Roper washing machine; spin cycle doesn't work. Can I fix it? Or should I buy a new machine? All else is fine.
  • 1 more comment
  • ssss666 May 18, 2008
    spin cycle doesn't work at all on any of the 3 spin settings no noise or sounds at all. what could it be
  • chetlita Jun 11, 2008
    The washer was running and then stopped when it got to the spin cycle. Is it something that I can fix?
  • lmjones36 Mar 24, 2009
    my machine will not rinse on any cycle.
I had the same problem with mine. It turns out that the lid switch was loose. I was able to check it by using a screwdriver (you could use a pen or pencil) to depress the lever located on the right side of where the lid rests while the spin cycle was turned on.
Posted on Jul 09, 2008
My 5 year old Roper washing machine fills up, washes/agitates the cloths, drains them when the washer get to the rinse line to start the rinse cycle it stops, and all I hear is a humming. The machine will...
I'm not familiar with roper washing machines so I'll ask the question does it have two fill hoses. Most European machines now only have one fill. If it has two then it sound like the machine takes the initial water from the one fill and the rinse cycle water from another. The humming sounds like the valve for the other fill needs replacing. These are quite inexpensive and easy to fit. Power off.. remove lid ....switch of water...take out valve when you establish which one is affected and replace
Oct 17, 2013 | Whirlpool WTW5700S
Washing machine does not spin in any cycle
Hello, It can be one of two things, the contacts in the dial can have worn or broke causing the relay not to open or close to activate spin cycle.
Most likely it is your transmission or main gear for your spin cycle.
I hope its the dial which is an easy fix, but the trans is a big project IF the washer is worth it. You may consider looking for new/used washer if trans is bad. Good Luck.
Dec 11, 2012 | Roper Washing Machines
Roper washing machine makes grinding noise on spin cycle but the tub doesn't turn
It sounds like you have a motor coupling that is broken. There are videos on YouTube to show you how to repair this. Search for "motor coupling repair on direct drive".
Nov 26, 2012 | Roper RAS8445KQ Top Load Washer
Roper rab4132hq0 washer does not spin consistently. Most of the time, the spin will not engage, this isn't just for the spin cycle, but for the spinning during the wash and rinse cycles as well....
Sounds like a bad gearcase.You have a machine that is direct drive. The motor is hooked directly to the gearcase by a little coupler. Look under and make sure the coupler is in place if it is then you need gearcase.Again the coupler is located between the motor and gearcase. Hope this helped.
Jun 04, 2011 | Roper Washing Machines
Spin cycle doesn,t work
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
May 27, 2009 | Roper RAX7244KQ Top Load Washer
Roper RAX4232KQ0 washer grinds
Yes they are only about 40 dollars but if your washer doesn't agitate then the problem would be the "drive motor to transmission coupling"
Dec 24, 2008 | Roper RAS8445KQ Top Load Washer
Roper washing machine roper rax7245kqo
more than likely something is jamming your pump now your coming up on the post with another user as having the same problem but its not the same kind of machine im getting ready to answer the first user who has a front loader and it may pop up to you so disregard that. Reply to this message and ill tell you how to check yours
Jan 01, 2008 | Washing Machines
Washing Machines Logo
678 people viewed this question
Top Washing Machines Experts
