Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
My system just quit working like it is not getting electricty, what can I do?
  • Intex Master
  • 8,404 Answers
Is it getting electricity? Check the breaker ... check the plug ... are you plugged into a GFI? Check the GFI
Posted on Aug 27, 2010
  • A Miller Aug 31, 2010
    So what happened? Did you do as I suggested? What happened?
Can i by pass the clock or timer to be able to use the main oven they are worked by electricty
Cooker dead or oven not working or clock flashing - YouTube
? 3:05
https://www.youtube.com/watch?v=FDz4UpFMXq0
Dec 20, 2011 - Uploaded by Richard Saupe
Can be quite a problem when your cooker or oven is dead and always ... want to use it. watch this video on tips to re set theclock and get it up and ru. ... I try to set time I'm after a video clip on how to change the timer any help .
My Rangemaster 110 oven will not light, the timer/clock is ...
www.howtomendit.com > Kitchen Appliances, Gas Cookers
Free repair help - rangemaster 110 oven will not light timerclock broken too. ... I turned off mains electric then took out the 5 screws .... all I was interested in was bypassingthe timer and not fixing the timer -like others ..... Like I say, you will have no clockfunction but will be able to use the oven in the way it was meant to work.
Nov 24, 2015 | Kitchen Ranges
When I press start the electricty trips ?
u HAVE A SHORT SOMEWHERE AND NEED TO CHECK UR WIRING FOR BURNED OR FRAYED AREAS.
Dec 16, 2014 | Beko Washing Machines
Audio shuts off after 2 minutes, no sound
It's probably Thermal Runaway' a term used when a electronic component over heats and quits working. Go to Radio Shack and buy a can of freeze spray, Take it down to where you can get to the chassis and when it goes out starting spraying components and when you get the right one the sound will pop back on/ This spray is not flammable and does not conduct electricty. That component will have to be replaced,
Mar 12, 2014 | Samsung 65" Series 7 LED HDTV - UN65F7100
Why it want make electricty are load up?
Must be up to full running RPM to generate the right operating voltage. If it is running at full throttle and there is no power out, then the generator head needs to be repaired.
Feb 06, 2014 | Coleman Electrical Supplies
Keeway hurricane 50 .the electricty went off suddenly
Hello and happy thanksgiving from the USA.
I would suspect that you have a defective igntion switch, the igntion switch is what powers up all of the electrical system when you turn the key to run, the contacts can get burnt or the connector or both. The switch is under/behind the ignition key cylinder which operates the switch or course.
Nov 24, 2011 | 2008 Keeway Hurricane 50
I can get into my facebook page but can no get into any games says error on page electricty went off for about 1 hr due to stormy weather
You can try to use system restore and restore it to yesterday or a few days ago when it was working. For XP go to Start->all programs->accesories->system tools-> system restore. For vista, just click on the start button and then search for "system restore". Select a date and see what happens.
Oct 25, 2010 | Computers & Internet
We had a thunderstorm and had the electricty blink off then back on. Everything started working again but our Philips DVD home Theater System HTS 3555. Now there is no power to it at all.
sounds like you got a power spike that only took out your DVD
check your owners manual to see if yours has a replaceable fuse.... the older ones have replaceable fuses but the newer ones do not!
May 13, 2010 | Audio Players & Recorders
What are the electrical needs for this system to operate efficiently? I am onsidering this 13 seer 5 ton unit for my home.
The system will need 220volts.The higher the SEER# rating is the less electricty you will use/require.13 is not so bad.
Apr 01, 2010 | Ruud Central System Air Conditioner
SHARP AE-A244J no cold air
Your possible problem could be something as simple as cleaning your coils. The outside coil could be possibly clogged with dirt or the worst is cottonwood if they exist in your area, this depends on how long the unit has been installed, be sure to unplug-shut down any & all electricty to the unit, spray coils with a good dirt solvent, 409 works good for this, hose the coil with as high a pressure as possible, let dry for at least 1 hour before connect electricty. Inside coils get clogged also, with running unit without filter, or using for a long period on time. Sometimes these are hard to get to, although you should be able to see them, if not call a pro. Another prob. could be low on freon, another job for a pro, this means you have a leak in the system.
Lee
Dec 16, 2009 | Heating & Cooling
My lincoln navigator shakes when i am completely stoped.....when im driving and i hit bumps i can hear like if air is being released from the front and the navi wont lift from the front sometimes.....and...
front air suspension shocks need to be replaced. Also for stuttering, there is either a vacuum leaky or bad spark plug wire. Bad 02 sensors would also cause this but the check engine light would be on if it was a sensor or anything electronically wrong
Oct 01, 2009 | 2004 Lincoln Navigator
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
70 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
