Question about HP Pavilion A730N (PJ510AA) PC Desktop
My a730n computer will not turn on. The green light flashes in the back. Local frys tested power supply and said it was working. Fans dont come on...nothing?
  • abdul vahid lakkal Aug 24, 2010
    change power supply and check
  • brianbtb Aug 24, 2010
    The power supply was tested and the tech said it was ok. The green light on the back blinks but nothing comes on when I hit the start button. No fans work, no noise anywhere. Could it be the motherboard?.....
    Guru:
  • 266 Answers
It could be a mother board problem or Power supply issue. Even if the power supply works it wont supply required voltage to some components.Its better you get a new power supply and test it.Still its not working it could be a mother board issue.There will be a chance for power button issue also.
Posted on Aug 24, 2010
Testimonial: "thanks. I will check it out"
Green light flashes on back of tower but won't turn on.
sorry guess your PCs motherboard is out....if FAN on power unit at the back works(the FAN that's close by to the power socket)
if that FAN does not work when you switch on then the power unit is out.....
take it to tech shop and have a tech examin it
Nov 18, 2010 | HP Pavilion A730N (PJ510AA) PC Desktop
I have an HP tower that won't power up...there is a green light on the back that steadily flashes unless you unplug the machine-then it slowly stops flashing. The unit is receiving power, however, neither...
the power wires are connected to the motherboard?
Is the switch working correctly?
You can check that by opening the box/case, look for the 2 pins where the power switch is connected (with letters PW) and touch both with your screwdriver. If the computer turns on, your switch is bad. Im not responsible if you touch other pins and kill your computer. Has to be the power one.
Aug 11, 2009 | HP Pavilion Media Center m8425f 2.66GHz...
HP dc5000 won't start. Green light on front is dim and flashing.
Hold down the power button until the machine completely turns off. Then turn the machine back on and let me know what happens.
May 26, 2009 | HP Compaq dc5000 Small Form Factor PC...
Hp Pavilion a730n unknown issue
You might want to check the CPU fan for dust and re-seat the RAM. I sounds more like a heat issue.
Mar 18, 2009 | HP Pavilion A730N (PJ510AA) PC Desktop
Raidmax Sirius case not turning on
Recheck the wiring. Make sure the fans are all plugged into the proper place. Then try reseating the RAM, video card, & cpu. Make sure you have applied a good thermal paste between cpu & heatsink as overheating can cause the system not to boot. Hope this helps & please remember to rate my answer. Thanks.
Dec 28, 2008 | RaidMax SIRIUS (ATX-701WS) ATX Mid-Tower...
Power doesn't turn on
NO! Do not buy a new motherboard or pc without checking some things.
First, is the green light you say is blinking on the Power Supply itself?
If it is, then the power supply is dead. A blinking light on a PSU means that it can no longer hold a charge and needs to be replaced. Get a new one and pop it in.
Mar 10, 2008 | HP Pavilion A730N (PJ510AA) PC Desktop
Pover up trouble
sounds like something is drawing down on your 12 volt supply drives or on board regulators. Try it without the drives connectged, and see if you can get the system to boot up(you'll just get a notice that your drives are unavailable, but you'll already know that, right?
got backup for your Dell?
Feb 15, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Power Green Light Flashing HP Desk Top PC m7250n
During a power outage their is a surge when power come back on the grid (surge can be caused by lighting strikes akso). This surge trips the internal procters inside the power supply to protect the Mother Board, hard drive, processor and fans and any device that pulls wattage from the power supply. Since all these power using devices are trying to pull power at the same time to boot the computer back up one ends up with a loop of surge thrugh the power supply with a protective trip, reset, surge again and trip again. This will continue in this loop as the computer is trying to boot all the devices at one time (Mobo, Hd, processor, cooling fans and other devices). Simoly, more power wattage is being demanded than the protectors will allow at one time causing a protective shutdown followed by a restart followe by a protective shutdown in a continious loop.
The normall sequence for a boot is to boot the board, processor and fans followed by a boot of the hard drive, and other boot devices once the board is energised, NOT all devices at the same time, as this results in an overload and trips the protectors. This protective loop is indicated by the blinking light as the power is turned on and then shut down for protection as the wattage pull is over the demand that the protectors will allow.
Blinking light indictes you are in the protective loop.
SOLUTION: 1. Disconnect the Mother Board connector, with the computer unplugged, this will allow the power supply to reset at maximum wattage upon reboot.
2. Disconnect the Hard Drive power connector and ay boot device power supply cables, this will allow the Mother Board, processors and fans to boot without an overload of the protector inside the power supply.
3. Plug in the computer and the indicator light will be solid green indicating that it is reset and out of the loop.
4. With the computer pluged in and the Power Supply fully energised, plug in the Mother Board. The computer will now boot, and the processor fan will come on and the cooling fans.
5. After computer has rebooted, shut the computer back down and connect the Hard Drive power cable and any other power cablis that were unplugged.
6. Reboot with all cables connected and you are up and running again.
POWER SUPPLIES HAVE AN INDICATOR LIGHT FOR A REASON.
REMBER - BLINKING LIGHT IS AN OVERLOAD OF THE PROTECTORS AND ELLIMINATING THE OVERLOAD SOLVES THE PROBLEM AND THAT THE POWER SUPPLY IS WORKING AND CONVERTING POWER.
NO LIGHT MEANS NO POWER OUTPUT AND THAT INDICATES THE POWER SUPPLY IS NOT FUNCTIONING AND NEEDS REPLACED.
Hope this helps everone with power outages and lightining strikes. It is a rather common problem and can also occure when building a computer and one missmatches the power supply with the board wattage needs. If the board wattage needs are greater than the power supply output you will get stuck in a potective loop eventually. WHEN BUILDING A COMPUTER ALWAYS MAKE SURE THE POWER SUPPLY CAN PRODUCE MORE WATTAGE THAN YOU CAN CONSUME AT THE MAXAMUM LOAD.
Have a great computing experiense.
Jan 13, 2008 | HP Media Center m7250n (ED842AA) PC...
HP Pavilion A730N (PJ510AA) PC Desktop Logo
191 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
