Question about Refrigerators
I have a GE side by side fridge (psc23mgpcww). My ice maker wont make ice. Temp is OK. Water is coming out of dispenser and I even used a blow dryer to defrost any ice that maybe in spout that leads into the mold. I also added 4oz of water into mold and shut switch to ice maker off for 15sec and turned back on and then pressed paddle 3 times and saw rake rotate but next morning still no other ice cubes formed. Could it be my water inlet valve vs water shut off valve or maybe even the spring on my paddle that seems very flimsy and has no recoil.thanks in advance. Yaron Shalomoff
  • 6 more comments
  • yava4 Aug 24, 2010
    yes I agree! but I am getting good flow from my water dispensor so wouldn't that tell me i am getting good pressure.
    yes I agree but my water flow of my dispenser is good.
  • yava4 Aug 25, 2010
    I just did a flow test as per GE and my water dispenser puts out 16oz in 20 secs and a malfunction would be less than 13.5 ounces so could it be still the water inlet valve ...I kinked the water line and released it but no water filled up the mold but it feels like there is cubes there already. Is it possible that the paddle on the bottomwhich has a spring has lost its recoil and that could be the problem.
  • yava4 Aug 26, 2010
    yes. but what about the spring which is located under the ice maker which is right above the ice maker paddle. could this cause any problem with the making of ice. the spring has no recoil left in it. please advise thanks
  • yava4 Sep 03, 2010
    i replied back to you a couple of days ago to let you know that i replaced the inlet valve but still no ice... please look at my last resonse. thx
    replaced my inlet valve but still no ice forming the only way the ice will come is if I close the switch off and turn back on and press ice paddle 3 times forward and with in 5 min the rake pushes out rhe cubes from mold.... can the spring which is flimsy on the ice paddle be causing this or do I have to replace the ice machins. thanks
    Yaron
    i already replaced the water inlet valve. please review all my previous comment to get a better understaning of my problem....maybe that will help narrow down the exact problem.thx
  • yava4 Sep 20, 2010
    i take back my last comment about ice flap spring...i noticed that when the light indicatior for quick ice is off I get ice filled up the next day as opposed to when its on, i get no ice. Dont know how to explian it!
    President:
  • 1,796 Answers
Hi!!
Check that the water inlet valve is open all the way. The ice machine needs more pressure than the water dispenser to work. In your Fridge owners manual says that if the filter is dirty, the unit will dispense water but it won't make any ice.
Check this web site for more Info. on your GE unit. http://www.geappliances.com/service_and_support/repair/refrigerator-freezer-icemaker.htm
Good Luck!! Don't forget to rate this post!!
Posted on Sep 03, 2010
  • 4 more comments
  • Rene J Solis Sep 03, 2010
    We do not see your comments until we provide and answer and go back and check. The other Experts comments we won't see them until you are satisfied with the answer.
    So every time you talk to a new Expert, you got to explain the whole thing again and all the repairs you already tried. This will help the new Expert to concentrate in what's not been tried. I thank you for your patience.
    Going back to your Ice Maker problem, I think this is something you have not tried, have you??
    Water Inlet Valve
    Your icemaker's water inlet valve could be filled with ice. If it is, simply thaw the its water tube with a hair dryer to remove the blockage. Be careful to not melt any plastic parts with the blow dryer.
    An icemaker's water inlet valve has a filtering screen to block minerals and other debris from entering into your ice cubes. It is possible that the water inlet valve's screen is blocked, and not allowing any water through to make ice. Clean out any built up debris you find. You should be able to pop the screen out of place with a screwdriver and then put it back in place with the screwdriver again once it is cleaned.
    Here is a blow up diagram of the Ice Maker with the part # and name.
    http://www.partselect.com/ModelFrames.as...
    I just thought of something, you replaced the water inlet valve, so you know how it goes. Could be possible to shut the water valve, remove the inlet valve and place a container if front of the line, turn the water valve on to see if there is water coming and to see if there is enough pressure.
    I was thinking that could be a kinked or obstructed water line between the "Y" that goes to the dispenser and the Ice Maker.
  • yava4 Sep 15, 2010
    when i replaced the inlet valve part of tubing craked b/c of wear and tear . so i trimed off a piece but there is a wire mesh that holds tubing in place once line is inserted, but that got damaged in the process any suggestions as to how to keep tubing in place once i insert the tubing in inlet valve? Otherwise my machine is making ice now and thats due to replacing the spring that goes by ice flapper
  • Rene J Solis Sep 15, 2010
    The mesh you're talking about is actually a filter to produce ice cubes free of impurities. I suggest to replace mesh before using ice maker. If you need your ice maker very bad, then install tubing with the damaged mesh while the new one arrives, but you'll run the risk to get impurities in your ice cubes.
  • Rene J Solis Sep 20, 2010
    Check the trouble shooting section of your Refrigerator's manual to verify the settings on your unit.
    http://products.geappliances.com/Marketi...
Replace the water inlet valve
Posted on Aug 24, 2010
  • 2,382 Answers
Hi, first check to make sure you have water pressure at your supply line. (flex hose) If you have pressure and the icemaker is cycling, (arm moving up and down on its own) you most likely have a defective water inlet valve. This is the valve that the supply line connects to. Water is fed to this valve through your flex hose and then passed through a solenoid to your icemaker when the solenoid is energized.
  • 1,998 Answers
Have u checked the water valve in the rear behind the panel to assure that you are getting water going up to the ice maker there are two lines that come off the water valve one goes to the water dispensor which actually has nothing to do with the ice maker so first thing to do would be to assure that your getting power to the valve next thing that you could do is take an extension and put two terminal ends on it and try giving power to the valve manually this if your valve is working properly will send water up through the line or you can unplug the line and have it go into a small bucket in back of the fridge so first thing is to check the water valve then to assure water is going to the icemaker if your were getting water inside the icemaker from the vavle then i would have to say your icemaekr would be bad so try the water repair first 7 outta 10 times it is a water problem please remember to rank this opinion on repair of your appliance situation and if you have any other questions message me back thanks again
rickead1
Posted on Aug 25, 2010
  • 4 more comments
  • Rick Ead
    Rick Ead Aug 27, 2010
    no you can have excelent flow to your water dispenser its the other side of the valve that goes to the ice maker so if theres an obstruction or that other side isnt getting power to it you will get no water to your icemaker while you will get water to the dispensor there are two differnt lines going from the valve one to the dispensor and one to the icemaker check it out and write me back thanks again
    rickead1 btw bud im on hawaii time so takes me a bit to get back but i look daily usually at night
  • Rick Ead
    you mean the lever? the lever basicly tells your ice maker when there is enough ice in the tray stops makin ice but u still would have water inside the tray if it told the ice maker to stop making the ice
  • Rick Ead
    this way when that lever goes back down it can already have started getting more ice into the bucket please remember to rank how this opinion has helped in your appliance situation and if ican answer anything further message me back thanks again
    rickead1
  • yava4 Sep 01, 2010
    i put in a new valve but still no ice. the paddle that i am refering to is under the main unit of the ice machine not inside it. GE told me to test the ice machine by pressing the paddle in 3 x's and w/in 15min will push ice out of mold which it did ...water then filled up but that was it no more ice came out. apperently i keep having to reset it to have ice come out of mold.
  • Rick Ead
    Rick Ead Sep 02, 2010
    I would just buy a new icemaker they start at about 60.00 and are very easy to install if you think that the lever is the problem your able to see the actual problem with the unit and do the proper tests so all in all if you think that its the arm cuasing you the problem check marone appliance parts there pretty cheap. please remember to rank how this opinion helped in your appliance situation and if i can answer any further questions message me back have a great day
    rickead1
  • Rick Ead
    Rick Ead Sep 03, 2010
    please look at my last response as well you could of tested the water valve without buying a new ne buy hooking power to each side of the valve to assure that water was going though read the last response before this one about buying a new icemaker thanks again
    rickead1
Won't dispense ice
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge.
Thank you for using fixya
imufo2
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Jul 27, 2011 | GE Profile Arctica 25.4 Cubic Feet...
Ice maker not working on GE side by side
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
iyooyi76
Jun 01, 2010 | GE GSL25JFPBS Side by Side Refrigerator
My Aman side by side quit dispensing water. It
Does your fridge have a small tank inside the food compartment? If so, the water may have frozen in the tank and the problem can be solved if you take a blow dryer and warm the tank. That's what happened to mine and with a temp adjustment to keep the food compartment a bit warmer, the water doesn't freeze.
May 30, 2010 | Amana 22.6 cu. ft. Side-By-Side...
The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My GE side by side fridge/freezer is working, water dispensing ok, but not making ice. I switch off the fridge, than ice maker but still not making ice. I try all the hints from Manual but no luck. Water...
fill the ice maker with water manually, if you have ice in the bucket you know that the ice maker is working , after check the water valve if is opening , if it is replace main board
Jun 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
No water coming out of dispenser
the water is freezing. I know this sounds nuts but it is the dust in the back of the fridge not lettng the compressor stay on long enough. call me if needed. 908-380-3633. This almost drove me crazy. Joe
Mar 04, 2009 | Hotpoint HSS25GFP Side by Side...
Refrigerator side won't cool
its iced up and needs to be thawed. you can use a hair dryer and make it fast in say 2 hours. the freezer side is blocked from admitting cool air to the fridge side. your defrost timer may be defective or you had a real humid situation that caused it to ice up.
Dec 08, 2008 | GE GSH25SGRSS Stainless Steel Side by Side...
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Water wont flow into LG LX259602b ice maker
You may have a bad water valve.  The valve has 2 sections, one for the water dispenser and the other for the ice maker.  Check those connections in the back of the refrigerator.  If everything is ok, replace the water valve.
May 18, 2008 | LG LRSC-26922 Side by Side Refrigerator
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
I just used the hair dryer and it worked the water is flowing again out of the dispenser
Dec 28, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Refrigerators Logo
63 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
