Question about HP Pavillion s7420n PC Desktop
My computer went into sleep mode and will not wake up. When I turn the monitor on it says it is asleep and then goes black. I connected the monitor to an old laptop and it worked, so the problem seems to be my computer.. it is not sending a signal to the monitor or the keyboard. The mouse light is on when the computer is on, so it appears to be receiving a signal. HELP!
    Problem Solver:
  • 17 Answers
You may try hitting the sleep button again
or
switch of main switch an wait for about 1 min
and try switching it on again
Posted on Aug 24, 2010
My monitor won't come out of sleep mode
when the computer enter the sleep mode, it is possible that the computer remove the check mark from this output activation.
When you have multiple ouptut like a internal LCD and output on a monitor, when going into sleep then waked up, laptop reactivate the internal LCD without reactivated the secondary monitor.
you could need to go in desktop property and reactivate the secondary monitor with the check mark listed : Activate.
If you only have one monitor but still a dual output card or two separate video card same thing can happend. try to connect the monitor on the second VGA or HDMI output and see if the video goes there.
then reactivate your secondary output and make it principal.
Does also happend when your computer is connected to a UPS power and your monitor is directly on the sector. (laptop issu also)
if a brief power outage arrive then the monitor shut down (no power) and the computer continu, as there is no monitor on the output any more Windows will automatically deactivate this monitor. when power goes back, this output is no longuer providing video. I suggest putting the monitor on a UPS as well.
Jan 03, 2014 | Westinghouse Electric L1916HW 19" Monitor
I wiped off my computer keyboard and did npt notice anything happened when I did. When I went back to use the computer, the yellow "sleep" light was on as it usually is after sitting a while. I...
You might have put the computer into hibernate; have you tried pressing the power button? It should wake the computer up if it is asleep or hibernating. It is also possible that your monitor cable is unplugged.
Mar 07, 2011 | Sony VAIO PC Desktop
HP Pavillion a6230n Desktop PC sleeping mode is not working properly. After it entered into Sleep mode, it will keep waking up as long as the Internet cable is plugged in. Any other computer can sleep...
Click on Start, Control Panel, Network Connections, Right click on local area connection that is connected and click properties
Under networking tab, click configure. New window opens, then click on last tab power management, take check mark out of "Allow this device to wake the computer" then click "OK"
Nov 30, 2010 | HP PAVILION A6230N DESKTOP PC
Dell monitor - when I put it in sleep mode (press the on/off button)it doesn't want to 'wake up' again when I return. I press the on/off button and briefly see the screen, then it goes black again. What's...
Computer is asleep or the controller board inside is failing to pick up the signal from the computer or you got a loose connection ether or here you need to check the computer and rule out the possiabilites.. From there if that does not wrok the monitor is going to need to be fixed.
Sep 17, 2009 | Dell Dimension 3000 PC Desktop
Sleep mode wakes up on it's own
turning off all the power saving items does not help this- it just ensures that it doesn't automatically power down your hard drive or shut off power to your monitor automatically when you aren't using it.
May I suggest Hibernation Mode as an alternative? this mode saves everything you are doing to disc and shuts your computer down completely. when you turn it back on, it will restore what you were last doing onto the screen, so you can pick up where you left off.
you can find more information on this and sleep mode from here: http://windowshelp.microsoft.com/Windows/en-US/Help/335c6a5d-0304-4af1-b135-6bf6c124dc111033.mspx#EZAAC
Cheers,
-Demolitio
Aug 03, 2009 | Microsoft Windows Vista Home Premium with...
AOC Monitor says "no signal" and won't wake up!
This monitor refuses to wake up because it cannot find the signal from the computer.
When the light is amber, force the pc to shut down by holding the power button until all lights go off. Then, after about 10 seconds, power the pc back up again.
If this does not start your monitor, unplug all the monitors connections and plug them back in again. These things should reform the connection from the pc to the monitor.
good luck
tony
May 18, 2009 | Computers & Internet
Monitor displays slowly after the computer starts.
try to turn off you screen saver just turn off power monitor to see monitor easy wake up after long time.if ok means windows screen saver have problem if still same look like is you monitor something wrong need to check
Jan 03, 2009 | Dell Dimension 2400 PC Desktop
Works when it wants to then turns whie with grey line in it
Hi
If only the monitor is going to sleep, then it could be a problem with the connection from the monitor to the computer or with the cable.
If the computer goes to sleep and if you are not able to wake it from sleep then check the sleep mode settings and also the power management settings for the keyboard and mouse.
You may also do a system restore if you are not able to wake the computer from sleep.
Feb 24, 2008 | Sony SDM-HS73P 17" LCD Monitor
My monitor is in sleep mode and I cannot get it out if it.
Sleep Sleep is a mode that the computer enters after being inactive for a set amount of time. Commonly, this mode will turn off a device or set it into a stand-by
Engergy star No data is lost when computer components enter a low-power mode, ... keyboard would get the computer out of this mode. Also see: Power Definitions, Sleep
This should wake your computer, Good Luck/Please dont for get to Vote.Thank you.
Dec 15, 2007 | HP Pavilion F1703 17" LCD Monitor
When I select sleep or hibernate mode - the monitor stays black...
Hit the keyboard keys. It is better to just turn sleep and hibernate off and just use a screen saver or tun it off.
Aug 24, 2007 | ViewSonic VX910 19" LCD Monitor
HP Pavillion s7420n  PC Desktop Logo
207 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
