Question about RCA D52W19 52" Rear Projection Television
The glass 6a 125 vac fuse blows when plugged in. what is the next step?
T3.15ah250v is ok t6.3ah250v is not ok Tried both 6A glass fuse and f6.3A separately. Both blew up as soon as i turn on power. if i change it with the exact the same fuse, it will fix the problem?
A fuse that blows out is an indication of something seriously wrong. If you don't find the problem, not matter what fuse you put in, it will blow it out. You cannot use a bigger fuse because it will burn out other parts. This could be a bad transformer, diode, capacitor, or voltage regulator or IC.
Jan 07, 2017 | Cars & Trucks
What is the fuse or fuse code for a Panasonic CT-32HL43
Some advice here;
The fuse is in a snap in holder and marked on the board and fuse as (look and see) 6.3 A 125 vac= 6.3 amps at 125 volts (a 250 rated fuse will also be fine as it is just max voltage rating).
In this case what I have seen is do not use a generic fuse like from Radio Shack as it likely will blow instantly for no reason.
We discovered early on (shop where I work) that both Panasonic and Sony (use same fuses) had this issue.
Do not exceed the amp rating for any reason---if a compatible fuse blows instantly then a short exists---if fuse where power cord enters either just the fuse or a short at the input area of the set's power supply.
to reply or ask more press the "make a comment button" on this page.
Mar 25, 2012 | Panasonic Televison & Video
Fuse type for onkyo a-9555
The main power fuse for most amplifiers is a fast blow, 125 volt fuse for the US and a 250v fuse in countries with 220v. This unit is 125 watt so the main fuse should be 2 amps or so. The correct fuse size is written on the circuit board next to where the internal fuse was located.
Feb 23, 2012 | Onkyo A-9555 2-Channel Amplifier
We have a GE prelit christmas tree for (this is the 3rd year). everything fine until last night when a fuse blew. we replaced with the extra fuse supplied and it lit again. on the plug it says 'use only...
the candles will not have had anything to do with the fuse blowing on your tree the fault is soley with the tree fuses are available at any good electronics parts store just make sure you only use 120v 6amp if the fuse blows again you have a serious fault with the tree and dont use the lights.
in some cases fuses blow on there own fault so if the fuse last then it was simply a worn fuse
best of luck
merry christmas
please take the time to rank this advice
Dec 07, 2010 | Heating & Cooling
Landice l 7 when turned on nothing lights up and nothing happens its dead
In order to do any of these tests you need to have a familiarity with electricity and a working knowledge of a voltage multimeter, if you don't then call a professional!! With that said you will need to remove the motor shroud then proceed with these steps:
1. Set your volt meter to AC volts, we are going to trace the power from the wall outlet through the treadmill to see where it ends.
2. With the treadmill unplugged, test the wall outlet. You should have from 115 to 125 VAC. Optimally, you will have at least 120 VAC.
3. Follow the power leads from the power cord to the lead ends. With the treadmill unplugged, connect your meter to the lead ends. Plug the treadmill in and check your reading. It should be the same as your reading from the wall outlet.
4. Continue this process with the electrical system, following the leads, as they pass through, breakers, fuses, and the like.
5. Where the power flow ends is where your problem is. Sometimes it will be in a bad connection, sometimes it will be in a shorted breaker or ( when checking the fuse unplug unit then check for continuity) blown fuse or a loose fuse in fuse holder, at times it may be as simple as a safety switch not working properly, or it may be a major problem with a component. If fuse is blown get the exact fuse ( 15 amp ceramic fuse) if it blows the fuse again, then you have a direct short in the Motor Control Board and will need replacement.
Jun 30, 2010 | Landice L7 LTd Pro Sports Trainer...
Blew a fuse what kind dose it take is it a slow blow fuse or fast blow one,i took out the old fuse and it reads le.3a/250v is it a 3a or .3a
It is a 3A/250V fuse, also known as a 6A/125V fuse.
Power amps generally have slow blow fuses.
If this is helpful, please be sure to hit the "Thumbs-Up" for me!
Jan 24, 2010 | Polk Audio PSW202 Subwoofer
No Power on rt2580
According the parts list on the model unit your fuse is suppose to be F101,FUSE 6A 125V. Is it possible that you have an undersized fuse?
I don't believe that one amp differents would cause your unit to blow like that but, you never know. More than likely you have a bad component in the power supply or power amp.
Then again, with an average replacement cost of $150 online; it not worth getting too deep into the repairs.
Jan 29, 2009 | RCA RT2500 System
RCA HDTV R52WH74YX61 blown fuse
there are 3 small red rectangular shape objects to the right of the flyback transformer these are fuses the fl231 most time goes bad .fl231 is the location number under the green circuit board. the location number can also be wriitten on top(brown side of the cicuit board)
you may have to put back the .6a you took out was it ok?
TRITRONIC ELECTRONICS sell parts . cathray 416 241 1106 sells also
Nov 22, 2008 | Televison & Video
RCA D52W19 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
