Question about Logitech Computers & Internet
My keys are either not ttttttttttttttyping at aall or do like the t above. More pressure on keys helps.
    Scholar:
  • 85 Answers
I assume you have windows.
open start menu
all programs
accessories
ease of access (also called accessibility on xp)
select on-screen keyboard
its a bit slow but it will get you by until you can fix the problem or get a new keyboard. below are three possible alternative solutions:
1. If it is a wireless keyboard then try to change the channel its a little button on the bottom of the keyboard.
2. If its a wireless keyboard change the batteries.
3. If the above two solutions do not help then either carefully take apart the keyboard and clean everything (if you suspect something was spilled on the keyboard) or if its just an old keyboard then the contacts need cleaning they look like little round rubber dots on the bottom of the keys mashing little grid like symbols on the clear plastic sheets. I usually clean the clear plastic symbol parts with a rubber pencil eraser very gently and the black dots below the keys i clean with just a paper towel. I don't use cleaning solutions and try and keep it all dry. remember less scrubbing is more. Look at the unused keys like z to see how they are supposed to look. and good luck. but its easier just to buy a new one.
Posted on Aug 24, 2010
Clutch master cylinder not bleeding.
you will have to bench bleed the line to get aall the air out
Oct 16, 2013 | Cars & Trucks
How can i find out my encription code for my asus eeepc
The encryption code is in your router's wireless setup.
To connect your computer to a wireless router, you click the Refresh network list, then Choose your wireless network and then click Connect to your secured Wireless Network, it will asks for a Network Key before allowing you to connect into your wireless network. This Network Key is either the WEP, or WPA or WPA2 Encryption key that is configured in the Wireless settings in the Router. The Passphrase is an alternate way to setup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrase or WPA or WPA2 key that was used to configure the Encryption key in the wireless router. http://www.fixya.com/support/r5270415-network_password_network_address For information on securing your wireless network, configuring the wireless router and configuring the wireless card in the laptop/computer, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Mar 28, 2013 | ASUS Eee 4G Notebook
Just need to know what button to use to turn on wi-fi for an Acer Ferrari 1000 laptop. Thank you
There is a button in the middle-front of your laptop that will turn on wifi. It has an image of two ovals and a stick on it.
For more information, I have provided a link to the manual for your model below. Information about the wifi switch is located on page seven, specifically number seven on that page.
http://tim.id.au/laptops/acer/ferrari%201000.pdf
Hope this helps.
Mar 15, 2011 | Acer Ferrari 1000-5123 Laptop
An signal, in the form of an exclamation mark, is appearing on my dashboard. What does that mean?
you need to add air into your tires. put 36psi on all 4 tires and drive vehicle for about 2 miles or less at at least35mph and if all sensors and systems are ok, light will go out. if only 1 tire os low and other 3 are not, than you may have a nail in the tire causing a leak, which causes low pressure, which causes the light to come on. start with adding air to 36 pounds to aall 4 tires.
Dec 23, 2010 | 2005 Nissan Quest
Kitchenaid Hinge tensioner
It is aall exposed on the outside of the unit. Discconecct the water, remove the two set screws attaching the unit to the counter, slide it out and you will see the damage left or right. The white plastci piece slips off over the metal clip and you re-attach the string, apply pressure to the spring and slip the platci piece back over the metal and you are done. You will spend more time removing the unit than repairing it.
Dec 31, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
It wont start
Assuming that the connections are correct, you could have dirty battery terminals, bad starter-motor, blown fuse, bad iginition-switch.
If aall the above are good, take out the starter-motor to a shop to test it.
Nov 17, 2009 | 1997 Ford Escort
My acer mic does not work. pls help
U HV SETTTING OR NOT IF NOT DN GO TO THIS PATH OKK ""START MENU------>ALL PROGRAMS--->ACCESORIES--->INTERTAINTMENT---->VOLUME CONTROL--->CHEK UR AALL CHECKS KK IF UR MIC NOT SHOW IN UR VOLUME CONTROL IF ANY OTHER PROBLEM CONTACT US SWATI27M@GMAIL.COM
Feb 19, 2009 | Acer Aspire 5610-4648 Notebook
Car breaks up if you give it gas to fast
gas filter look like low gas pressure
Sep 30, 2008 | 1996 Chevrolet Camaro
Computers & Internet Logo
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
