Question about Jensen XS1693 Coaxial Car Speaker
On the Jensen XS 1693 car speaker which is the positive terminal white or black
    Problem Solver:
  • 7 Answers
In a speaker, there really is no pos or neg- there is however phase- that is the concern of the given that a speaker is a in/out kind of thing so that where two or more speakers are gathered together there is phase in the midst of them...they all do the in/out thing together. Also keep in mind it's AC. Use the colors of the wire leads as a reference to the other speakers leads- meaning -one can reffer to either lead as pos or neg as long as any other speaker on that system had the same wir
Posted on Nov 02, 2011
Are Jensen XS1010's single voice coil or dual voice coil?
An SVC speaker has one pair of terminals; a DVC has two.
Mar 07, 2016 | Jensen XS-1010 Car Subwoofer
I have no harness labeling ground, hot or speaker wires, I need diagram
Alot of new stereos have an ISO color code,
This is mine:
Car Radio Constant 12v+ Wire: White/Green
Car Radio Switched 12v+ Wire: White/Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Yellow/White
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Blue/Green
Left Front Speaker Negative Wire (-): Gray/Black
Right Front Speaker Positive Wire (+): Red/Green
Right Front Speaker Negative Wire (-): Brown/Black
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Blue/Yellow
Left Rear Speaker Negative Wire (-): Gray/White
Right Rear Speaker Positive Wire (+): Red/Yellow
Right Rear Speaker Negative Wire (-): Brown/White
Apr 25, 2011 | Jensen Car Audio & Video
How do I bridge my jensen 200watt bridgeable amp
To bridge an amp, connect the negative speaker lead of a speaker to the negative terminal of the first channel, and the positive speaker lead of the SAME speaker to the positive terminal of the second channel.
Mar 20, 2011 | Jensen Car Audio & Video
What wires are for what on my kd-g200
The cables for you In-Car stereo are as follows:
Black - Earth to to the chassis.
Yellow - Live that should be connected directly to the car battery and not the igniton.
Red - To an accessory terminal in the fuse block.
Blue / White stripe - To remote antenna (if fitted)
White / Black stripe - Front left speaker (negative terminal)
White - Front left speaker (positive terminal)
Grey / Black stripe - Front right speaker (negative terminal)
Grey - Front right speaker (positive terminal)
Green / Black stripe - Rear left speaker (negative terminal)
Green - Rear left speaker (positive terminal)
Purple / Black stripe - Rear right speaker (negative terminal)
Purple = Rear right speaker (positive terminal)
That covers all off the cables that you should have with the car stereo.
Apr 11, 2010 | JVC KD-G200 CD Player
Just need a pic to see what color wire goes to each of the 20 pins on the back of the deck
Wiring Diagram / Color Codes
1. Power Antenna (dark blue wire) - Connect to power antenna or amplifier.
2. Ground (black wire) - Connect to ground terminal or clean, unpainted part of chassis.
3. Memory/Battery (yellow wire) - Connect to battery or 12 volt power source that is always on. The radio will not work if this wire is not connected.
4. Accessory/Ignition (red wire) - Connect to existing radio wire or radio fuse.
5. Left front speaker - White/Black is negative, White is positive
6. Right front speaker - Gray/Black is negative, Gray is positive
7. Left rear speaker - Green/Black is negative, Green is positive
8. Right rear speaker - Violet/Black is negative, Violet is positive
9. RCA Outputs to Amplifier - Black is front, Gray is rear
10. Auxiliary Input Cable
11. Subwoofer Output
12. Antenna
13. CD Changer
The manual is available here:
http://diversesolutions.org/files/CD4610.pdf
The wiring diagram is under the section Wiring.
Jan 13, 2010 | Jensen CD4610 CD Player
Color codes for my jvc arsenal kd-ar560 wire harness
Hello jlj2382,
Here's the wire colors for your KD-AR560:
Black = Ground (to vehicle chassis)
Yellow = Constant 12V (power)
Red = Accessory (to vehicle accessory terminal)
Blue/White = Remote turn-on lead (to remote amp)
Orange/White = Illumination (to vehicle light control switch)
Brown = Cell Phone terminal
White = Left Front Speaker positive (+)
White/Black = Left Front Speaker negative (-)
Gray = Right Front Speaker positive (+)
Gray/Black = Right Front Speaker negative (-)
Green = Left Rear Speaker positive (+)
Green/Black = Left Rear Speaker negative (-)
Violet = Right Rear Speaker positive (+)
Violet/Black = Right Rear Speaker negative (-)
Hope this helps.
Apr 24, 2009 | JVC Arsenal KD-AR560 CD Player
Dont know how to wire a subwoofer
The Jensen XS1010 is a 4-ohm sub and should work properly off of the outputs of most any single channel monoblock sub amp or off a bridged 2-channel. You did not say what brand or type of amp you intend to use, but in any case, there's only 2 wires to connect to the sub, one positive (+) , the other negative (-). Simply match them up with the positive and negative on the amp speaker output and you are ready to bump.
Here's the link to Jensen's website:
http://mobile.jensen.com/jensen/
I'd recommend downloading the XS1010 manual. They recommend an enclosure with at least .75 CuFt internal volume.
If this helps, please rate it as "FixYa". Thanks!
Mar 28, 2009 | Jensen XS-1010 Car Subwoofer
Car radio wiring color coding.
Specifically for what make and model of head unit pls?
Most current car radio would be using:
Yellow - +12V Constant Power/always on such as the battery's + terminal
Red - +12V Switched (accessory) Power such as the ACC terminal of the ignition switch
Blue - Power Antenna
Blue/White - Amp Turn-on
White - Left Front Positive Speaker Wire (LF+)
White/Black - (LF-)
Gray - Right Front Positive Speaker Wire (RF+)
Gray/Black - (RF-)
Green - Right Rear Positive Speaker Wire (RR+)
Green/Black - (RR-)
Purple - Left Rear Positive Speaker Wire (LR+)
Purple/Black - (LR-)
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 19, 2008 | Car Audio & Video
Jensen Bass Boost CR220x
white/black is speaker positive
white solid is speaker ground front and back ground
gray/black is speaker ground front and back
the solid black wire is battery ground
Apr 13, 2008 | Jensen SCR-60 Stereo Cassette Player with...
Wires came out of the plug
From Pioneer Electronics Support Website Yellow - To terminal always supplied with power regardless of ignition switch position. Red - To electric terminal controlled by ignition switch (12 V DC) ON/OFF. Black (ground) - To vehicle (metal) body Blue/white - To system control terminal of the power amp or Auto-antenna relay control terminal White - front speaker left + (positive) White/black - front speaker left - (negative) Grey - front speaker right + (positive) Grey/Black - front speaker right - (negative) Green - rear speaker left + (positive) Green/Black - rear speaker left - (negative) Violet - rear speaker right + (positive) Violet/black - rear speaker right - (negative) Best of Luck.
Sep 09, 2007 | Pioneer DEH-P3800MP CD Player
Jensen XS1693 Coaxial Car Speaker Logo
133 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
