I can't install my (ACM-615) Midget Web Cam - Computers & Internet
I lost my installation cd for d-link dir-615 wireles router where can i download the same cd
Access the manufacturer's web-site:
ftp://ftp2.dlink.com/PRODUCTS/DIR-615/
Select the "Revision Level" of your router.
Then, download the software/quick-install-guide/manual for your router.
Apr 04, 2014 | D-Link DIR-615 Wireless Router
Tip
Activate the Faunhofer IIS MP3 Professional Codec remove Advanced
The WMP Bundled MP3 codec is the L3CODECA.ACM encoder "Fraunhofer Advanced MPEG" codec has limitations on available bit-rates andkeeps the sampling rate at below 22,050Khz it is licensed by Microsoft and ACM (Audio Compression Manager) is also by Microsoft
To improve the bitrates and sample rates available to you install and activate the Professional Fraunhofer ACM codec this is called L3CODECP.ACM, use the included TWEAK to remove the Advanced version and enable the Professional version after you have installed it.
The another version of the Fraunhofer MP3 codec is L3CODECX.ACM, and is a decode version ONLY and can be seen in the drivers.desc in the registry this can't be used as an ACM for re-encoding in VirtualDub and other such programs. This is also included in the zip file HERE
If you want to remove the MP3 decoder only L3CODECX.ACM I suggest that you use Codec Sniper be carefull only DELETE press once keep your sound ON if it says HEADSHOT it has been removed....
Check with Sherlock Detective to see if the Codec has been removed sucessfully this is also the best way to view all your Audio and Video codecs it will give you version number and manufacture details
  • l3codecx.acm: v1.0.0.64 (included in WMP6.4 decode only)
  • l3codeca.acm v1.9.0.305 (Advanced): Encodes up to 56Kbps
  • l3codecp.acm v3.4.0.0 (Professional): Encodes up to 320Kbps. (included in WMP10+11)
  • l3codecp.acm (so-called "Radium" version): Encodes up to 320Kbps
If you want to extract this latest L3CODECP.ACM v3.4.0.0 that has unlimited encoding use this little tip its perfectly legal to do this by the way.
Download the wmp11-windowsxp-x86-enu.exe it may require Windows Genuine Activation then save it to the root folder then extact it the Professional Version of the Codec L3CODECP.ACM, will be included in the wmp11.exe extract this and then just copy it to the system32 folder use THIS reg tweak to install it.
on Feb 14, 2010 | Computers & Internet
The driver cd of cam acm-398, has broken by my kids,, i need the driver to down it and get the cam started,,, ples send me the driver file
Dear Friend!
Please click on following link to download drivers/software for Webcam ACM-398 -
http://www.zaapa.co.uk/Public/ficha_producto.asp?CPRO=707
the drivers is on the bottom of the page.
Best regards,
Pramod Bhikam Singh
Apr 26, 2011 | Computers & Internet
To get free download of dsp group truespeech audio
Here's the download link:
DSP Group TrueSpeech Audio Codec 1.1.1.5
http://www.codec-download.com/modules.php?name=Downloads&d_op=viewdownloaddetails&lid=505&ttitle=DSP_Group_TrueSpeech_Audio_Codec_1.1.1.5
1. Extract tssoft32.acm into your C:/Windows/System32 folder, rename your old tssoft32.acm to tssoft32OLD.acm and rename the new unzipped file tssoft32[Codec-Download.de].acm to tssoft32.acm .
2. In Control Panel, go to Add Hardware.
3. Click Next and after it searches choose 'Yes, I have already connected
the hardware'. Click Next.
4. Scroll down to the bottom of the 'Installed harware' list and choose
'Add a new hardware device'. Click Next.
5. Choose 'Install the hardware that I manually select from a list
(Advanced)'. Click Next.
6. Choose ' Sound, video and game controllers' from the 'Common hardware
types' list. Click Next.
7. Click on the 'Have Disk' button.
8. Click 'Browse'
9. Navigate to the 'C:/Windows/System32' folder
10. Choose '$winnt$.inf'. Click Ok.
11. Click 'Continue Anyway' if you get a warning box.
12. Select 'DSP Group TrueSpeech™ Audio CODEC from the list. Click Next.
13. Click Next again to install.
14. Restart if necessary.
*This was taken from another site
It wast posted by Faizi
Mar 04, 2010 | Asrock 775i65G Motherboard
Webcam Tvisto ACM-366 doesn't work on Windows 7
Try running the webcam program in 'compatibility mode'
Nov 24, 2009 | Computers & Internet
Unable to get onto internet explorer
Hello
Thank you for using FixYa.
Use another computer to download "combofix" from bleeping computer, run this and part of the fix is to reset the IE settings back
IE should restart after this, If not download say Firefox and get this installed and see if that will work, most cases it will and IE not, it can be bugs causeing your IE to stop working
Thanks
Richard
Nov 17, 2009 | Acer Aspire 4530-5889 Notebook PC
Necesito instalar mi wed cam pero no tengo el cd de instalacion el modelo de mi wed cam es creative labs inc vf-0050
Espanol: (English below)
Muchos sitios en línea tienen capacidad para detectar y buscar los controladores. Usted podría intentar una de ellas.
Sospecho que su cámara web ya no es soportado por Creative Labs.
Si la webcam es USB, puede ser capaz de salirse con la suya utilizando un software diferente. Usted podría intentar encontrar driver para VF-0450. O, incluso un competidor como el software Logitech QuickCam. Este último es utilizado por varias cámaras web.
Por último, una nueva cámara web puede ser la mejor respuesta. English: Many sites online have ability to detect and search for drivers. You could try one of those. I suspect your webcam is no longer supported by Creative Labs. If webcam is USB, you may be able to get away with using a different software. You could try finding driver for VF-0450. Or, even a competitor software like Logitech QuickCam. The latter is used by various webcams. Lastly, a newer webcam may be the better answer.
Oct 12, 2009 | Creative Labs Creative Webcam
I lost my web cam driver
I lost my CD driver ACM-366. I need to install my webcam. Please help me. Thank's you
Jul 26, 2009 | Computers & Internet
USB charge point location
YOu need to purchase and install the ACM (audio connectivity module).
If you're in the US I know where to get the ACM. I have the instructions for the ACM install if you're interested. First you will have to spend money on the
ACM - about 300 dollars....
Feb 16, 2009 | 2002 Jaguar X-Type
How to install mp3 in a v3i cellular phone?
On your PC if you go into Start/Settings/Control panel/Sounds and Audio devices, under Hardware tab/Audio codecs, click Properties, you'll see the driver listed as "Fraunhofer IIS MPEG Layer-3 codec (decode only)". This confirms that the wrong driver is installed.
Something you installed, probably to burn CDs, installed a playback-only version of the driver. The driver is l3codeca.acm, which is replaced by the playback-only version l3codecx.acm.
You need to edit the Registry:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Drivers32. Locate the item named msacm.l3acm.
Its value should be changed from l3codecx.acm to l3codeca.acm.
Note that you might have to use the full path name thus:
C:\WINDOWS\system32\l3codeca.acm
For its name to appear properly in the Audio codecs list.
If that's not your problem, and you want to tranfer files to and from Mob/PC.
Go here to learn more:
http://www.knowyourmobile.com/motorola/motorolarazrv3i/motorolarazrv3iuserguides/167/backing_up_your_motorola_v3i_to_a_pc_by_bluetooth_or_sync.html
Mar 31, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
