Question about Toshiba Gigabeat S30 MP3 Player
Its no charging and and on screen it shows "5 contact manufacturer for repair"
4 Suggested Answers
  • 12 Answers
SOURCE: gigabeat screan read contact manufacturer fo repair
You've either got the wrong battery or did something wrong when you installed it. You must make sure that the main power switch at the bottom is turned off.
Posted on Dec 10, 2007
  • 5 Answers
SOURCE: MES60V suddenly stopped charging.
Download, and install the firmware. It should work after that. It might of formatted the storage partition of the device, but you can resync it after you update the firmware on the device. You can get the firmware here: Gigabeat S Firmware.
Posted on Apr 04, 2009
SOURCE: will not turn own it reads contact manufacturer for repair.
The hard drive became disconnected. I took out all of the screws to the outer case (5), gently slid cover down until the small ribbon connector for the power buttons is exposed, unclip and remove. Set aside back of unit (at this point the hard drive might come with it if the ribbon has come out of the back) at the top there is a two screw metal bracket that covers the ribbon connection for the hard drive. Remove the ribbon from the main unit and gently force it back into the hard drive ribbon connector. once fully seated you can reinsert the other end, replace the two screw bracket in a way that holds the ribbon down. Slide the backing back far enough to reinsert the power buttons ribbon connector and then test it before you throw in those last 5 screws.
Posted on Jul 23, 2009
El panel me informa ERROR DE SCANER 5 ,que debo hacer?
Contact HP immediately. They offer a free repair on this unit and problem for any machine manufactured before January 1, 2010. Check your serial number label on the back, it will show date of manufacture. Be insistent, some HP agents and dealers are not aware of this free repair.
Feb 04, 2011 | HP Laserjet M2727nf Multifunction Printer
Even when charged overnight i dies in 4 to 5 minutes
Sounds like you need a new internal battery. Contact the manufacturer for repair centers.
Jan 28, 2010 | Audio Players & Recorders
Touchscreen does not work
Ok, remove the battery for 5 minute to reset the internal programming. once the 5 minutes are up, re insert the battery and power up. if the screen is still unresponsive, you will need to contact your manufacture for a repair ticket. the internal software that is used for collaborating the touch screen has failed.
May 22, 2009 | LG CU500 Cellular Phone
After 15 minutes tv turned on screen goes funny
contact the manufacturer if the problem is serious or else try loosing tje static charge from it and restart
May 07, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Gigabeat MES60VK - Error # 5
It just went off and when it was turned on the screen says 5 in a yellow triangle (Error 5?) Contact Manufacturer for repair. Toshiba could not help.
Did anybody found a solution to this problem yet? is it worthy to try to repeir it? please let me know moisilayo2002@yahoo.com. I really appreciate it. Thanks!
Nov 08, 2008 | Toshiba gigabeat MES60VK Digital Media...
It won't charge
Hi, The problem lies with the battery. If you are within the 90-day warranty, the unit can be replaced. If you are out of the 90-day warranty, contact the manufacturer for a replacement battery. Keep in mind, to replace the battery, if you are handy you can do it yourself with a soldering gun. If not, take it to your local repair facility. It should not take more then 5 minutes to replace the battery. The cost for a battery is a $6.00 Money Order. Contact Coby Consumer Care / Technical Support
  • Toll-free: 800-727-3592 (8:30AM to 9:00PM on weekdays, 9:00AM to 5:30PM on weekends)
Thanks, Mike
Oct 29, 2008 | Coby MP-C7085 MP3 Player
Jun 17, 2008 | Toshiba gigabeat MES60VK Digital Media...
Konica minolta dimage a1
Sounds like a CCD fault. Many A1 users, including myself, have had this. Allegedly, Sony, who made and fitted the CCD sensors, had a manufacturing "issue" at the time. Many A1s were recalled and others, including mine, have been successfully repaired free of charge by Sony on request. I suggest that you contact your vendor or a local repair shop to discover whether this service is (still?) available in your location. It's well worth the effort as this is a fine camera. Good luck.
May 29, 2008 | Konica Minolta DiMAGE A1 Digital Camera
Monitor stops display
most likley the monitor has an internal power supply failure, generally the cost of repair could be higher than buying a new one.If your monitor is still in its warranty period contact the manufacturer,if not do you know of a local tv repair shop that provides free estimates to confirm cost of repair vs. replacement?
Dec 14, 2007 | ViewSonic VA1703wb Monitor
Black screen after 5 minutes of use with Fujitsu PDS-420 plasma
Sorry to inform you my freind, but the main board has to be replaced in this beast. Could get expensive. there are no schematics and or componets listed to repair this module. Its a board level repair only. Try going to ptscorp.com, find their phone number, and see if they repair these boards. if not you will need to contact the manufacturer for replacement boards. good Luck Please do not forget to rate this thread.,
Dec 15, 2006 | Fujitsu Plasmavision PDS-4209 42 in....
Toshiba Gigabeat S30 MP3 Player Logo
26 people viewed this question
Top Toshiba Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Electro Med Services...
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
