Question about Vehicle Parts & Accessories
I have a Cyclops Paralyser 355 car alarm fitted to my vl commodore. I removed the battery to charge it and now the alarm won't disarm. How do i reset it so it work's again?
  • 33 Answers
SOURCE: How do I disarm a audiovox prestige car alarm?
Locate the valet/override switch (button), (if you can't locate it, try tracing the wires under the dash from the main unit, usually a black and gray or black and red set of wires). Turn key to "RUN" position then press the button, the alarm's LED should light up solid at this time indicating valet mode as been set.
Posted on Jun 20, 2009
SOURCE: need to disarm the alarm because the remote is not
i have an 02 WRX my alarm keepes going off and i cant start my car and it keeps honking and honkin this viper system cam with the car n there is no button to press my blue button is flashing n my car is honking loud ! help! RPN 473V
Posted on Oct 10, 2009
SOURCE: Toad car alarm - text alert texts when arming and disarming alarm
yes this is aknownprobplem to Scorpion (Toad), you will need to use relays on the trigger wires
Posted on Nov 14, 2009
  • 7 Answers
SOURCE: How can I disarm a prestige car alarm system
find the program button and turn on ignition without starting the engine and press and hold the button till it goes steady
if it has a swith turn on and flip the switch till it goes on solid 1 or 2 x
Posted on Dec 15, 2009
  • 242 Answers
SOURCE: we have a cobra alarm on our car and its causing a
take red lead of battery then hold down the remote while you re attach the red lead and that should reset it
Posted on Dec 29, 2009
Need reset security does not have keyless entry
THIS WORKS ONLY ON FACTORY SYSTEM ONLY NOT AFTER MARKET OR DEARLER INSTALLED SYSTEM
. Find the RED / GREEN (-) wire located in the "25 PIN" Plug at the Driver Kick Panel / Door Harness.
Ground the RED / GREEN (-) wire.
This will DisArm the Factory Alarm until the Ground is removed.
OR
You can try (does not always work):
Be sure battery is fully charged
Disconnect Negative Battery Cable
Open Driver Door & LEAVE Open
Turn Ignition Switch ON & LEAVE On
Reconnect Negative Battery Cable
Alarm may sound for a few seconds
Start vehicle
Apr 25, 2016 | 1997 Lexus ES 300
On 2004 chevy silverado
Take the positive lead off the battery. Touch the battery with the lead on and off for about five to seven times. This should reset the alarm. Reconnect the positive lead and using the remote control for the vehicle alarm arm and disarm the alarm once before operating as normal.
May 17, 2013 | Cars & Trucks
Car won't start and arms alarm when I turn the ignition
Dead battery armed the security system. Remove the battery cable let the system reset. Charge the battery. Use the key to unlock the door instead of the keyless entry. This resets the alarm once the battery is charged.
Nov 01, 2012 | Volkswagen Cars & Trucks
My 2000 mustang battery died and now everytime i try to charge the battery the alarm goes off and nothing works to shut it off...how do i shut it off?
You factory security alarm needs to be reset.
Insert the key in the drivers door, turn left, then right to disarm and reset it.
Once this is done, charge the battery.
If this does not work, do the reset again, then disconnect the battery and charge it out of the vehicle. Once it is charged reconnect it. You may need to perform the key reset again afterwards.
If this does not work then the system has malfunctioned and either I can explain how to bypass it if you have some level of electric ability or you will have to bring it to a dealer.
best of luck.
Jan 10, 2011 | 2001 Ford Mustang
Left lights on ,and ran down battery. When i try to jump start, alarm goes off,key fob wont work till battery charges tried putting key in ignition and turning key, tried locking and unlocking door. what...
Find the alarm and disconnect it, or locate the fuse to the alarm and remove it. Then you can charge the battery without all the noise. Once the battery is charged, hook the alarm up and disarm it with the remote.
Dec 28, 2010 | Kia Spectra5 Cars & Trucks
I have a 02 silverodo battery went dead i charged battery reinstalled it it starts but dies and with the key out of the ignition security light stays on
you need to disarm the alarm. unplugging batt. or dead battery being jumped sets of the alarm not all alarms make noise
use remote to lockand then unlock doors need to be closed
or lock then unlock door with key if it dont reset then try passenger door
Mar 22, 2010 | 2002 Chevrolet Silverado 1500
Car alarm won't reset after disconnecting car battery
you should try to hit the unlock button on the remotes and that should disarm it. Try disarming that, that way and if that doesnt work we will go from there
Feb 22, 2009 | Vehicle Parts & Accessories
Vehicle Parts & Accessories Logo
187 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
