Question about Epson Artisan 800 All-In-One InkJet Printer
I have an Epson Artisan 800 Printer with a bad print head. This print head is beyond any more attempts at cleaning it and I would like to find out where I could find a replacement. I have found that this print head is very easy to replace. You take out three screws and you can lift the print head out of the carriage, then three more screws to remove the ink feed lines and then the electrical feed just pulls out of the plug. If I had another print head I could have it installed in the printer in about ten minutes but I can't find a replacement. Does anyone know where I could find a replacement print head at a reasonable cost?
Ihave found a solution that you only have to insert vinaigar...? alcool in the ink line wait about 30 to 60 min and it's done.
Some cies sold cleaner for printing heads
Louis
Posted on Aug 28, 2010
On Epson Artisan 800 the scanner leaves wide black stripes for the whole length of the paper. Printing From a file is OK.
If computer printing is fine (source) but scanner printing has problems, then of course, your problem is in the scanner. The only solution based on your info (which is good), are the lines in the same areas on other bad scanning prints? If so, your problem means that the scan-head has a connection problem leaving a 'black' send to the print buffer. This will require some technical repair replace or clean connection. Remember that this is a mechanical movement that not only records what it 'sees'e but at what X-Y location the read was 'seen'. It would be worth it to get an estimate from your local computer repair center give you an estimate.
Sep 22, 2014 | Epson Artisan 800 All-In-One InkJet...
Epson artisan 810 prints vertical black lines on all documents
this problem is usually fixed easily. this commonly occurs when print head is clogged. I use a facial tissue and alcohol to clean the head with the ink cartridge in an upside down position (if possible) then i print one or two test prints to get it back to normal.
Jul 06, 2014 | Epson Artisan 800 All-In-One InkJet...
Epson Artisan 800 won't print with ink in the cartridges.
Have you run the head cleaner function under the maintenance section? You may have to run it several times. Then make sure that you print something that uses the colors every week.
Aug 06, 2013 | Epson Artisan 800 All-In-One InkJet...
Artisan 810 will not print black
i have same model need to clean head of catridge then used air spray to clean heads of printer then install back again if this don't work then need to get new cartridge
Oct 13, 2012 | Epson Artisan 810 AllInOne InkJet Printer
My Epson Artisan 810 prints horizonal light blue lines on all printed materials. How to remove the blue lines?
To resolve this issue, you need to print a nozzle check pattern and then determine if print head cleanning is need.
To print nozzle check, follow the steps below.
  1. Turn off the Artisan Series and your computer, if connected.
  2. Disconnect any connected USB cables.
  3. Load plain paper in the main tray.
  4. Press the On button to turn the Artisan 800 Series on again.
  5. Press Setup.
  6. Select Maintenance.
  7. Select Nozzle Check.
  8. Press Start.
  9. The Artisan Series begins printing the nozzle check pattern.
  10. If there are no gaps, select Finish Nozzle Check.
    If there are gaps, select Head Cleaning.
If the nozzle check pattern page prints correctly, the problem may be with your software settings, the interface cable, or your computer.
Oct 31, 2011 | Epson Artisan 800 All-In-One InkJet...
My Epson Artisan 800 prints only 1 inch of anything and then spits the paper out
Try the following to resolve this issue.
1. Check if same issue appears when using your Artisan 800 as a standalone copy machine.
2. Try printing from a different application to isolate the issue further. You can also print a windows test page to check if this issue is caused by the application that you are printing from or by the printer driver.
3. Reinstall Printer Driver.
Oct 29, 2011 | Epson Artisan 800 All-In-One InkJet...
Is it ok to remove the print head from an epson artisan 810 printer to clean it? Will allignment be a problem?
yes you can remove it. and dont worry about allignment you can software manually re-align it will recoginize it immediatly
Mar 22, 2011 | Epson Artisan 800 All-In-One InkJet...
I have an Epson Artisan 810 printer. All of a sudden, the printer will not print the black color. I just changed that cartridge and that didn't help either. Thanks!
Hi you should clean the print head and you need to take out the cartridge and pay close attention as you put it back into the printer because it may not be fitted in place properly.
Aug 08, 2010 | Epson Artisan 800 All-In-One InkJet...
Epson Artisan 800 continually indicating paper jam error--No jam.
Yes, that fixed the problem on my Artisan 800! Thanks so much for the info about slipping the cr scale back onto the u-guide on the back of the print head carriage, Larry P and dabaker!
For those trying this, the u clip is upside down so, from the front of the printer, you move the CR scale ribbon down a little and in towards you gently, in from the back towards the lower part of the rear of the print head assembly, and it will slip in on the top part of the ribbon into the u shaped groove (which, to be technical, looks more like an n-shaped groove, an upside down u). If it is loose and not clipped in, the CR scale ribbon will bow out easily on both sides of the print head carraige when lightly pressed towards the back of the printer near either side of the print head. (As pointed out in the service manual, do not touch the ribbon with your fingers, particularly if they may be greasy/greasty/gritty; use a clean tool for this-I used a q-tip which worked well for both testing the tension and for pushing it down and back into the proper guide slot.) If the CR scale ribbon is clipped in properly to the print head (properly seated in the n-shaped slot), it will bow towards the back of printer easily ONLY on the side that your press it from (ie left or right) but not on the opposite side of the carriage; the opposite side will remain almost entirely flush to the rear of the print assembly. Remember to press gently; you do not want to stretch or damage this scale ribbon if you can help it. If you have a small dental mirror and good light, you will be able to see the n-shapped clip (it's plastic and black on my 800 clearly. If the ribbon is correctly seated, it will be in the slot at the top and free at the bottom. Because of the use of u-slot in the previous posts, I was confused as to where to fit this in but then figured, nothing to lose and yep, it's actually the n-shaped slot at the top.
Jul 12, 2010 | Epson Artisan 800 All-In-One InkJet...
Epson artisan 800 will not print
please make show that ur connection to the printer is correct.mostly if u using usb cable.uninstall and reinstall ur printer drivers can solve the problem.
Apr 19, 2010 | Epson Artisan 800 All-In-One InkJet...
Epson Artisan 800 All-In-One InkJet Printer Logo
1,840 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
