Question about Argox OS-214 Label Printer
Unable to print barcode labels from Pastel accounting POS.
How to print barcodes
To print bar codes you first need POS software that will contain all the pertinent information of your products. The software then will generate a bar code and assign it to your individual products allowing them to be scanned for inventory and checkout purpose. You can find labels here: Labeldomain com
May 16, 2014 | Zebra Eltron TLP 2742 Thermal Label...
We're using 4.00 X 2.00 inch labels. The barcode is printing just under an inch long when it should be about 2 inches long so our scanners cannot read the barcodes. The text is printing out the
in some barcode software you can see the preview. if you click on the barcode itself maybe you can stretch it out to fit better. or try swapping to 2 by 4 format and see if that works. good luck
Aug 12, 2017 | Zebra ZM400 Thermal Label Printer -...
Failed to load the print preview or failed to print.
You need to run the Wasp software under an Administrative account or Right click the program Icon and select run as administrator (only need to do this 1 time, not over and over again). Once the program loads, set the label printer again by clicking file at the top left and selecting Setup Label Printer. Select your label printer. Now try printing the labels again.
Jul 19, 2012 | Wasp Technologies Inventory Control...
Error 616
The software is not corrupt. The 606 is basically telling you that one of the dots that heat up to make the image on your paper isn't able to heat up correctly. Since the printer can typically shift these dots over from one side to the other to help compensate for these dots going bad, it is also saying that it can't shift either.
You're seeing this issue on a barcode, and instead of a barcode you're getting a gray box. If you're unable to make changes in your code that is going to the printer, that tells it what to print and where, your best bet is to purchase a new printhead form Avery.
1-800-543-6650
Though the issue can be worked around, it is possible that now that you can print that barcodes you want, you may find that new ones won't be able to print because they're printing in that same space where the printer cannot shift dots to compensate for the bad one.
Jul 10, 2012 | Monarch 9855 Thermal Printer
Our Blaster Advantage prints too low on label
Printer needs to be calibrated. This can be accomplished through the driver under 'printing preferences' or the Cognitive Printer Setup Utility.
Dec 12, 2009 | ATSI Holdings Cognitive Blaster Advantage...
Transfer info from the digital weight scaleto quickbooks
You would need to add an criteria or the rule, like barcode length or type. Than is the the scanner able to understand which barcode should be handled by the specific rule.
Dec 03, 2008 | Symbol LS2208 Handheld
Zebra TLP2844 does not print the barcode label
Can you print the barcode using the software that come with the printer. Zebra TLP2844 come with basic Designer software. Test whether it's printing the barcode or not.
IF it prints the barcode via its software, then you might be having barcode font problem between your application/os and the printer.
May 21, 2008 | Zebra Eltron TLP 2844 Thermal Label...
Improper printing of barcodes
recalibrate the label length in the printer(hold feed and power up). from memory bar-one uses the label settings from windows, so go into printers and faxes under control panel and correct the label size
May 25, 2007 | Zebra TLP 2844-Z Thermal Label Printer
Argox OS-214 Label Printer Logo
195 people viewed this question
Top Argox Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
sahoo_sanjay
bvmihai
Are you an Argox Office Equipment and Supply Expert? Answer questions, earn points and help others
