the filter.Pull the filter ( you might be needed to remove turbo air filter case and pipes in case if the filter is stucked with a leg in the engine bracket). Here is your Diesel Filter in your hands. Took me about two hours for replacing the filter.
Jul 20, 2009 | Peugeot Square Case with Crystal Bezel...
Took transmission pan off and can't find filter
2002 Hyundai Elantra has 2 trans filters. One is inside the pan which is mounted vertically. The other is located on top of the transmission case.
Apr 22, 2009 | Hyundai Motor 2002 Elantra
The Aprilaire is leaking around the casing attached to furnace
How old is the filter? Filters should be replaced every year. If its a new filter check to make sure the little hose is inside the hole at the tom of the filter.
Jan 18, 2009 | Humidifiers
Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower Logo
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
