Question about Canon imageRUNNER 5570 Copier
I'm having trouble finding the waste toner cartridge. Where is it?
  • 1,219 Answers
the wast toner box is located on right sideway of copier in lower right section, covered with marrow and long plastic cover, right from paper pass and bypass door.
Hope that helps!
Posted on Aug 24, 2010
Can I reuse excess toner from printer cartridge?
It can be rescued, but the trouble and mess that you will endure is often not worth the challenge. Send the cartridge in for recycling and score some environmental friendly karma instead. Most office supply stores will accept them.
Nov 30, 2013 | HP Office Equipment & Supplies
Changing waste container
The is no waste container on Phaser 6500. There is a "waste collection box" in every toner cartridge and the waste toner is discarded along with the empty cartridge. The is also a waste toner reservoir on the transfer belt and this one will be replaced along with the transfer belt.
If there is an error message saying, for example, "Waste Full Cyan Cartridge", it means the waste toner counter reached the replacement value for that color and you have to replace the corresponding cartridge. But the waste collection box is not really full.
Sep 30, 2012 | Xerox 6500/N Phaser Laser Printer
HP1022N laserjet printer there are black specs along the printed page. looks like toner smudges.
toner specs are usually caused by a bad cartridge. If it is a refill, it is possible that the waste toner bin was not emptied when cartridge was refilled. Try different cartridge as your first trouble shooting step.
Jul 22, 2011 | HP LaserJet 1022 Printer
Hl3040cn prints a black stripe down the page despite the drum being cleaned as advised by Brother.Peter
Hi
3 issues might be the problem.
1. The toner waste compartment is full. You need to clean the toner waste compartment located in the cartridge itself.
2. Roller drum inside the cartridge have lines normally starts on both ends of the drum. This due to bulky printing. Check and replace this parts inside the toner cartridge. Manual cleaning is not advisable because the result will still the same. If you have only toner cartridge, use the roller drum and replace in place of it.
3. Faulty Toner Cartridge that cause leaking the toner powder. If you purchase remanufactured toner cartridge or you refill the toner cartridge. It tends to worn out the parts. Normally starts as roller drum and follows with the other parts. Replace new original Toner Cartridge. When you refill the toner cartridge, you need to clean the waste compartment as well as it will later be full and overflow.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
May 15, 2011 | Brother HL3040CN Laser Printer
My machine says Drum Error, refer to trouble shooting for maintenance?
Drum Error:
The corona wire on the drum unit
needs to be cleaned.
Clean the corona wire on the drum unit.
(See Cleaning the corona wire on page 122.)
or
The drum unit has reached the
end of its life.
Replace the drum unit.
(See Replacing the drum unit on page 130.)
and/or
Open the front cover
press Clear/Back
Press Start, then 00
after the screen show "accepted"
close the front cover and you are good to go.
Feb 03, 2011 | Brother MFC-7340 All-In-One Laser Printer
Waste toner gets full before toner runs out
Actually, the waste toner should get full sometime before the regular toner runs out in laser printers that have several toner cartridges compared to the single waste toner reservoir.
You can dump the toner reservoir out and avoid buying the empty waste toner 'reservoir.'
I did this on my Brother Laser printer and saved about $30 or so for an empty plastic waste toner bottle or jar.
If this is the way the Kyocera-4020DN is, then I would put the waste toner, which is just that, waste, and put it into a plastic zip loc storage bag and throw it away. Don't breath the toner.
Good luck on this repair.
Jul 19, 2010 | Office Equipment & Supplies
Toshiba E-Studio 202L cartridge does not match manufacture
Did you replace the waste (used) toner cartridge or the empty toner cartridge? These copiers have 2 "cartridges" .... one is waste (used) toner, the other is "new" toner for copying / printing etc. Some newer copiers have All in One units....Drum, New Toner, Waste (used) Toner. If you replaced the Waste Toner container (or dumped it) that should reset the code or error message.
Jun 23, 2009 | Toshiba e-Studio 202L Copier
Canon imageRUNNER 5570 Copier Logo
49 people viewed this question
old marine
old marine
