Question about Kenmore Dishwashers
The last couple of months, taller glasses are not getting clean, have a food-like residue. No problems with other types of dishes. Tested water temperature, seems ok.
  • 122 Answers
If your drain is connected to a disposal make sure the drain hose has an air break, the hose should be raised higher than the disposal drain connection, if not it will syphon food from disposal back into dishwasher, also if you have never ran cleaner through dishwasher that also may be your problem, the best thing that I have found to use is muratic acid, just a cap full with the unit empty
Posted on Aug 24, 2010
We have had this dishwasher for approximately 2 years. Dishes do not clean well. For example, I put a mixing bowl in that I just mixed brownie in--and the bowl did not come clean (simply a thick...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Mar 01, 2011 | GE Profile PDW8480JSS Built-in Dishwasher
There is white residue on the dishes/glasses (note: the rinse aid is full and we have cleaned the components one month ago) also, water drips slightly out of the left corner of the dishwasher
heatman101
Jan 08, 2011 | Maytag MDB7100AWB Dishwasher
My dishes are not getting clean, the plastic has a grease fill on it the glasses have food residue stuck to them on the inside. I had to put the glasses on the bottom shelf in order to clean them but that...
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Sep 15, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Brand new bosch dishwater does not get dishes clean - food residu
Try the cascade new soap they have been changing the ingredents due to state requirments for the water treatment. also make sure spray arms and jet are free from food particles,also clean soap dispencer,If you want run CLR through dish washer no dishes to clean machine.Thanks
Jul 26, 2010 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Dishes are not clean and white residue is left on dishes
clean the filters or get new ones.make sure your water in is connected to the hot water not cold.Also put new rubber O rings on the spinning arm water sockets.
Jul 20, 2010 | Maytag MDB5100A Dishwasher
Dishes not getting clean
Are dishes too greasy!
Check incoming water for free flow
Add correct quantity of soap as per manual. Use dish washer friendly soap. Fill rinse aid liquid in the dispenser meant for it.
Select a different cycle programe and give a try.
May 27, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
I have a 2006 tall tub kitchenaid dishwasher which over the last 6 months has been leaving residue on the dishes, esp. glasses. We have had it serviced twice. Last Wed was the last time and he found food...
Try changing the type and brand of detergent. We had similar problems with a Maytag dishwasher which was solved by the above. The glasses in particular seemed to have a sand-like texture in the debris, yet drinking water showed no such problem. Hope this helps!
Apr 13, 2010 | KitchenAid 24 in. KUDP02CR Built-in...
the problem is hard water leaving the residue. go to www.dishwasherfilter.com and get the dishwasher filtration system. it will reduce the hard minerals that leave the residue and your dishes will be clean as can be. it is very affordable and fits right under your sink.
Mar 10, 2009 | Maytag MDB6000 Dishwasher
Dishwasher dishes not clean
i am a retired appliance engineer of 20 years, (and whats a chopper), this problem can be easily improved maybe totally rectified, by making sure the salt is topped up and use rinse aid, make sure all the food catch filters are cleaned out and the waste outlet is also cleaned out, make sure blades are free to rotate and holes are not blocked, these are easy to remove and clean they just unclip. there is no need to dismantle the appliance hope i have helped , if so please rate me,
Sep 18, 2007 | Kenmore 24 in. 16222 Built-in Dishwasher
Dishwashers Logo
41 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
