Question about Nikon COOLPIX L3 Digital Camera
My camera says kens error when turned on - Nikon COOLPIX L3 Digital Camera
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Aug 24, 2010
Nikon coolpix lens error
Hello Ken,
The lens error in many cameras are caused due to sand or grit interfering with the lens extension mechanism. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials stick to the camera by electrostatic build-up from the camera rubbing against the side of the carrying case. To resolve the lens error remove the battery for some time. Then insert the battery again and charge the battery completely. Then try pressing and holding the Menu, Function, Function Set, or OK button while turning the camera on. Also try the factory reset option. Also try the on/off button many times after battery full charge.
Jul 02, 2011 | Nikon Coolpix S3000 Digital Camera
Not detected on computer
Try turning the power on to the camera..when the camera is hooked to the computer via usb.
KEN
May 07, 2009 | Canon PowerShot A720 IS Digital Camera
Dropped my Canon SD 750 and it won't turn on
KEN,
I HAVE LOCATED THREE REPAIR SHOPS THAT WORK ON CANON AND GIVE FREE QUOTES. I DO NOT ENDORSE ANY OF THESE, BUT PASS THEM ON FOR YOUR INFORMATION. AS FAR AS I KNOW THEY ARE RESPONSIBLE. THE WEBSITES ARE BELOW. I HOPE THIS HELPS! GOOD LUCK! IF YOU NEED ADDITIONAL HELP,REPLY TO:ARCLIGHT1217
www.digitechcamerarepair.com
www.PrecisionCamera.com
www.keh.com
Nov 07, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Troubleshooting for my sony cybershot 3.2 megapixels
there is a possibility that the lens assembly is not in the right angle like a piece is not in line, or a possible gear slipage, there are many other reasons why this is happening, you may refer to the pictures below.
question, does the camera give out an error message or when you turn it on and press the zoom, do you hear a sound from the camera itself?
if in case will you turn it one and gently push the kens sideways, because like waht i mentioned, a part may just be stuck.
http://forum.ecoustics.com/bbs/messages/8691/248818.jpg
http://forum.ecoustics.com/bbs/messages/8691/248819.jpg
Aug 19, 2008 | Sony Cyber-Shot DSC-P52 Digital Camera
File Transfer Error
Hi.
I recommend using a card reader available nearly everywhere.
Plug it into the PCs USB port. then it should show up as a drive. transfer the files and you're done. Don't forget to 'safely remove' the drive before unplugging it.
Ken.
Aug 02, 2008 | Canon PowerShot S3 IS Digital Camera
Communication Error
Try connecting the camera to another computer. Is the camera reading the same error? If not, it's a computer issue.
If the camera is reading the same error, see if there's a way to restore camera back to the factory settings, and try all over again. Good luck :)
Apr 07, 2008 | Fuji FinePix S5100 Digital Camera
Sony DCR-DVD92 drive error
i have a canon camera with a similar problem.
it would not allow me to finalise unless the power adaptor was connected to the camera.
not sure if this will help you?
cheers, joe
Mar 08, 2008 | Sony Handycam DCR-DVD92 DVD Camcorder
My sony digital camera was stepped on and the viewfinder is broken
I have a DSC-P93 (same camera with 5mp) I had crack the LCD carrying the camera in my front hip pocket. I searched for a replacement LCD and I had no luck. I ended up Buying a “parts” camera from ebay for $9.90 + 4.00 for shipping. You could get either DSC-P73 or DSC-P93 (the LCD is the same) just be sure they say that the screen shows something. Menus is fine errors are no problem as long as it’s not black.
Dec 31, 2007 | Sony Cyber-Shot DSC-P72 Digital Camera
DSCH9
Guys - I just recevied a new H9 today. Was using it and decided to turn the flash off. Later on I wanted to turn it back on and I got the famous "flash settings cannot be changed" error message. I found the problem. I had turned on the "continuous shooting" option as I wanted to see how fast it would take photos continuously. When that option is on, you cannot use the flash so therefore you cannot change the flash settings. I put the camera back in "single-shot" mode and now the flash works fine. I hope this fixes your issue.
Thanks, Ken
Nov 23, 2007 | Sony Cyber-shot DSC-H9 Digital Camera
Write protect card
thos pictures are lost... u ken fix the problem by format...menu- setup- format...they are problems with the pictures because the camera was shaken allot...dont worry this will do it... or u ken get a card reader to get thos photos back, but the format is required
Sep 22, 2006 | Olympus Stylus 700 / 700 Digital Camera
Nikon COOLPIX L3 Digital Camera Logo
15 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
