Question about HP Pavilion dv7-1132nr Notebook PC
The laptop overheats and shuts off - HP Pavilion dv7-1132nr Notebook PC
    President:
  • 1,851 Answers
In case you can open (I mean disasemble) the laptop do it and clean every air inlet - outlet. In case you can't use a soft brush and clean the inlet - outlet from the outer side. After that you may use CLEAN AIR in order to improve the cleaning effect (not before the brush because all the dust will go in the laptop). Leave the laptop some minutes to calm and check the results.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Aug 24, 2010
    Problem Solver:
  • 17 Answers
If you are using it keeping on bed then it will certainly overheat
due to closed fan vents
to avoid keep the fan vents clear
HP Pavillion tx2-135dx laptop overheats
hi.Fan Always Runs Or Laptop Overheats And Shuts Itself Off
Warning! Before Disassembling Laptop always unplug power and remove the battery.
Laptops that shut down without warning are often experiencing overheating issues. Overheating may be a symptom of age, of clogged ventilation or impending failure, but it can also result from simply using the laptop in a bad location. Before you try to take the laptop apart to look for problems, it pays to patiently troubleshoot the symptoms and see if an easy fix is possible. I wrote The Laptop Repair Workbook to teach basic laptop technology and troubleshooting to regular people and techs in training. The overheating flowchart below is one of twelve flowcharts in the book.wfwmoavismn7iaaaaasuvork5cyii=
May 09, 2014 | HP Pavilion Computers & Internet
Laptop Overheats
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Feb 16, 2012 | Computers & Internet
Aspire 5738-6444 overheats
you have to open your laptop and clean all dusts sticked to the heat sink. this will solve your problem temporarily.
Feb 08, 2012 | Computers & Internet
The laptop overheats and then shuts down
Hi joshua1156,
Your laptop fan is not working. That's why the laptop overheats and shuts down. Replacing the fan will solve your problem.
Thank you for using fixya,
Arun Zac
Nov 26, 2010 | Gateway 7320GZ Notebook
HP compaq nx6125 windows vista 64 bit
http://www.daileyint.com/hmdpc/overheat.htm
This site has a some info on that.
I must say that all laptops get hot but the shutting off is worrisome. Try placing it on a raised surface that does not block the air vents and have a fan or something to circulate some cool air around it.
Mar 30, 2010 | HP Compaq nx6125 Notebook
Laptop Compaq Presario F 700 overheats easily and shuts down
When the CPU overheats it shuts down (ie thermal overload) and won't startup until it has cooled down. This problem is caused by faulty fans (with bearing problems and may not spinning at normal speed) or the fan and heatsink assembly is clogged with dust.
Check the vents and fan and vacuum and remove the dust.
If the laptop is not placed on a flat surface there may not be enought air entering the vent on the bottom of the laptop.
To improve ventillation, you can stick rubber pads on the bottom of the laptop to increase the height of the laptop off the table. Better still purchase a laptop fan assisted base and place the laptop on this base, this provides further fan assisted ventillation.
Aug 26, 2009 | Compaq Presario 700 470024-192 Notebook
I just got a webcam and my laptop overheats what
You need to buy a laptop cooling fan. Not expensive. This is a must so you don't burn out the components on the laptop or oops! laptop no more....
Jul 16, 2009 | Dell Inspiron 1501 Notebook
Toshiba A65-S1062 - This laptop overheats and shuts down.
I bet that you had your laptop on all the time.
Your heat sink is saturated with dust and grit.
you may have to open up the unit and use a can of dust remover to clean the fins on the heat sink out. it is causing your CPU to shut down bucause it is becoming overheated.
Happy Fixing =)
Jul 11, 2009 | Toshiba Satellite A65-S1062 Notebook
Overheat and switches off automatically
check the cpu fan it is not working properly need clean sometime full of dast that why always became heat. epected of overheating is automatically shut down...
repair you cpu fan disasimble you laptop then check the cpu fan
thanks
Jun 01, 2009 | HP Pavilion DV5-1000US Laptop
HP Pavilion dv7-1132nr Notebook PC Logo
203 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
