Question about Life Fitness 9500HR Next Generation Remanufactured Treadmill
9500hr display reads please wait takes 3 or 4 mins to start reads incine inoperative liftmotor works
  • 79 Answers
Check the swicth home and the fuse of 0.3 amp and the capacitor
Posted on Sep 15, 2010
Treamill 9500hr is reading weight in pounds and not kg
Please go to the Menu, and go to the section go caractheristic and change the Lbs to Kgs.
God bless you
Jan 09, 2013 | Life Fitness 9500HR Next Generation...
Unlock theftlock on 98 oldsmobile intrigue after several attempts
You need to read the instructions in the 1998 Oldsmobile Intrigue Owner's Manual. Yes, you must now wait an hour. The first time that "INOP" will display is if you have tried it eight times and failed. After you wait an hour, you will only get three chances to get it right before INOP will be displayed again.
May 03, 2012 | 1998 Oldsmobile Intrigue
Radio locked no code
Unlocking the Delco Radio Theft-Deterrent Feature After a Power Loss
If you know the code that was used to lock the radio then use the following instructions from the owner's manual to unlock the radio.
Quote:
Enter your secret code as follows; pause no more than 15 seconds between steps:
1. Turn the ignition on. LOC will appear on the display.
2. Press MIN and 000 will appear on the display.
3. Press MIN again until the last two digits agree with your code.
4. Press HR until the first one or two digits agree with your code.
5. Press AM-FM after you have confirmed that the code matches your secret code. The display will show SEC, indicating the radio is now operable and secure.
If you enter the wrong code eight times, INOP will appear on the display. You will have to wait an hour with the ignition on before you can try again. When you try again, you will only have three more chances (eight tries per chance) to enter the correct code before INOP appears.
If you don't know the code that was used to lock the radio then you will have to use the dealer's unlock procedure as follows. The dealer code changes over time - the one listed is current as of this posting. If it doesn't work try 08359 or search the forum for messages with a more recent code.
Quote:
1. Press and hold presets 2 & 3 for about 10 seconds until the first three digits of the display code are displayed.
2. Write the numbers down.
3. Press the AM-FM button, write down the next three numbers.
4. Call 1-800-537-5140. When asked, enter dealer code 202108, press the * button, and enter the six digit code from the radio. You will get an unlock code, write it down.
5. Go back to the car, press the HR button and set the first two numbers, press the MIN button and set the next two numbers, then press the AM-FM button. The display will show SEC, indicating the radio is now operable and secure.
To remove the code, repeat step 5. you should see --- on the radio face indicating the code is now out of the radio."
Dec 29, 2010 | 2000 GMC Jimmy
I recently replaced a liftmotor on a 9500 and it still says inoperative when turned on. The motor is a reman and I use them all the time so if the motor is good is there a sensor that needs to be replaced...
you should first check if any cable is not loose check the connectors between the CPU and lift motor check if the Swicth home is not disconnected
or perhaps the home swicth is not compatible or damaged is possible that some connector is not in place the CPU is at the side of Emerson CONTROLLER and motor connector pins must have three any question send me a E-mail cardiotech_me@hotmail.com
Sep 14, 2010 | Life Fitness 9500HR Next Generation...
Sir, i have a life fitness 9500hr. I hit start screen reads incline inoperable. Everything else works but won't incline. Thanks
please check the fuse of 0.3 amp is located in the front of the machine revises this swicth home underneath the left side of the machine or check for side always in the left if the cables are not disconnected last step and check the capacitor is located on the hoist motor any question send me a message cardiotech_me@hotmail.com
Aug 15, 2010 | Life Fitness 9500HR Next Generation...
The treadmill keeps shutting off and display code reads "System Initializing"
Check magnetic safety with lanyard,if magnet is not secure it can turn on and off. Also check plug at outlet. And emegency stop button , if you start treadmill and tap around e-stop it should keep running
Nov 23, 2009 | Life Fitness 9500HR Next Generation...
I have a locked radio for a 2000 pontiac grand prix thanks to a battery exchange...can anyone help ...the 6 dig code is 292298
Hello! You have done half of the work already! You can take the code, and the VIN to your vehicle; and call your local GM dealership. Tell them that you need the unlock code for the radio, and they will ask you for that information.
Also - there are 2 modes to the TheftLock - "LOC" or "SEC" and "INOP". Once the anti-theft is activated, the radio display will show "LOC" or "SEC" - you then have 8 attempts to enter your code. If after 8 attempts you don't enter the correct code, the display will change to "INOP". It is only at this time that you will need to wait one hour, with the ignition ON; before you can retry. After that - you will have only 3 attempts before the radio enters "INOP" mode again.
Hope this helps and good luck!
Sep 25, 2009 | 2000 Pontiac Grand Prix
I got the code just don't no how to put it in
Unlocking the Theft Deterrent Feature after a Power Loss Enter the secret code as follows, pausing no more than 15 seconds between steps:
  1. LOC appears when the ignition is ON.
  3. Press MIN again to make the last 2 digits agree with the code.
  4. Press HR to make the first 1 or 2 digits agree with the code.
  5. Press AM-FM after you have confirmed that the code matches the secret code that was written down. The display will show SEC, indicating the radio is now operable and secure.
If you enter the wrong code 8 times, INOP will appear on the display. You will have to wait an hour with the ignition ON before you can try again. When you try again, you will only have 3 chances to enter the correct code before INOP appears.
Sep 22, 2008 | 2003 Pontiac Grand Prix
Life Fitness 9500HR Next Generation Remanufactured Treadmill Logo
241 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Howard
Howard
Electro Med Services...
Matt Olenzek
Matt Olenzek
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
