Question about Microwave Ovens
I have a honda vtx 1300 motorcycle . after a short ride I pulled it in the garage and it began to leak (I mean dump) oil all over the floor. Is it the oil pump? or a line , seal , gasket?? help!!
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010 might have better luck finding a solution for your problem if you post it under another heading. You posted this question under "Microwave Ovens".
  • Microwave Ovens Master
  • 9,098 Answers
Was it overfilled?
Does it have a PCV valve?
Posted on May 10, 2008
I have a lg microwave oven model mc-2681ds stopped working the service centre people say its circuit board needs to b replaced . coz of 6-7years old model the company doesnt have its spare circuiT.
Before you dump it, if it is totally dead with no lights or anything, I would check to make sure that the fuse inside is okay. Make sure that the unit is unplugged and turn it around and take the screws out that hold the cover in place and then remove the cover. Look for where the power cord goes into the back of the microwave and follow the black wire from the cord to wherever it ends. It should end at either an inline fuse folder or at a small circuit board. If it goes to a board, your fuse will be mounted on that board. Remove the fuse and have it checked with a multimeter set for continuity. If it is bad, replace it with the same size fuse, you will find the size stamped on one of the silver bands at each end of the fuse. It will be either a 15 amp or 20 amp fuse usually. If you put in a new fuse and it blows right away, that means you have a short somewhere and you would need to have a repair tech look at it. Hope this helps!
Jul 02, 2015 | LG Microwave Ovens
Most of the time P relates to Power. Microwave cooking Power at level 10. P10 is most likely the highest cooking power setting. If this is in error - Google the information - Or youtube it..
Aug 05, 2014 | Panasonic Black 1300-Watt Counter Top...
Microwave plug started melting and is leaking what appears to be oil
Replace it. it may have a short near the plug causing it to melt. if the wires touch you may have a fire on your hands.
Nov 10, 2013 | Whirlpool MT4155SP Microwave Oven
My refrigerator has a leak behind the drawers on the inside . I have since had to put a towel at the bottom of the drawers or it will start leaking down the front and onto the floor every couple of days....
Moisture condenses out of the cold air inside the fridge. Many refrigerators have a drain tube in the bottom to allow the condensate to run into a drip tray under the refrigerator (behind the trim panel on the bottom) where it evaporates. Over time this tube can get clogged by food particles and the water backs up, eventually running over the bottom edge onto the floor. You can use a straightened out coat hanger or other stiff wire to clear it out. This should get the water back into the tray where it belongs.
Jan 21, 2011 | Microwave Ovens
After about 2 weeks of use, the microwave began to make a horrible buzzing noise from the "box" in the upper right hand corner on the back. It also smelled horrible. It then proceeded to stop working...
Two weeks? This is a warranty problem. The buzzing noise was probably either from high-voltage arcing or an overloaded transformer trying to drive a shorted component. The smell is from something electrical getting fried. Remember it; the next time you smell it, you'll know to pull the plug.
Oct 12, 2010 | Sunbeam SMW777 Microwave Oven
How do I get the "surround" panel off ? My JE2160 keeps shorting out when the door latch release is pushed.... wondering if it is a circuit in my garage..... or something wrong with microwave. Would...
You have a serioius problem which requires professional intervention. Your oven should Never 'arc' between the door and the cabinet. Evidently, the oven is charging the door (which should not happen) and the charge is not properly leaking to a proper ground.
Thanks for your interest in
Oct 03, 2010 | GE Microwave Ovens
While cleaning it the vent began to open and close and the microwave would not shut the vent down when the keypad was used to end the cycle. Now it only shows F3 on its screen when we try to set it up...
The "F3" error code means "Shorted key panel (touch pad)". The correction is to replace the key panel aka a membrane switch or a touch pad. The control panel in that case is just a plastic frame.
please rate this help to keep us online
Aug 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool MH2175XS microwave/hood combo with oil leak, etc.
This is a very wierd problem that we have been dealing with for years, and never seem to get a correct answer. Have actually seen green slime like oil inside the units before. From what we have heard, is that this oily substance is actually coming out of the blower fan assembly inside the unit. Its like bearing oil from the center support shaft. Will go away over time, but the fan may or may not go bad. Good luck with the mystery oil.
Jun 11, 2009 | Whirlpool MH1150XMQ Microwave Oven
hi my name is mark, if nothing boiled over in the microwave. the oil could be coming from a capacitor in the microwave oven. i would call for service before it fails.
Mar 16, 2009 | Frigidaire GLMV169D Microwave Oven
Microwave Ovens Logo
55 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
