Question about Manitowoc 450 Lb Ice Cube Machine Self Contained Air Cooled SSeries SD0452A
I have a Manitowoc s-450 with a AuCS-SI installed and it is set to not clean at this time. The machine is stuck in cleaning mode and is partially refrigerating. I disconnected the AuCS and it works fine. What do you think is wrong?
  • 32 Answers
When a Manitowoc goes into clean mode,It stays in clean mode until it finishes.If you turn it off and then on again,it just keeps cleaning.Let it run in cleaning mode until it finishes
Posted on Sep 16, 2010
  • chillerman1 Apr 22, 2011
    turn switch OFF-ICE-OFF-ICE-OFF-ICE to unlock the rinse cycle....visit www.hvacphilippines.com for more info.
    Chillerman
How do i change control board of my ice machine become my father take off the control board
First do you have the new control board ? If not then you need to get with a supply house that sales Manitowoc parts. Now if you have a board or have bought one the here goes. Looking at left top corner of board there is a AC Line voltage electrical plug ( numbers marked on wires ) There is only one that will plug into it. Under that there is a main fuse (7A) then under that is a Automatic Cleaning system (AUCS) accessory plug you wont use it. Under that is the ice thickness probe (3/16 ) connection Marker 1C check water thickness probe and follow wire back to end and plug it to 1C. Now under that one is a spade marked 1F that is the Water level probe terminal go to water level switch in sump tray and find the wire that goes to it and put on 1F. Under water level spade is another spade marked 1G this on is not used on this model. At the left side bottom of board is another plug in this is the DC low voltage electrical plug the numbers are marked on the wires that plug into it there is only one plug that will plug into it.
Jan 20, 2015 | Manitowoc QY-0134A - Ice Machine, Cuber,...
My manitowoc new ice machine is not making ice
Its plug and play. You need to call who ever sold it to you and have it checked out its under warranty.
Sep 24, 2014 | Manitowoc Indigo Ice Machine - Full Dice,...
We have ice maker which shows off /on mode
Make sure it's not in clean mode... needs to be in ice mode
Aug 24, 2014 | Manitowoc ID1202A-261 Dice Cube Air Cooled...
How to clean a qyo214a manitowoc ice machine
cleaning manitowoc ice machine video. discale
May 15, 2014 | Refrigerators
Sd0452a stuck in clean mode
When a Manitowoc is turned on in clean mode, It stays in clean mode until it finishes (about 30 minutes).If you turn it off and then on again,it just keeps cleaning. Let it run in cleaning mode until it finishes then turn the witch to ice mode.
Mar 25, 2014 | Manitowoc Kitchen Appliances - Others
Manitowoc ice machine freezes
most likely you have bad ice thickness probe.
Aug 31, 2013 | Manitowoc 450 Lb Ice Cube Machine Self...
Cleaned machine now stuck in harvest and dump valve will not close
There is a little finger that the door needs to hit to get it back to the freeze mode...You don't have the door in the correct position...
heatman101
Aug 26, 2010 | Manitowoc Koolaire Undercounter Freezer...
How Do I maintenance a manitowoc series 150 ice machine
find the filter remove clean with water, coils should be shiney. This should fix the problem
Apr 23, 2009 | Manitowoc MAN-KF6E Koolaire Undercounter...
Manitowoc 450 Lb Ice Cube Machine Self Contained Air Cooled SSeries SD0452A Logo
517 people viewed this question
Top Manitowoc Kitchen Appliances - Others Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
George Merkley
George Merkley
Are you a Manitowoc Kitchen Appliances - Other Expert? Answer questions, earn points and help others
